I'm looking for the remote code to program a directv remote to a Polariod model ttm-2410 tv. Know any?
  • 360 Answers
Direct tv gives this code 11641
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • more possible codes 11326 11991 10765 12002 11992
    still more
    11523 11276 11498 11327 11328
    11314 11262 11962 10865 11316
    11286 11341 10178 10835*
    Codeslisted with an asterisk (*) are possible alternate codes for yourdevice. These alternate codes should operate the primary functions ofyour device in most cases (Power, Volume Up/Down, Mute).
    There is no other setup code indicated for your product
    that links to the model number you entered.
    Youmay still find a setup code that works for your device by steppingthrough the library codes in your remote. The following instructionswill help you do this. StepNSet
    • Set the "Mode Switch" to the desired mode such as TV for a Television.
    • Enter the code "991" followed by the "device number"
      1. for Televisions
      2. for "AUX 1" devices - VCRs or DVDs
      3. for "AUX 2" devices - Audio
    • You can step through the setup codes for this mode by pressing the"Channel Up" key to go forward through the codes or pressing the"Channel Down" key to go back to the previous codes.
    • You can try out each code by pressing one or more function keys such as power, volume or digit keys.
    • When you've found the setup code that works for your device, press the "Select" key.
    This is all the information I could find, Poraroid does not offer a URC code.
    Hope this helps
    Please take the time to rate this solution
    Posted on Feb 01, 2009
    What is the code to program the direct tv remote for model LN37B550
    You should look up in DirecTV control's user's manual. To get the manual, you should provide make and model of your DirecTV remote
    DIRECTV Remote Control Code Lookup
    Jun 21, 2014 | Samsung Televison & Video
    Sanyo vizon model clt1554
    I think you are asking about the Directv remote codes to control your tv,if so you can get those from the directv site.Look under remote control programming and select your tv or device.It will give you the most used codes
    Jun 18, 2014 | RCA Direc Tv Remote Control Model Crk76sg4...
    How to program Direct TV remote
    How to program your DIRECTV remote control:
    Press MENU on remote.
    Select "Parental, Favs and Setup".
    Select "System Setup".
    Select "Remote".
    Select "Program Remote".
    While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
    How to program the white DIRECTV remote to your TV
    Look up the control codes for your DIRECTV remote control.
    Make sure your TV is turned on.
    Slide the mode switch at top of remote to "TV".
    Press and hold the MUTE button. This is located above the number 1 button.
    While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
    Enter the first TV code you have. The green light on remote should flash twice.
    Aim remote at TV and press PWR button once. The TV should power off.
    Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
    If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
    If remote control fails to program using all available codes, try scanning for the code.
    How to scan for TV codes on your DIRECTV remote
    While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
    Then enter 9911, the green light on remote should flash twice.
    Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
    When the TV powers off, press and release the SELECT button.
    Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
    You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
    Apr 11, 2012 | Audio Players & Recorders
    I need to know the code to program a jvc av-32432 tv to a direct tv remote
    Hello
    The code for JVC with Direct TV Universal remote is:
    10053
    Programming DIRECTV Remote
    [1] Locate the DIRECTV Receiver's brand and model number
    (on the back or bottom panel) and write it in the
    spaces below.
    [2] Enter the 5-digit code for your DIRECTV Receiver
    [3] Power on the DIRECTV Receiver
    [4] Move the slide switch to DIRECTV icon
    [5] Press and hold in the MUTE and SELECT keys until the
    green light under the DIRECTV icon flashes twice and
    then release both keys.
    [6] Using the number keys enter the 5-digit code. If performed
    correctly the green light under the DIRECTV icon
    will flash twice.
    [7] Aim the remote at your DIRECTV Receiver and press
    that the power key once. The DIRECTV Receiver should
    turn off. If it does not turn off, repeat steps 3 and 4, trying
    each code for your brand until you find the correct
    code.
    OK.
    Jul 06, 2011 | Televison & Video
    Trying to program direct tv remote to westinghouse 42" tv. Gon't have tv code
    Since you did not specify the model number, you can get the instructions for programming your Direct TV remote at
    http://www.directv.com/DTVAPP/content/remote_codes
    Let me know if you have any other questions. Thanks.
    Please rate this solution. Thanks.
    Feb 03, 2011 | RCA DIRECTV Satellite Remote Control
    Need code for polaroid model ttm-2410 for one for all remote
    Hello
    Four digit universal remote code for Poloroid TV are:-
    0182 0173 0133
    NB: Switch ON and switch OFF the Tv by its FRONT PANEL POWER ON OFF SWITCH; NOT BY REMOTE CONTROL HANDSET each time before trying an other code.
    Direct Code Entry
    1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
    3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
    4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    Ok
    Dec 29, 2010 | Polaroid TTM2410 TV
    FLM-373B Polariod tv codes
    try this:
    Setup Instructions
  • Try your new code and tell us how it worked!
  • Jun 01, 2010 | Directv RC23 Remote Control
    Unable to program Directv universal remote for tv
    The RC64RB has more codes in it. Unfortunately, it is an extra $25. BUT, it is backlit, which is very cool at night. With my RC64RB, I get 16 codes to enter for your TV (Emerson HDTV).
    Dec 29, 2008 | Universal Remote Control DIRECTV Universal...
    Need Universal Remote Code For Polaroid TTM-2420 TV
    I recently found a remote that does work for this TV. Its a DirecTV model RC64. The codes listed in the book do not work. So you must do a channel search. It's not that far down the list so it doesn't take that much time. I hope this helped those concerned.
    Dec 13, 2008 | Polaroid TTM-2420 TV
    Televison & Video Logo
    81 people viewed this question
    Top Televison & Video Experts
