Question about Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s
My image of decals
Why are you using my image of decals and discription without a link to my site? You are using this with out my OK, Briggs & Stratton 66set Panzer Tractor Decal 6hp 1960s? I had a customer ask me if there was a problem with my decals, NO there is not, just poor wording at another site! Jim owner of web site www.engine-decals.com and eBay store http://stores.shop.ebay.com/ENGINE-DECALS
  • jimbowie57 Feb 01, 2009
    Hi mrfixit, I have most on eBay right now, if you are looking for something special let me know. Jim
ImpalerCo
  • 13 Answers
SOURCE: replacing engine. Briggs 26hp on GT5000 garden tractor
Unfortunately, there is no single manual for this. It depends entirely on what crankshaft the OEM requested be used in the engine. You need to find out the diameter of the crankshaft and any threading to it, direction of the threading, etc. From there, a replacement can usually be found pretty easily. That or contact Briggs customer support (number in your owners manual) with the Model, Type and Code numbers off the engine. From this information they can see how the engine was outfitted for that OEM. Horsepower tells them nothing as those ratings and stickers are often replaced by the OEM and often NOT the information Briggs sends out on the engine.
Posted on Mar 13, 2009
  • 22 Answers
SOURCE: I am trying to get the 11 hp Briggs & Stratton
On the end of the shaft that comes from the motor there should be a bolt that holds the pulley in place. You will need to remove the bolt in order to get the pulley off. If you can lift the front end onto a couple of blocks it will make the job easier to do. You may have to place a screw drive in between the belt and the pulley. A wood wedge the width of the belt would be better as it would be less likely to damage the pulley. Depending on how old the tractor is, you may have to spray the bolt with a penetrating oil first to help loosen the bolt.
Hatter1
Posted on Mar 14, 2009
SOURCE: Poor running engine on my lawn mower
I think you need more than a screw adjustment in the carburetor. It sounds as if you need a full tuneup. This means air filter, gas filter , carb. rebuild ,spark plug etc. Good luck. donnyb60
Posted on Mar 22, 2009
  • 83 Answers
SOURCE: removal of flywheel from briggs and stratton 4 cycle engine 3 hp
Without the $100 flywheel remover that briggs will happily sell you you can do the following.
First you will need another body to help, two if available
2 pry bars or large screwdrivers
A air hammer if you have it or a large hammer if not
Loosen the flywheel nut until it backed off til the nut is just barely one thread or even with the shaft. Now put your pry bars behind the flywheel on opposite sides. Have someone provide constant pressure (don't be too forceful the block is made of aluminum and can be damaged). Now hit the end of the shaft with a hammer or air hammer (the nut is protecting the shaft threads) with medium power. With a few careful hits the flywheel should pop right off.
If you run into trouble or are unsure of something in this proceedure please ask.
Posted on Mar 30, 2009
  • 583 Answers
SOURCE: Briggs & Stratton Briggs Stratton Intek V -
these are common for doing this ,if you dont want to pull it down and hone the cyl. then i would use a heavier oil say 20w/50and that will probabley solve your problem
Posted on Oct 25, 2009
How do I know if a site is ok to post my website without validating the Google Adsense's policy?
1. Make sure that you site should not have more flash and animated content
2. Content should be unique and needs update frequently
3. Image should not more compare to your text content
Sep 03, 2014 | Google AdSense
Where can i purchase a diaghram for 6.25 briggs engine
Any Briggs dealer should be able to get it for you. Try a local lawn and garden store. Or at the bottom of this web page link there is a link for the "Service Dealer Locator" in the section of "Support" and you can use that to find a place local to you.
Briggs and Stratton site
Aug 26, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
I need an ower's manual
Find the model number (look at decals on mower) and click here for a manual. Even if they don't have your exact model, the differences are minimal between units. Good luck! Please rate my solution if helpful, thanks.
Jul 04, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Engine wont start
go to youtube and type in valve adjustment on briggs,very simple procedure to do.
Apr 23, 2010 | Briggs & Stratton 66set Panzer Tractor...
Descaling De Longhi IFD Expresso Coffee Maker
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have De longi , Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Mar 20, 2010 | Coffee Makers & Espresso Machines
2.5 year old, 15.5 hp Briggs cranks but wont fire
make shore that the valves are not rideing no tappet clearance back both roccers of and try for comp there has to be a tappet clearance for there to be comp or set the inlet at 5 thou and the exhaust at 10 thou on the comp stroke .horizontal b/s have a very good past very good engine in the past
Jul 13, 2009 | Briggs & Stratton 66set Panzer Tractor...
Engine working ok tractor slows down to crawl after sort time of use
Check to ensure governor spring is not stretched or possibly missing. Here is a link to their web site so you can check location of parts and also get info on your unit in depth. Hope this helps.
http://www.briggsandstratton.com/maint_repair/
May 22, 2009 | Briggs & Stratton Garden
750 decals
Fairing is from a later bike looks like FE fairings with the side air inlet and the decals are definitely not stock and I would guess custom made. Do a google search for images of your bike and you can see stock. Other than the Dunlop decal on the seat, (what happens if you use Michelins?) it looks fine IMHO.,,,
Nov 10, 2008 | 2002 Ducati 750 SS
Briggs & Stratton 66set  Panzer Tractor Decal 6hp 1960s Logo
151 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
