Question about IBM (02R4084) Motherboard
Ibm 8 pin connector front panel problem
I've got an IBM motherboard (fru19r0837 gv) with Intel 865 chipset and i cant find anything on the web about it but it looks like the intel D865GLC board
http://us.st12.yimg.com/us.st.yimg.com/I/yhst-88444626679184_2016_5171348
except for the part pointed as (S) in the picture... i got her an 8-pin connector for the power switch, led etc. the problem is i don't know how to power on the PC I tried to put the power switch 2 wire connector in all places 7-8, 5-6 then i reversed the connection and still not working ... anyone got any idea for this plz post
3 Suggested Answers
  • 161 Answers
SOURCE: IBM NetVisat 02R4084 Mainboard
With the power on cross the pins with a slide on connector. When it fires on you know which one is the sw. When you cross the reset it will restart. When you try the HD the light will come on during HD activity. And the power light will work when you have the power light plugged. It isn't to hard. Just be careful.
Posted on Aug 12, 2007
SOURCE: I have a problem with Ibm motherboard wiring
Het probleem is whera zijn de schakelaar , reset switch , power led en HDD LED Pins?
Posted on Jul 23, 2010
Download e139761 manual a10383
An old Intel entry server motherboard, that uses a Slot 1 Intel processor,
http://www.ebay.com/itm/Intel-S875WP1-E-Entry-Server-Motherboard-E139761-D33025-Free-Shipping-/321064089691?pt=US_Server_Boards&hash=item4ac0e9385b
Over by the white IDE connector on the Right side of the motherboard, (Motherboard installed in computer case), there is a 9-pin Front Panel header.
It is the usual Intel 9-pin Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
Regards,
joecoolvette
May 01, 2013 | IBM (73P0595) Motherboard
Where to find manual for motherboard 143159 imperial Gv 20030812?
Good luck. Used to be you could get a mobo manual from e4allupgraders.
The Imperial board is made by TriGem
Started out as TriGem Sambo, is now TG Sambo
The Imperial models were Imperial G, Imperial GL, Imperial GV, and Imperial GLVE, if memory serves.
TriGem Imperial GV - 143159 -20030812
http://www.ebay.com/itm/gateway-emachine-mother-board-imperial-gv-20030812-/111025938736?pt=Motherboards&hash=item19d9a96130
Bad photo, but it does have the mouse Zoom In feature.
CMOS jumper and Clear BIOS Password jumper, down by the Front Panel header; is the same as used on the TriGem Imperial GLVE -129504,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07540&lc=en&cc=us&product=83481
Scroll down to Motherboard Layout (Illustration), and Photo; then down to jumper info.
(By the way.........the BIOS chipset is removable, therefore replaceable)
The front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to; is the Front Panel header.
This is PANEL in the illustration. Bottom/Right corner. Uses the same Front Panel pinout, as your Imperial GV uses.
8 pins along in a row.
Starting on the LEFT side going towards the Right;
Pins 1, 2, 3, NO pin 4, 5, 6, 7, and 8.
A) Pin 1 is N/C. Not Connected
(May not even be there for all I know)
B) Pins 2 and 3 are for the Power On LED.
Pin 3 is for the Positive wire.
If the PWR LED is dim when the computer is on, switch the wires around.
C) There is NO Pin 4. At least that is what I make, looking at the Front Panel header pinout. Indicate Pin 1 is N/C, and Pin 4 is N/C.
D) Pins 5 and 6 are for the HarDDrive activity LED light.
Pin 5 is for the Positive ( + ) wire.
If the HDD LED is dim when the Harddrive is active, switch the wires around.
E) Pins 7 and 8 are for the Power On switch.
HOWEVER, since the motherboard photo on HP Support, and Ebay; is as clear as mud; suggest you do this,
Connect your Power On switch to Pins 7 and 8;
OR,
touch across them briefly with a small flat tip screwdriver.
(Power plugged in)
See if that is correct for the Power On switch. What will happen if it isn't? Nothing. Pressing the Power On button just won't turn the computer on; is all.
Turned the Power Supply (Computer) on?
Good. We can assume the rest of the pinout is correct also.
Want to make sure? Easy.
Take an LED bulb (Power On, or HDD), and touch it's two wires to the Power On LED pins, in the Front panel header.
Stays on? Yep. Power On LED pins.
Blinks? Whoops.
Those are the Harddrive activity LED pins.
Just that easy to check it. With using an LED, you won't harm anything even if the pinout is wrong.
Moving on.........
Using the HP Support page, for that TriGem Imperial GLVE motherboard, the Motherboard Layout is the same as the Imperial GV.
(So is photo, 'natch)
Referring to the layout, and photo;
A) Power cables:
Two
20-pin ATX main power cable, and 4-pin ATX +12 Volt power cable.
General example of a 20-pin ATX main power cable, and it's respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
Note* Color of power cable connector does NOT matter.
Can be Whitish, Yellowish, Black, Sea Foam Blue, or Lactating Mammary Gland Pink. (Made the last two up)
Goes to the motherboard connector immediately above PCI slot 1.
Note the LOCK on the side of the power cable, and corresponding TAB on the motherboard connector.
General example of 4-pin ATX +12 Volt power cable, and connector on motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
Power for the Processor
Looking at the motherboard illustration, look at the Northbridge chip; -> Intel 845GL in the middle.
ATX 12V to the left, is where the 4-pin ATX +12 Volt power cable plugs in.
See the aluminum finned Heatsink, sitting on the Northbridge chip?
The whitish/yellowish 4-socket hole square connector, to the Left.
Moving on............
See where it states Primary IDE to the bottom/right in the illustration? Blue IDE connector?
That is where the Harddrive plugs in.
This is a general example of the connector,
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
Note the Locating Lug on the top/middle. This particular style uses two ribs. Some are just a solid block.
The reason I brought it up, is if there is NO Locating Lug on the connector; let me know in a Comment.
I'll tell you how to use the faint Red stripe, on the side of the flat cable; in order to plug it in correctly.
The optical drive (CD/DVD drive) plugs into Secondary IDE.
You can see where a Floppy Drive plugs in.
Above the Processor (CPU) socket to the Right, is where a computer case fan plugs in. PS_FAN.
To the upper Left, is where the Processor fan plugs in.
CPU_FAN
To the left of the ATX Power Connector, (20-pin ATX main power cable; motherboard connector), is the connector for the small audio cable; coming from the optical drive. (CD/DVD drive)
Optical Drive In.
Right next to the round CMOS battery, is the Front Panel USB header.
-> TWO USB ports connect to this header.
(USB)
A 4-pin Peripheral power cable is used for the Harddrive, and Optical Drive.
Misnomered as 'Molex' power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Note the rounded corners. When plugging the power cable in, these rounded corners always go UP.
[Molex was the first maker of the power cable connector.
The name stuck.
Kind of like calling an adjustable open-end wrench a 'Crescent wrench' ]
The motherboard chipset is an Intel 845GV.
This is what Processors (CPU), and Ram Memory are supported,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Pentium_4_chipsets
Single-Core processors.
Use a Socket 478 processor socket.
Intel Pentium 4, Celeron, or Celeron D.
(Celeron D is NOT a dual core processor)
400 to 533MegaHertz Front Side Bus processor support.
(400/533MHz FSB)
DDR Sdram ram memory that is either 266MegaHertz, or 333MHz.
(PC2100 and PC2700, respectively)
2GB's of it.
1GB for EACH ram memory slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 08, 2013 | eMachines Mb, 143159 Imperial_gv 20030812...
I HAVENT GOT A VGA DRIVER FOR MY IBM MOTHERBOARD WITH INTEL CHIPSET I845G
Drivers for Intel D865
Please visit the above link, select the 'Operating System' and 'Type of Download'
Download/save the required drivers (Video: Intel Extreme Graphics Driver for 865 Chipset-Based Intel Desktop Boards) to you system and install them. You may also write the drivers on to a CD for future use.
Hope it helps! Good Luck!
Don't forget to convey your feedback
CreativeTECH
Feb 26, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Ibm d865gkd audio drivers needed?
http://www-947.ibm.com/support/entry/portal/Overview/Software/Software_support_(general)
download here i hope this helpfull, if you think this helpfull please rate very helpfull or helpfull
thanks for using fixya
Jan 20, 2011 | Intel D865GBF Motherboard
My IBM Intel D865GKD Motherboard needs drivers.
Intel 865 Chipset
Link 1
VGA Driver intel 865 series
Part 1
Part 2
Part 3
Part 4
Audio
* I need teh device ID
Apr 10, 2009 | Computers & Internet
Intel chipset 865 gv is ded 1st where i check?
try to change Power ICs near by motherboard power supply connector.but first check CMOS battery...
Feb 23, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Missing sound drivers
Windows XP or other operating systems, only provide generic or standard running drivers.
If you have On-Board sound, you,ll need to go to the manufacturers site, and download all the drivers relating to your motherboard. Also check that you have connected the sound-card and cables correctly. Or if your using a DVD Drive, that you have the lead to connect Drive To Motherboard. ** This is usually a 3 pin plug connector.
Mike @ Compurepair.
Feb 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Sep 27, 2006 | IBM (02R4084) Motherboard
Computers & Internet Logo
1,182 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
