Question about Linksys Wireless-G Broadband Router
Unplugged to move wires now not working
Trying to get connectede
The reset button is not actually visable to those that need glasses or in poor lighting. Most likely there is a hole the size of a ink pen head. That is your reset button. stick a small object (ink pen head, toothpick... ect...) in hole for 10 seconds to reset.
Posted on Feb 01, 2009
    Problem Solver:
  • 20 Answers
Hi. I had this same problem about six months ago.
There is a RESET button somewhere on the console, i don't remember exactly where. If you plug it in and hit the reset button, it should boot up. Unfortunately, you'll have to set up the network again.
Good Luck!
At times I'm not getting power to fuel pump.turn ignition on and no power to gauges.gently close door and reach through the window and turn ignition on and everything works fine
is there wires under the seat that are shorting out or coming parley unplugged or are your feat touching some wires from under the dash try kneeling by the door and try moving the wires under the dash
Dec 03, 2015 | Cars & Trucks
Release a stuck power front seat in my 2009 tahoe? its stuck all the way forward, need to move it back
there is no release. it can only be moved with the motor. if the swtich is bad you can try to bypass the switch using a battery and 2 wires and get the wiring diagram for the swtich. then if you know what your doing. jump the wires and get the motor to work
Jan 23, 2015 | Seat Cars & Trucks
I keep having to the was button to connect to the internet won't stay connecteded 2 my y800 WiFi device
Your Y800 device is a Wi-Fi router with a 4G connection on it.
It may be the 4G connection is intermittent, not the connection to the laptop.
You need to check with your mobile supplier that it supports LTE.
ALCATEL ONE TOUCH PRESENTS ITS LTE DEVICES FOR MOBILE CONNECTIVITY
Oct 15, 2014 | Computers & Internet
Oven won't work says PF
Hello lornalang - Typically "PF" indicates power failure. Once again try reprogramming the range by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. If it proves to be ineffective, the range may possibly be experiencing a wiring failure or faulty EOC. Consult a professional to move forward accurately and to assist with the repairs.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Quantum 610 error #107 Charger Inhibit
I just had same code. I took off rear cover and unplugged a rubber cap at the end of a long skinny group of a few wires. looks like a charging wire kinda. and unplugged the main plug. I did not unplug the two larger battery plugs. when I plugged them back in firmly everything was back to normal.
Mar 03, 2012 | Health & Beauty
Sound not working on onkyo ht-r510. It Powers on and all the buttons work, but sound doesn't come out of speakers.
Simjones700,
Assuming that everything looks like it should work, that the volume is up sufficiently and the mute is off, and that any power section fuses are set and/or not burned out and that the units 'warm up' temperature feels the same. I would try a process of elimination something like this:
* Always turn the unit of and unplug it everytime you attach/detach speaker wiring *
Unplug all sources (DVD, CD, DVR etc) and use only the FM section as as source:
  1. Does the unit have an indicator that is labeled overload or protect or something like that? If so, then unplug/disconnect and inspect the wiring on the speaker terminals. Ensure that if they are bare wires, there are no strands from different wires contacting each other.
  2. Does the unit have a speaker have an A/B switch? If so, ensure that your speakers are plugged into the correct terminals
  3. Does the unit have earphone plugs? If so, try using those . . . if you don't have any earphones go and purchase a cheap pair . . .make sure you have the proper plug - 1/4" stereo?
  4. Do you know for a fact that your speakers work? Beg, buy or borrow a pair of cheap of speakers and try them.
  5. Try using different speaker wire . . . if you have a fancy monster or vampire wire wiring set up, then go to RS and buy some in-expensive speaker wire (not too thin!) and see if anything changes.
  6. Unplug everything from the unit and then hook up one and only one speaker and see what happens. Move the speaker wiring from one set to another, see if there is any behavior change . . .
If after all this and no joy, then time to take it to be serviced.
The Poodle Guy!
Nov 25, 2010 | Onkyo HTR500 Receiver
1997 blazer fuel gauge so if i try this the fuel pump should it work ? if it doesnt work should i assume its bad gauge
The pump won't work if you unplug it, I'm just trying to help you diagnose the gauge. If unplugging it doesn't make the gauge go the other way then hook a jumper wire between one of the black wires and the purple wire. Turn the key on and see if the gauge moves the other way. If it moves when you ground it test both black wires for good ground. If they are good, replace the sending unit in the tank, again, even if its new, the parts store should warranty it if its less than a year old.
Apr 03, 2010 | 1997 Chevrolet Blazer
Laptop not connecteding to internet
There is a reset button on the back I think on this model. This will reset it to factory default. You don't need drivers for this to work. What kind of internet access do you want to hook this to? Or do you want to use it for lan use only?
Sep 19, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
SUNROOF STUCK IN OPEN POSITION
Control Module might have issues.
Remove headliner (quite a job)
Unplug the the power leads to the sunroff motor
Use spare wires to use power from the overhead dome light to the power conections on the motor to get it to move a bit.
If it does not move, reverse the wires. If it sill does not move, then the Sunroof Motor is bad.
Otherwise, Re-connect the power leads to the motor and re-try the sunroof switch to get the roof closed..
Most likely the sunroof control module has a bad diode.
Jul 23, 2008 | 2004 Nissan Maxima
Power to second screen
Try the online help at http:www.1800customersupport.com. Also, in order to watch both units together, once connecteded by the audio video cable (red/white/yellow), the power supply must go to the dc in jack of the monitor (not to the the player).
Jan 11, 2008 | Durabrand Portable DVD
Linksys Wireless-G Broadband Router Logo
18 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
