Question about Brother 925D Serger
925d needle change
How do I release the needles to replace a bent one please.
Sharon
  • 360 Answers
To remove the needle
(1)Turn the main power switch to the OFF position.
(2)Turn the hand wheel counter-clockwise by hand
until the needle is at its highest position.
(3)Loosen the needle set screw with hexagonal
wrench
Reverse order to install new needle.
Click this link to download the users manual for your machine --->click here<---
Please take the time to rate this a Fix Ya solution
Posted on Feb 01, 2009
Neddle hits the plate, how do i fix it ?
check that the needle is fitted correctly
check for bent needle
check for correct needle
May 23, 2015 | Sewing Machines
Threaded right, but will not chain
Are the needles in the correct way
Mar 06, 2015 | Brother 925D Serger
How do I change a needle on a brother 770?
same old way as all machines loosen the screw/clamp and pull it down
Feb 12, 2015 | Brother PE-770 Embroidery Machine
Lowerlooper threading needle for Brother Lock 925D
try
sewingpartsonline.com
premiersewing.com
Apr 06, 2012 | Sewing Machines
What is the needle system for Simplicity 804D serger?
For the both you listed (brother 925d and simplicity 804d) it is a "15x1" which is a standard home needle. Same size the fits almost all home sewing machines. Make sure to put the flat side of the needle to the back.
Let me know if you have any more questions,
Chris
Jun 09, 2010 | Brother 925D Serger
Singer Inspiration 4228 Automatic Threading Problems
The small hook that passes through the eye of the needle is bent or broken. If it is only bent it can be straightened with a small screw driver. If it is broken it will need to be replaced. Most dealers can get this part for you for about $5.00
sewman7
Apr 11, 2009 | Singer Sewing Machines
No manual
google brother 925d user manual and it will take you to the brother site to download the manual i had to do the same thing! good luck its just time consuming to print it off. hope this helps
Sep 01, 2008 | Brother 925D Serger
No stitches 925D.
Probably your looper timing is off. This is common, and just a necessary evil of sergers. Their tolerances are tight.
The operation of creating a serger stitch is a succession of thread grabing and delivering. One looper grabs a thread and delivers it to the needle and so on.
To check this, turn your handwheel slowly and check to see that the upper looper is meeting the lower looper by passing very close to the indented part at the back of the lower looper (indented part is called the scarf, this is where the looper threads form a lock) If not, it's the looper timing. If they seem to meet properly then check your needle. Is your needle up into the needle clamp all the way? Try a new needle. Even a slight bend to the needle will not allow the loopers to meet and grab or deliver thread. You might check the tensions. Thread has to have some resistance in order for the loopers to do their job,
If your looper timing is off, find a sewing repair person to retime the serger. Don't try it yourself or put this repair off. If the loopers go further out of timing, they might hit something and replacement can be costly.
Nov 18, 2007 | Brother 929D Mechanical Sewing Machine
Sewing Machines Logo
210 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
