Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
KP-51WS510 I have this TV KP-51WS510 have multiple images and I dont know how to fix the problem. I have tried to go in to convergence to fix it but it not do anything. Can you help?
  • Sony Master
  • 3,459 Answers
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Posted on Feb 03, 2009
  • Edward
    Edward Feb 13, 2009
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
  • Edward
    Edward Feb 13, 2009
    Solution #1
MY SONY KP-51WS510 LOOKS LIKE 3D AND THE IMAGE IS CURVED
The flyback as you discovered does not effect convergence. The convergence repair is different. This video should explain it further.
Nov 26, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a Sony KP-51ws510 that has wavey or fuzzy corners opposite of one another?
The problems ur tv having it is call a convergence problems,it dead.Very common problems,for old DLP tvs design.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?Yes,than tv covergence board is dead.Tv convergence board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Feb 08, 2011 | Sony KP-51WS510 51" Rear Projection...
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Have red outline of images on left side of screen
Convergence is dead.Must Know how to solders.Replaced the 2 convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit,to do it ur self.The shop will cost u $300 for parts and labors.
Feb 04, 2010 | Sony KP-51WS510 51" Rear Projection...
My tv wont line up crosses and it is the same model kp-51ws510 51in
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 06, 2010 | Sony KP-51WS510 51" Rear Projection...
My kp-51ws-510 looks like 3D! How can I fix this
TV shows that kind of picture when convergence out ICs become defective.
Replace 2 big black convergence ICs on D board in TV, these ICs are mounted on silver heat sink, requires soldering work if you are not comfortable with replacing ICs, call local tv tech.
Let me know if there is any further question.
Thanks.
Nov 17, 2009 | Sony KP-51WS510 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony dp-51ws510 made 11-03
If your tv is Sony KP-51WS510, then it has problem in convergence ICs or Board and needs to be replaced.
Best Buy has no idea about Bulb, this TV is 3 CRTs rear projection system and has no Bulb or Lamp inside.
Need further help, let me know.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp-51ws510 51' projection tv
There are resistors that need changing and maybe small fuses.
Nov 28, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
547 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
