Question about GE (GTS16BCS) Top Freezer Refrigerator
Gts18fbsarww model GE Fridge, doesn't keep cool but freezer is working perfectly barely cold
  • Ken Bledsoe May 11, 2010
    Is your fan working inside the freezer?
5 Suggested Answers
Sea Breeze
  • 4654 Answers
SOURCE: freezer and fridge not real cold no ice
Inside the fresh food compartment there is a defrost timer behind the control panel. There will be a small hole that you can place a screwdriver through and turn clockwise s;lowly until you hear the refrigerator stop. It should remain stopped for about 30 minutes. If not you will need to again turn it again slowly until it starts. If this happen the timer will need replaced. The part number for the timer is WRX9X489 This is correct providing the model you have is the model listed above your post.
Go to the link below and enter your model number in search feature. this takes you to many just like yours, they are same just little differences. Let me know, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 28, 2009
SOURCE: GE fridge
Replace the ADC board. That is the problem i had.
Posted on Jan 13, 2008
SOURCE: Refrigerator warm, freezer too cold
I had this same problem. You need to totally empty the fridge and freezer and allow it to defrost for 24 hours. Then put it back on and it will work. This happens if someone leaves the freezer door open and then it gets closed. The defrosted water freezes in the pipes and doesn't allow the cold air to move up into the fridge so the freezer gets even colder. This has happened to me twice!
Posted on Aug 16, 2008
  • 306 Answers
SOURCE: Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Posted on Nov 26, 2008
heatman101
  • 43501 Answers
SOURCE: fridge and freezer not cooling properly. bottom s...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
68rjszndh
Posted on Sep 29, 2010
Refrigerator not cooling
the damper vent door fan that blows the cold air from the freezer into the refrige compartment is bad,these are known to go bad a lot of the time,you need to buy the whole damper vent door/motor together
May 02, 2012 | GE Refrigerators
GE model tbx14sisdrwh fridge. freezer works fine but the fridge will only cool to 50 degrees can anyone tell me the problem thank you.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 13, 2011 | GE J Series 18.2 cu. ft. Top Freezer...
Freezer works fine but fridge doesn't get to cold any more
heatman101
Jul 31, 2011 | GE Refrigerators
Freezer and Refrigerator are not cold enough. Freezer barely keeps things cold and fridge doesn't keep cold at all.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Jul 07, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Freezer working perfectly but Fridge section not cold Model Refeerences ZD-28/11 155/2T
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Apr 21, 2011 | Zanussi Refrigerators
I have a ge refrigerator MODEL NUMBER GTS18FBSARWW AND THE FREEZER IS NOT COOLING completely
i have a ge fridge and the frezzer is working, but the fridge isnt keep food cold enough
Dec 28, 2010 | Refrigerators
Refrigerator not getting cold enough
Read these tips... they will help you...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 31, 2010 | Whirlpool (ET8FTEXSQ) Top Freezer...
Freezer is very cold, refrigerator not cooling on Maytag side-by-
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
s
Nov 25, 2009 | Maytag MZD2766GES Side by Side...
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
GE (GTS16BCS) Top Freezer Refrigerator Logo
501 people viewed this question
Top Refrigerators Experts
KJ4QOB
Jim Akins
Stan Ford
