Can't change channel on Element TV
I am not able to change the channel on the tv by pressing the channel up or down button. I can only change the channel by entering the channel by the number keys.
  • 1 more comment
  • Anonymous Mar 13, 2009
    My Element tv will not allow me to change channels by channel up or down buttons but I can still enter channel numbers on the remote.  The
    up/down buttons work in other functions of the menu so I know the remote and buttons on the side of the tv are working.  I'm wondering how to
    do a reset on the tv...the menu reset doesn't do the trick.
  • Anonymous Apr 16, 2009
    same here what the heck
  • US User Sep 18, 2010
    Sounds like what my TV is doing.... it is as well an element TV, (Flat Screen , LCD)
SOURCE: Can't change channel using the remote or buttons on tv
Just run a channel scan, it should work after that.
Posted on Nov 11, 2008
SOURCE: Volume and chanel number stays displayed
Pressing i+ button (bottom left on the original remote) for 5+ seconds worked for me...
Posted on Jul 26, 2008
  • 34 Answers
SOURCE: My Olevia TV will not change channels using the remote or buttons
First thing, check batteries in remote, next make sure there are no obstructions between your remote and your tv. i would then call olevia tech support and describe your problem. sounds like the remote sensor has failed. usually covered under warranty. check with olevia to see if they have a factory wide problem or issue with remotes. persistance pays off in this case so just keep on top of tech support. hope this helps, john.
Posted on Apr 09, 2009
  • 192 Answers
SOURCE: my remote control for my polaroid tv wont change channels.
You may be able to program your cable box remote to control your TV in addition to your cable box. When they initially set up your cable box they probably left a pamphlet giving you instructions on how to program your remote. I'm not sure why you can't change the TV channels manually but this may give you a work-around.
Posted on Apr 26, 2009
romsky79
  • 822 Answers
SOURCE: Channels will not change- 42
it means that only one channel save from your tv. press automatic search to search more channel from cable signal. now you can change channel.
Posted on May 29, 2009
Soo I accidentally pressed the USB button on the element controller and I have no idea how to take it off again sooo...
The USB button is a dedicated shortcut key to select the USB source. To change to another input, press the Source button repeatedly until you have the desired source selected and then press OK. (On the Element ELEFW3916 TV, it's the lower side of the button above the power button on the side. On the remote, the source button is between the volume - and channel down buttons. That puts it below the mute.)
I hope this helps. Please post a comment with the model of your Element TV, if you don't see an Input or Source button on the TV or remote.
Jul 17, 2017 | Element Televison & Video
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
We dont have a manual and we dont know how to change the channel or set the time
To set the clock on the unit, have the TV connected to power but not on. Then press and hold Mem/Clck Adj on the TV (it's the third button from the right in the top row of controls). Use the adjacent Tune/Clk (up/down arrows) to set the clock for 12 or 24 hour time. Then press Mem/Clk Adj again to adjust the hour with the up/down arrows. Press Mem/Clk Adj again and set the minutes. Press Mem/Clk Adj to save the time. The original remote also has these buttons. Mem/Clk Adj is also labeled Set and is the furthest right button on the second to bottom row of the remote. The Tune/Clk buttons are the DN and UP buttons on the left of this row.
Use the Tune/Clk arrows to change the radio channels after pressing the radio button (second from the right on the bottom row). When you press the TV button (first on the right of the bottom row) to watch TV, then you need to use the Channel up/down arrows at the top and bottom of the ring control on the far right of the TV or the Channel + and Channel - buttons on the remote. On the remote, the Channel + button is below the timer button which is below 9 in the keypad section. Enter is below the Channel + button and Channel - is below Enter. Make sure that the TV is in the correct mode for your signal (ATSC for OTA and NTSC for analog cable) by pressing the TV mode button. If you are using a set top box, you will need to change the channels at the box.
Press the TV Menu button and then go down the list to Time to set the time zone for the TV. Press Enter to save the setting. Use the TV Scan button to get a list of available channels before trying to change channels.
The manual for the GPX KL868S is available from GPX at the product page: http://www.gpx.com/store/p/287-KL858S.aspx . The direct link to the English version of the manual is: http://www.gpx.com/owners_manuals/KL858S-IB.pdf .
I hope this helps.
Aug 22, 2011 | GPX KL858S 8.1 in. Under Cabinet TV
The Zenith Digital TV Converter DTT900 needs reprogramming
1) While pressing & holding down the TV POWER button, press CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on or off. 2) Release the TV POWER button when your TV is turned on or off. *Each press of the channel button sends a manufacturer code (1-45) to your TV, one after the other. Note: You may have to do this every time you change or remove the battery, as the remote will reset itself to the default code.
Nov 25, 2009 | Televison & Video
I need to re tune my samsung tv but have no remote any ideas?
you can always use the button on your Tv itself.
ie menu = Menu
Channel up/down = take you up and down
volume = goes left and right.
follow these steps
Menu,
channel down button to CHANNEL
press the volume button along
channel down button to AUTO STORE
press the volume button to Start the scan.
right now you have your telly tuned in. What you could do it get an old sky remote off a friend/ neighbour. or buy from argos etc ( a lot cheaper then getting a replacement samsung one)
press the following buttons on the sky remote to program it to work with your samsung tv.
TV,
RED + SELECT
TV.
0060
try the volume if this works press SELECT to save this code if it doesnt press Tv then try the volume again. repeat this step until the volume works your telly. once it doest dont forget to press the SELECT button to save.
Now you will be able to change your volume use the number keys. if you also press the HELP button on the sky remote this will also change your AV / SOURCE I hope this post helps you out. When it does please leave a thumbs up for me Please
Cheers Little Dish Fitter
Sep 21, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
I need the codes for the sylvania television as i replaced the batteries and then it stopped working my tv
1. Manually turn on the device (TV, VCR, etc.) to be
controlled.
2. Press and hold the CODE SEARCH button until the
red indicator stays on, then release the CODE
SEARCH button.
3. Press and quickly release the desired mode button
(TV, VCR, etc.). The red indicator blinks off once.
4. Press the CHANNEL UP button repeatedly (up to
300 times) until the device to be controlled changes
channel. The red indicator blinks off with each
button press. If you accidentally overshoot the
code required, press the CHANNEL DOWN button
to backtrack through the library until the device
changes channel. Pressing CHANNEL UP changes
direction to forward again.
5. Press and release MUTE to install the code.
Jul 16, 2009 | Philips PM3S Remote Control
Can't find button on tv to change source in order to play dvd
I'm assuming that you do not have access to the remote for the TV. If you do, you can simply press "INPUT" on the remote.
If you have no remote, try this:
Press the "MENU" button on the TV.
Press "CH Down" until "Channel" is highlighted, and "MENU" to select it.
Press "CH Down" to highlight "List and Labels", and "MENU" to select it.
Press "CH Down" to go below channel 1, you should see "FRNT" displayed.
Press "MENU" to get out of the Menu system.
You should now be seeing whatever is plugged into your front connectors.
Simply pressing one of the channel buttons will switch back to normal TV mode. I could find no faster way to access the front connectors without using the remote.
Feb 11, 2009 | RCA F25442 25" TV
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Televison & Video Logo
1,950 people viewed this question
Top Televison & Video Experts
