Question about JVC HD-52G886 52" Rear Projection HDTV
Jvc hd52g886 hdmi no sound
I can get picture with hdmi plugged into tv and dvd but no sound i have dvd run through onkyo receiver no sound!! can i get some help
  • 1284 Answers
SOURCE: jvc hdmi????
Changing the output to digital only affectts the audio output stream such as Dolby Digital or DTS audio. Try turning on the DVD player first then the television and see if then it sees the DVD player. Otherwise using the component outputs most will never see the difference n picture quality. Good luck.
Posted on Dec 12, 2007
SOURCE: JVC HD-70FH96 both HDMI problems
Have you been using a flashlight behind the TV. These TV's have a sensor that shuts off the unit when the rear cover is removed (by sensing light). You may have tripped this. I think you can fix this in the service menu somehow but I can't remember.
Posted on Oct 10, 2008
SOURCE: Mitsubishi HDMI connection trouble
I have the same issue with my 73". Rather then going over all of my connections and equipment I'll just say htat I feel your frustration. I have been on the phone with Mitsubishi directly and it appears as though they have a free software upgrade that should address this problem. If you call 1-800-332-2119 and press 4 in the menu you will get someone to help you. Be patient. They will make you go through all of the fixes that you have already tried. They will mail you a flash drive that goes right into the front USB port of your TV. I hope this is of help. Good luck.
Posted on Jan 05, 2009
  • 11896 Answers
SOURCE: my jvc-hd52g886 has a bad picture where black shld
A projection tv that has color issues is usually due to bad ballast which is attached to color wheel which you should also look at to make sure the colors are not mixed together and wheel is not warped.
Posted on May 10, 2009
  • 53 Answers
SOURCE: my hd52g886 has intermitten picture with sound
when the picture is out see if you can see the lamp light on in the back inside the tv. if its still on you might have a problem with the optical engine. if not try replacing the lamp part# tscl110u
Posted on Mar 27, 2010
Onkyo tx-nr509 no picture with blue ray dvd player
Hello, I am sorry about your issue. Have you tried the other HDMI ports on the receiver. Please check the cable from the receiver to the TV. Thank you, Onkyo USA
Mar 07, 2017 | Onkyo TX-NR509
Onkyo tx-sr604 help
You said you tried hooking the HDMI up directly from the TV to each component, and that worked. How is it usually hooked up - through some kind of switch? I'm not completely understanding your setup here.
Aug 10, 2007 | Onkyo TX-SR604 Receiver
Sound only, no picture, when Blu Ray hooked up to receiver through HDMI. Input was assigned correctly.
are you sure you have the HDMI output turned on through the DVD player? are you sure you have the following;
HDMI Monitor out running to the TV
Correct input on the TV
May 10, 2010 | Onkyo TX-SR705 Receiver
I just bought a Blue Ray player but my surround sound has a dvd player built in and only one input which I have my new Sharp TV plugged into. How can I hook up my Blue Ray . I have the HDMI cables
Depending on if your surround system has a hdmi input or not. if it does you can connect the blu-ray player to it. If it doesn't have an hdmi input you will have to run the hdmi cable from the blu-ray to the tv then run a set of rca cables (red and white plugs) from the tv audio out to the surround systems' audio input jacks to get sound through the surround system. Most surround systems don't have an auxiliary input for another video device.
Nov 21, 2009 | Onkyo TX-SR606 Receiver
How do u plug in a dvd player
the onkyo receiver should have hdmi jacks on it labeled cbl/sat,dvd, and so forth. plug the hdmi wire into the dvd and from the dvd to the hdmi jack on the onkyo that says dvd. then run another hdmi cable from the hdmi out jack on the onkyo receiver to the tv
Oct 21, 2009 | Onkyo HT-SR800 System
I have a onkyo 706 reciever and I can't get any TV sound
Component (i.e. TV) should be connected to plug labeled IN (signal IN receiver).
Jul 15, 2009 | Onkyo TX-SR606 Receiver
No audio sound from HDMI connection from TV to Onkyo 606 amp.
you have the output of the receiver going to the input of the TV?
i believe that you should be running the TV output to the receiver input to get your sound from the TV to the receiver and thus speakers.
the easiest setup is to just run your cable box and DVD player HDMI's into your TV inputs. then run another HDMI from the TV output to the receiver input.
Feb 28, 2009 | Onkyo TX-SR606 Receiver
Connecting PS3 to receiver via HDMI
First put the orginal ps3 cable onto ps3 then to tv.set tv to see ps3 and go to ps3 setup,now down to display settings,set to hdmi,picture will go off so now switch tv to hdmi input .Next go to sound settings for ps3 and set to hdmi if your amp can work this way ,if not set sound out to optical.
hope this helps.
Jun 24, 2008 | Onkyo HT-SR800 System
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
New home theater setup- no signal at tv using onkyo tx=sr605
Could well be the quality of your cables. if you have high end cables the consult a service agent. if you have the cables that came with the products, go and get some better ones.
Nov 04, 2007 | Onkyo TX-SR605 Receiver
JVC HD-52G886 52" Rear Projection HDTV Logo
364 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
