Question about Hotpoint HSS25GDMWW Side by Side Refrigerator
Motor and compressor work but no cooling
It did work, we moved it to another house and now it does not.
    Problem Solver:
  • 5 Answers
If you tipped the refrig on it side to move it you must leave it unplygged for 24 hrs before plugging in.  Does the fan work?  If not see if something is stopping it.
Posted on Feb 01, 2009
04 sequoia A/C does not cool when car not moving, cools great when car is moving. mechanic said compressor motor was "locked up" and head pressure was high. We replaced with new compressor motor. all...
If the compressor failed ,then the entire system
had to be flushed & the expansion valve replaced
Any shop should know how to fix the system & not
be stumped
I wouldn't deal with them anymore,need a different palce
Sep 09, 2013 | 2004 Toyota Sequoia
Hi. We moved to a house with an integrated Teka A-FC1359 Fridge/Freezer. It was working fine. We switched it off 3 months ago. Now we've swithched it back on but it's not working.
It can be issue with faulty compressor capacitor.From main power outlet the power goes to capacitor beside compressor and from there power goes to compressor motor,then after that all unit works.May be that capacitor got shorted or loose from its actual connection.Or other possibility is faulty power wire of refrigerator.Get the wire checked with continuity tester to confirm its not broken in between.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
What do i need to take off in order to put the thermostate on a Ford Focus 2007?
Hello! Here is procedure to replace the thermostat on your vehicle.....Guru.....Saailer
  1. Thermostat and housing are an assembly
  2. Disconnect battery negative cable from battery and properly isolate to prevent accidental reconnection.
  3. Drain the cooling system.
  4. Raise vehicle.
  5. Remove or disconnect the following:
    Accessory drive belt shield Accessory drive belt Two power steering hose bracket retaining nuts and position the hose and brackets aside. Cooling fan motor and shroud 3 A/C compressor bolts and position the compressor aside Hoses from the thermostat housing
  6. Remove the bolts, the thermostat housing and the thermostat as an assembly.
To install:
NOTE Lubricate the thermostat housing O-ring with clean engine coolant.
  1. Install or connect the following:
    New thermostat/housing assembly and tighten the bolts to 89 inch lbs. (10 Nm) Hoses to the thermostat housing A/C compressor bracket and compressor and tighten the bolts to 18 ft. lbs. (25 Nm) Cooling fan motor and shroud Power steering hose, bracket and tighten the nuts to 89 inch lbs. (10 Nm)
  2. Fill and bleed the cooling system.
  3. Reconnect the negative battery cable.
retailerIdd874f148debugOnfalsecustomerId117788472vehicleId3089401
Sep 11, 2010 | Ford Focus Cars & Trucks
Turn thermostat on, cooling fans kick in, i can feel compressor with my hand moving but no cooling inside freezer or fridg
Hi, you say the fan in the freezer kicks on? You also have a fan located by your compressor and coil which is the condenser fan motor and condenser coil. This fan must also be running when the compressor is on.Make sure that the coil down below is clean on the front of it as it draws air across this coil to keep the internal head pressures down. Check all of these things. The small copper line coming off the compressor, discharge line should be almost hot. The larger of the lines is the suction line and will be very cool, almost condensating . If not, you may have developed a small freon leak which will cause these problems. Make sure that everything I said is working and clean, and if the small motor in the rear bottom is not running, you can get a new one at a appliance parts house and 2 wires will replace it. Do all of this and keep me posted.
Shastalaker7
Jun 15, 2010 | Refrigerators
Moved refrig this morning and now it is not cooling... freezer works great
Hih, Check and see if something has stopped the condenser fan motor down by the compressor from turning. Sometimes this happens in a move.
Also make sure the controls didn't get turned to wrong settings. Make sure evaporator fan motor is working in freezer and that there is no frost building up on the rear panel.
Just some ideas to help you.
lease let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | Admiral 26 cu. ft. Side-By-Side...
Freezer not working properly
Sometimes when movers use dollies to move a frig they will put it underneath the condenser fan motor and bend the housing into the fan blade. If this fan doesn't turn, the compressor will turn off on the heat sensing overload before it has a chance to cool everything inside.
Dec 03, 2008 | Frigidaire FRS3R5EMB Side by Side...
Side by side wirlpool fridge freezer not cooling down
make sure the fan motors are running. there is one near the compressor in the bottom rear and one in the freezer area. also be sure the compressor is running. being it was in storage there could be rust on the motors or possibly a mouse could have chewed through some wires.
Oct 28, 2008 | Whirlpool Refrigerators
Boshe kgu3220 not working
There is a fan motor that blows the cold from the freezer to the refrigerator side. Listen for the inside fan when the compressor is running, and look to see if an adjustable air passage has become shut.
Jul 23, 2008 | Refrigerators
Moved The Fridge, Not cooling
Check the evaporator fan inside the freezer compartment.
Dec 23, 2007 | Amana ABB1927DE Bottom Freezer...
Hotpoint HSS25GDMWW Side by Side Refrigerator Logo
97 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
