Question about Sony FD Trinitron WEGA KV-32FS100 32" TV
"No Signal" When you turn on the TV it states there is no signal. It is hooked up directly to the cable so it is not the way it is hooked up. we recieved this computer for free and we are wondering if this would be something simple to fix or will it be expensive and not worth it?
  • 3 more comments
  • JoAnn Golden Jul 31, 2007
    Sorry not a computer but a tv rather . . .
  • JoAnn Golden Aug 01, 2007
    We have pressed the buttons and that does not seem to work either. We've changed it to Ant/cable and still no picture. WE have done some research and we are lead to believe it might be the tuner wich is what first recieves the signal. Is this expensive? Would it be simpler to just buy a new TV?
  • silverkiss Nov 09, 2007
    My Sony Wega tv is attach to my cable box, however, there is snow and it is saying no signal. We've called our cable carrier and they change the cable box. This worked for about 1 week but it is now doing the same thing with the new cable box. I've tried three different cable boxes but the snow and no signal is still there. My cable carrier thinks it is the barrel on the back of the tv. What do you think?
  • louie_biscot Jan 20, 2009
    I have the same exact problem and its recurring i find if i leave the tv on for a few days it'll randomly fix itself but ti keeps happening sooo Frustrating
  • jnbcols Mar 01, 2009
    same issue..total flatline "no signal" message
    Scholar:
  • 150 Answers
Might need a tuner, I suspect if you arent seeing any snow/static you probably need to press the tv/video button untill you get the ANT input.
Posted on Aug 01, 2007
"No Signal" Problem in Sony TV
Posted on Jun 06, 2008
Which cable outlet do i hook tv to for cable
most RV's have a selector box that takes signals in from all the different sources and directs them to the cable going into the TV. Should be marked "To Tv" or something similar. Then you just select the source as Cable.
Feb 28, 2015 | Keystone 2014 Outback 277RL
My hisense is hooked up but says there is no signal
Using the Hisense remote, enter setup menu fpor TV. Choose SAT/Cable as signal source.
Feb 22, 2015 | Hisense LTDN50K360GUS 50" LED TV...
No tv signal
That outlet does not have cable service, do you?
Nov 12, 2013 | managemylife.com
Dvd connection
Check the connection wire for any internal conductor break. Check it with a multimeter.
Aug 13, 2012 | Sceptre X400BV-FHD 40 in. LCD TV
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
Picture gets fuzzy especially the writting on 2000 Sansui tv
This could be multiple things. If the fuzzy picture is on your regular cable channels and the tv is hooked up directly to the cable then it is a signal issue. Your cable signal is probably too low because it is either split too many times, a splitter went bad, a piece of cable went bad, you have RG-59 cable rather than the much better RG-6 cable. Another solution is if there is a vcr hooked up, the cable jack on the vcr could have gone bad, the vcr power could be on which will cause a fuzzy screen. If you have a vcr try to bypass it and hook directly to tv. If that fixes you problem then it may be the vcr or the wire from the vcr to the tv. If you have no vcr then I recommend buying a cable amplifier and hooking it up. This is a band-aid solution but it could work long term if it's just a matter of weak signal. If that does not fix your problem I would recommend calling a cable professional to evaluate your problem. Could be the line from the pole to your house or any of the wiring in your home.
Jul 10, 2010 | Panasonic CT-32SL15 32" TV
Does not pick up cable satellite signal
Do you have the satelite hooked threu the regular cable input? If so hook it thru one of the video inputs instead; composite video or component video. the picture and sound will be better and you will be by-passing the problem area of your Tv ( the tuner).
Apr 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
HDTV Setup
it wont hurt to run both to the set, they wont interfere with each other
Nov 28, 2007 | Televison & Video
Sony FD Trinitron WEGA KV-32FS100 32" TV Logo
1,410 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
