Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Panel reads "water sensor opened"
Spa heater not working, display panel now reads, "water sensor opened"????
  • donschick Mar 05, 2009
    Where is the water sensor located and can I replace or repair it myself?  Where can one purchase a replacement?  Thanks for answering.
    Don S.
  • 3 Answers
I had the same problem. The water sensor is on a pipe running into your pump. It will have a circular clamp around it. Remove the clamp and pull the sensor out of the pipe. The wires should run into your control box. disconnect the wires and replace. My water sensor was part 7790. Not sure if you have the same one. Do an online search. bestbuypoolsupply.com has them for $50 plus 9 for shippng. Hope this helps.
Posted on Mar 12, 2009
  • 125 Answers
Gulfstream pool heater is displaying ,,max heat temperature but pool water is cool.
I have the same issue. Went to tur non today and reads max water temp. Manual reads call for service for that display. Will open panel and check a few connections first.
Mar 31, 2017 | Pool & Spa
Jandy panel reads 89 degrees, sta rite heater panel reads the right temp 78.
Standard 10K ohm sensor appears to be compromised. Replace it.
You have one for water temp, one for air temp, and one for the solar if you have one.
Feb 14, 2014 | Jandy Pool & Spa
LED panel on heater does not light up and water temp reads higher then actual 107/64 degrees on control panel
This is an indication of a bad water sensor. It also tells me that the pressure switch may be bad because if it is working then the light on the panel will light up telling you that the spa water is heating.
Rod
US Parts Center
Oct 20, 2013 | Pentair Pool & Spa
Pentair MasterTemp 400 Stack Flu Sensor Reading Stuck
check gas pressure and for clogged burn tubes unit is overheating
May 12, 2012 | Pentair Mastertemp Pool & Spa Heater Dual...
Heater does not work and the display reads 56 ?
Not 56, but Sb, stuck button, check the back of the control panel for corrosion. We had the same issue and found some moisture had caused a spot of corrosion blocking the contacts. Cleaned it out and worked like a charm.
Sep 26, 2010 | Hayward H Series Pool & Spa Heater 400k...
I have a minimax ch 150 heater and the heater is running but the water coming out is not as hot as it used to be. Though the heater is extremely hot on the outside. Any tips?
Check your SENSOR. With the Minimax ch heater, you might be using an 'IntelliTouch' panel that controls your equipment. If you are, check the reading that the panel says the water temperature is and then check the temperature of the water 'coming out' (spa??) manually with a floating thermometer. When the heater cycles off, check the difference between the 2 numbers. Say the panel says 102 & the thermometer says 95?? - that is a faulty sensor, telling the heater that the water has reached 102, so it cycles off before ever getting hot. If you're not using the IntelliTouch, you will be checking the display panel on the actual heater itself & again the floating thermometer. Now... if the temperature is less than a 4 degree difference you can always calibrate/or have calibrated the heater.
Aug 03, 2010 | Pentair MINIMAX NT TSI IGNITER
Plugged in our EZ Spa for first time - panel shows 'SN'
Open your drain for a moment till you get water or force water into the skimmer. If you have an air lock in the pipes this will stop the spa from working.
Jun 25, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Panel reads HHO-----, no temperature display until activate jets, then shows a temperature drop sometimes down to 65 degrees ,then starts heating upwith jets going
"OH" is an overheat error. In normal function, it is used as a safety shut off if the spa water temperature reaches over 110 degrees in the event of a thermostat failure. But more commonly, (if the water temp hasn't gotten too hot) it indicates that the temp sensor(s) have failed. If you have a digital display on the topside controller of your spa, then it is a circuit board controlled spa pack. Most spa builders use the same control pack manufacturer - Balboa Watergroup. The sensor kit usually consists of 2 probes and wires that plug directly onto the circuit board. Depending on the spa, they could both be located onto the heater manifold, or one on the manifold and one mounted to the tub making direct contact with the water via a thru-wall sensor mount. If I knew the spa manufacturer, I could further assist you. If you replace the sensors, and encounter the same problem... then the circuit board is bad, and usually a costly replacement. The sensors are usually listed as a "BA sensor assy" Hope this helps you,
Dec 24, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
2,274 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
