Question about Durabrand DWT1304 13" TV
Durabrand DWT1304 13 in. Tv
Th Antenna in came out. How d you put it back in and reattach it?
    Novelist:
    Champion:
  • 236 Answers
Most set have the coaxial plug made onto the tune inside the set. When it comes out the tuner will have to be removed and the connector re soldered back to the tuner frame. This can be done most of the time unless the circuit board inside the tuner is damaged. If so the tuner would require replacement. This is a job for an experienced tech. Stargazer
Posted on Aug 16, 2007
SOURCE:
I have a 42panasonic plasma tv model#th-42pwd7 it has no cable antenna terminal in the back of the tv but it has rgb terminals i have a converter box and x box360 how can i get a antenna tv signal
Its a Progressive Wide Plasma Display. It wont have a built in Turner. So you will not be able to connect antenna to the TV.You have to use a set top box or cable box and connect its output t the TV.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Televison & Video
I can't get a signal because this tv don't have cable antenna terminal the tv has rgb terminal. I don't know what to do?
RGB is for a computer screen display signal and has nothing to do with TV display of channels. You must have a Component hook up, it is a yellow cable, a red and a white one. Yellow is video signal, the red and white are sound.
Sep 12, 2016 | Panasonic TH-42PWD7UY 42 in. EDTV-Ready...
Reattach keyboard key
If the tiny plastic hinges are still attached to the keyboard then place th W key over these hinges align it with the other keys and press down on the W key until it clicks onto these hinges.
Jan 09, 2013 | ASUS K73SV-DH51 Laptop
I have a Kenwood TH-78A. The nut holding the antenna barrel in place worked its way loose, causing the soldered connection to break. i can't determine where the wire from the barrel needs to be...
I have a schematic diagram of your unit. There are lots of pictures for you to follow on how to re-soldered your device.
Please just click HERE so that you can be in the right page.
I hope you find it very helpful.
Aug 08, 2011 | Kenwood PB-18,...
Durabrand 13' DU1301 TV problem: I can barely see the picture or hear anything because of intermittant snow. Sometimes the picture will roll as if we are back in the 70s. When I turned the tv on its...
Hello
The fault you describes is due to low signal strength. If tuner of the said TV is faulty, this type of snow interference will occur too. Just check for good firm connection to its antenna terminal. If it is Ok, check the continuity of the cable used with antenna. Check the orientation of yagi antenna if used outside. If all are OK, and nothing help you, just replace its tuner with same type and number. Tuner is a small metal box type component can be seen soldered directly to the main printed circuit board inside. Usullay, its one terminal will come out as antenna IN of the TV, to which you connects the external antenna or cable. You must have a concept of soldering and desoldering to replace it, and must have a knoledge in electronics too. OK.
Jul 29, 2011 | Durabrand DU1301 TV
My Durabrand dwt1304 was hooked up to cable. I now have relocated the TV into my workshop and am attempting to hook it up to a digital converter and an antenna. Turning the TV on, I am getting a...
I suggest to go back to the menu and make sure in the connection or signal type to select antenna.. Since you had it hooked up to cable it may not have been selected to go back to antenna. Hope this helps you out.
Feb 04, 2011 | Durabrand DWT1304 13" TV
Where do you plug the antenna cable into a 50" pioneer Pop-505PG Plasma TV
on the back of the viera in the middle is all the jacks, at one end is a standard cable tv/antenna jack...just screw the cable into it, and then have your tv scan for channels.
'you should be good to go after that.
Dec 18, 2010 | Panasonic Viera TH-50PZ85U Plasma TV
The remote pad stop unlocking and locking doors. not recieving signal
there was a recall on these units for the antenna. Unplug the antenna on your windshield, let it sit for 5 minutes then plug it back in. You will need to contact your authorized dealer to replace it under warranty if you are the original owner of the system.
Aug 02, 2010 | 791XV The 791XV is a 2-way Security and...
Have a durabrand tv im using a universal remote i some how have the following on my screen there are number 2 in each cor ner on top it reads as follows 050-0.11 271 in th left of th screen where it reads...
you have activated picture in picture.I was able to simply turn the tv off using the power button on front and turn it back on again and it was ok.
Mar 11, 2010 | Durabrand DWT1304 13" TV
Durabrand DWT1304 13" TV Logo
63 people viewed this question
Top Durabrand Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
