Question about Sansui COM312AD 13" TV/VCR Combo
13" sansui AC/DC 12 volt use
Hello, I have a Sansui 13" AC/DC VCR combo and it is supposed to 12 volt capable but it won't turn on when I only have it pluged to a 12 volt source. I did check to make sure I had power in the recepticle, and it does work fine when it's pluged into 120 volts. Is there any thing I need to do for 12 volt use?
Thanks,
Tony
  • Sansui Master
  • 520 Answers
Did you check the fuse inside the plug on the 12volt cord?
Posted on Feb 06, 2009
Remote code for Sansui Com312 AD 13
These are the codes to check with Sansui brand TVs. 1052 1061 1203 1157 1091 1075 1173 14231140 1032 1051 1337 1237 1209 1079 1232 1287 1203 1258 1335 13391340 1375. If you wish to get more codes, and set-up proceedings to many other popular remote controls, check these links.http://electrohelponline.blogspot.com/ http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 11, 2013 | Sansui COM312AD 13" TV/VCR Combo
I need a code for my remote control?
Hello
You hven't given any specification of the remote control you have. Yet I hereby send you universal remote codes for Sansui herewith.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit codes to check with are:
0135 0310.
Four digit code for Sansui TV/VCR cobo is:
0310
  1. .
Nov 02, 2011 | Sansui COM312AD 13" TV/VCR Combo
Code for universal sony remote sony-v201
Hello
Sorry to say that Sansui is not listed to Sony V201 remote control. Anyway I'll give you some three digit and four diit conds for Sansui. I'm not sure will it work, but try these, sometimes you may get.
135/ 136
Four digit universal remote code for Sansui TV/VCR combo is
0310
Four digit universal remote code for Sansui TV are:
0135 0310
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
NOTE: Switch OFF and switch ON your combo with its FRONT PANEL POWER ON-OFF SWITCH each time before trying an other code.
Hopes you will be helped.
OK.
Jan 27, 2011 | Sansui COM312AD 13" TV/VCR Combo
I have a 2004 sansui 13 in screen tv vcr combo no manual. How do you program the vcr to record?
MAIN MENU ON THE COMBO ,,UNDER SETUP ,,SET UR CLOCK ,,AND YOU SHOULD FIND IT ALL THERE
May 15, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Is this set digital ready?
I'm sorry, but this tv is not digital. You might be able to use an inverter that converts 12volts DC to 120volts AC to power a digital converter box.
Nov 07, 2008 | Sansui COM312AD 13" TV/VCR Combo
Sansui VRDVD4000
Universal remotes rarely fully work with these type of units. Call Orion customer service 800 289 0980 to price an original remote.
Oct 09, 2008 | Sansui VRDVD4000 DVD Player/VCR
Sansui COM3101A 13" Tv/VCR Combo Problem
You can try the codes for Orion, Emerson, and RCA. Call the number on the back of the set to see if the original remote is available.
Sep 28, 2008 | Sansui COM3101 13" TV/VCR
Need to find a code to work the tv/vcr combo from a comcast digital remote
Try the codes for Orion, Emerson and RCA as well as Sansui. Good Luck!
Jul 22, 2008 | Sansui COM3101 13" TV/VCR
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
"DEW" is on screen and VCR not working
When the DEW appears leave tv on for several hrs at room temp. The heat from the picture tube will help remove the moisture.
Jun 30, 2007 | Sansui COM311AD 13 in. Combo
Sansui COM312AD 13" TV/VCR Combo Logo
250 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
