Question about Kenmore 24032\24036 Top Load Washer
Washer wont spin
My washer wont spin....I found a thick rubber ring under the machine....when inspecting underneath, there is a white circular plastic piece with prongs....looks like some of them are broken off??? any suggestions
  • Anonymous Feb 01, 2009
    vxa
  • 640 Answers
The the motor coupling ..unit want wash or spin,,,if you would lik to try your hand at replacing it lety me know,,onthejob
Posted on Feb 01, 2009
Kenmore washer will not spin moved out and underneath found a wagon wheel shaped black thing with four small plastic white parts?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look in the section for the motor, pump gearcase and you'll see the Motor Coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump. This is likely why the machine drains.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Dec 29, 2010 | Washing Machines
Washer won't spin, found rubber shavings under unit kenmore 90 series
Dec 19, 2010 | Washing Machines
I have the Kenmore Model 110 92274100 . The drum does not spin and under the washer is powder from the belt. If you could explain the method for which to inspect/replace this I would greatly appreciate...
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Nov 18, 2010 | Washing Machines
Washer will not begin spin cycle
Hello,It needs a drive coupler for the motor/transmission.
Unplug machine. Just lean the machine back, pop the two clips on the pump and put it to the side. Take the two screws out of the motor clips (usually 1/4 inch), and pop those clips off. Motor will come off. You will see the 3 fingered white piece on the motor shaft and one on the transmission shaft. There is a rubber coupler that connects the two. Replace which ever white plastic piece is broken, or the rubber piece if that is it. Make sure not to bang the white plastic piece too far onto the shaft. The shaft should go flush with the white plastic part facing you. Put motor and pump back together and plug in motor.
Thanks
May 23, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a kenmore series 70 heavy duty washer. The agitator stopped spinning. I moved the washer out of the laundry closet and found broken plastic pieces and a torn up white rubber thing under it. I...
If this is a basic top load, direct drive washer, there is a rubber-band like device that fits around the brake drum. It's a sound deadening device and won't hurt anything if it's broken or missing. That's likely what the "belt or gasket" is.
May 02, 2010 | Washing Machines
My washer (ALW880QAW) agitates but does not spin. I took off the front cover and the found a black circular piece lying there (What it goes to I do not know). The belt looks okay. The motor goes in spin...
That is the drive coupler and it has worn out. You can order a replacement set that comes with two plastic retaining pieces that slide onto both your transmission and engine and also a rubber piece that goes in between these two plastic pieces. You can search many places to find out how to replace this part. I just ordered a set and shopped around a bit and mine was $20 after shipping.
Nov 29, 2009 | Amana ALW880WH Top Load Washer
Kenmore Elite washer wont spin
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.20932992
See the section on the motor and transmission.
Between them is a rubber piece with six holes. The power from the motor is transmitted through the rubber piece to the transmission.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. This may be the baseball in spokes sound (the plastic prongs clicking together.
Oct 14, 2009 | Kenmore Washing Machines
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 24032\24036 Top Load Washer Logo
Sal De GO PATS
fordexpert
Ed Mac
