Question about Jensen MP7610 CD Player
Detachable face for some reason i cant read what's on face. it barely shows anything. at night if u look hard u can see a little but cant read it. what's wrong? please
  • martell tyson Aug 01, 2007
    THE FACE IS DETACHABLE AND I DONT SEE A RIBBON CABLE PLZ HELP ME N TY FOR THAT INFO
There is a brightness controll on the radio menu and you can ajust it. I had the same problem.
Posted on Feb 28, 2008
    Novelist:
    Champion:
  • 219 Answers
Either the back light lamp is burned out or if it is also a flip face, then you may have a "wire" on the ribbon cable to the flip face that is broken and then you would need to replace the ribbon cable. If it is a flip face then I would strongly suspect that it is the ribbon cable.
Posted on Aug 01, 2007
SOURCE:
Face book will not stop rolling cant read anything then bounces around, cant get it to stop?
this seems like a keyboard (or mouse) error... when this happens try to detach your keyboard and mouse to see if this stops.
Nov 15, 2017 | Book Computers & Internet
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Hi Guys, you must be getting this a lot, but i am going nuts! I have a Hitachi 5K320 250Gb Harddrive that for some reason I cant get in anymore. I have very important stuff on there that i need for my...
I know it sounds a little nuts but try it with the drive upside down or on either side or on end supported by some books, you can also try cooling it off in a fridge for a while. when a drive starts to go and starts making clicks and vibe noises you have very little time to get everything off. before you try anything make sure you have space to save the files if you do get in.
Also look into Puppy Linux it runs in ram without running the hard drive,
Puppy may be able to read your drive.
I'll check in with you later, off to work.
Regards
TickMagnet
Aug 16, 2011 | Hitachi Travelstar 5K320 320 GB SATA Hard...
Video will not show
Hi and thank you for using fixya:
Please explain more what is your problem. Does it shows anything on the screen at all or just the dvd?
Jun 08, 2010 | Phase Linear 160W AM/FM/CD Receiver W/...
I have an Olympus FE-330 The problem I am having is when I take pictures at night, focusing on anything is impossible. The view shows black, until the picture is taken. After the picture has been taken it...
Take a flashlight with you and shine it on what you want to focus. Press the shutter half-way, shut off the flashlight and press the rest of the way.
Jan 18, 2010 | Cameras
Display not working
I have the same problem. There's a little ribbon cable behind the contacts for the faceplate. It gets folded as the face plate motors in and out and eventually breaks like mine did. I'm fixing it tonight and then I will disable the motorization. Followed by NEVER BUYING A PIONEER AGAIN. I reccomend you do the same.
Aug 05, 2009 | Pioneer DEH-P780MP CD Player
Unable to delete data or format or partitioning samsung HDD
Have you tried booting from a Windows XP CD? If you have one available you can boot from it, delete the partition and format it. Works all the time for me.
Jul 30, 2009 | HP Computers & Internet
FACE
You can take a piece of tape or a small peice of paper (matchbook anything) and pin back the little tab in the middle towards the bottom that is pressed when you put the faceplate on or goto circuit city and steal one off the floor model i had the same prob gl
Jul 07, 2008 | Pioneer AVH-5700DVD Car DVD Player
Detachable face plate for DEHP47DH on and off buttons and other function buttons not working.
make sure the connections are clean on face plate and base make sure no grease or anything like that failing this then contact the makers or even place of purchase usually as long as you have the face plate and the whole unit they will replace the face for free but you might need to show them both as stolen ones people were getting the face for free so they stopped this so get in touch with makers or even place of purchase they should replace for you.
How old is device?
Have you tried pushing the face in whilst pressing it on further just in case the connections are not touching.
Do any buttons work?
Apr 21, 2008 | Car Audio & Video
I/O Magic external drive not showing up in computer
Extreme temperatures, either very hot or very cold, can certainly cause damage to your External Hard Drive.  Based upon your description, it sounds like the hard drive enclosure has been damaged.  This would explain why device manager can not recognize it.  Your hard drive is plug-and-play with Windows XP, so no drivers are necessary.  Have you tried plugging it into another computer?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on the I/O Magic website.  Make sure to get the right size enclosure.  Your hard drive has a 3.5" hard drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still isn't recognized by multiple computers, then the hard drive inside the casing has probably been damaged, and I would recommend contacting a data recovery specialist.
Have a nice day,
I/O Magic Technical Support
Mar 10, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Jensen MP7610 CD Player Logo
124 people viewed this question
Top Jensen Car Audio & Video Experts
Mike Duncan
Mike Duncan
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
