Question about Maytag Atlantis MDE7400AY Electric Dryer
Dryer runs, but does not heat
I have already replaced the heating unit, what do you suggest?
Thanks
  • pearcevinton Feb 01, 2009
    Thanks Information was greatly appreciated!!!!
    Dave
  • integac Feb 03, 2009
    I have been told that my centrifugal switch in my motor has gone bad and there is no power going to the heating element. Before this problem started, it got really hot on top of the dryer. I was wondering what the root cause would have been to make this issue possible.
    Sergeant:
  • 311 Answers
Do you have a volt meter ,and the wiring diagram for your dryer.if so we can fix this by email.your going to disconnect one side of the element[there are two wires that end up feeding the element electricity,each side is a curcit].and isolate that side with tape,but so you can still get a volt meter probe on it.now if you set your meter to AC volts and scrap one of the probes into ground[the body of the dryer,anywhere]so it gets past the paint into metal.now take the other probe with the dryer on in heat mode and started.and now touch the wire you have disconnected and then the other side that's still connected to the element.the side that did not have 110 volts is the side of the circuit that has something not working.so using your wiring diagram,or if you can see visually you still keep one probe to ground[any where] and go back to the next part,until you find where the voltage has stoped.and replace that part.almost all parts are showned closed on the diagram unless other wise shown.so another way to check a part to see if it is closed[meaning,complete or electricity can pass thru it]is to set your volt meter to ohms setting.in this setting if you put the two probes together the meter will go to zero[digital meter] and when you take them apart they will show 1 or the needle will go all the way back,if non digital.the reading you get when you put the probes together is the reading you would get from a part if it is good,[its called continuity]but one side of the wires must be disconnected so not get false readings.the thermostats and fuses will have countinuity[also your new element is a good example of something that has contunity[remember one wire must be disconnected.i hope this helps ill be there if you need advise God bless ,tom
Posted on Feb 01, 2009
  • Thomas Malailua
    Thomas Malailua Feb 03, 2009
    dear integac,im not sure what's going on with your dryer ,no heat?high heat ,i would love to help !can you give me better details?
What do error codes FDL and R11 indicate?
Hello Lidia, thank you for your inquiry!
Based off the information you have provided your Frigidaire dryer is not heating and displaying error codes "FDL" and "RL". I am showing that the codes you have provided are not valid error codes. I would recommend performing a reset on your dryer and you can do that by disconnecting power from it for at least ten minutes. I see that you have already replaced the igniter; however, if you continue to have issues with the error codes I would suggest having a professional technician out. This will help you avoid any further unnecessary part purchases. Hopefully this information is helpful to some degree. -Matt
Feb 15, 2016 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
DRYER WHIRLPOOL LER 6646 SERNO. MS23065579 IT RUNS BUT NO HEAT OUTPUT TO DRY CLOTHES
I would suggest replacing the heating element these are usually always the culprit and pretty much anybody can replace them.
Check here for parts for you model number, they also have good diagrams.
Hope this helps, thanks.
May 12, 2011 | Dryers
Neptune 5500 gas dryer runs but no heat. I cleaned out the exhaust ducts already.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Maytag Neptune MDE5500AY Electric Dryer
No heat
If the unit is running but you are gettin no heat at all, you're heating element needs to be replaced.
Hope this helps...
Sep 14, 2009 | Kenmore 60172 Electric Commercial Dryer
Dryer won't heat. Already replaced heating element.
Undoubtedly since you have replaced the heating element the problem is actually the thermal sensor overheat unit has burnedout. It is a very small unit mounted inside on the back of the dryer someplace and has two wires clipped to it. If you have a test meter you can put it on the ohms scale and connect the ohmmeter leads across the terminals after you remove at least 1 wire from the sensor. It should read very low ohms...maybe less than 4 ohms. If it has a high reading...maybe 10K or 10,000 ohms then it is burned out and will need to be replaced....it is something like a fuse but opens up from temperature instead of current. Replacing the unit will make the dryer run....unless...you could have a bad door switch...but I doubt it. Probably your dryer is or was clogged up with lint and the vent pipe to the outside was also clogged up allowing the dryer to overheat and burning up the unit I mention above. Be sure to clean good everything before putting it back together. I recommend using a leaf blower inside the dryer and also blowing and brushing out the vent pipe to the outside...may prevent your house from burning down.
Aug 21, 2009 | Whirlpool Dryers
Whirlpool dryer WED5530SQ0, heats but does not run
So,. basically your drum doesnt turn. SO your getting heat still even though the drum isnt turning. Is this right? Sounds strange??? Do you hear any humming noise when you push the start button? I need to know a little more about the problem because im kinda confused as how you decribed the problem. Iv never seen a dryer heat but the drum not spinning. especially your model dryer. Its electric heat right? because if the drum doesnt spin, maybe your motor is bad. and if your motor is bad, then your heating element wont heat up because the centrifical switch in the motor is not switching to complete the circuit to the heating element. So this is why im confused when you said" Dryer heats when knob turned but when "push button" pressed, drum doesnt run." Because your belt wraps around the motor pully and the motor is what makes the drum turn. Like i said, i never seen this model dryer heat with out the motor operating. So if you can give me some more info, ill do my best to help you out....Thanks!!!!
Jul 30, 2009 | Whirlpool WED5500S Electric Dryer
Dryer runs too hot.
Remove power from the unit. You want to use a multi-meter set on an ohms scale. Remove the wires from each terminal at the heating element. Check resistance to ground at the heater by putting one meter lead to the case of the heater, and the other meter lead to each terminal at the heater. It sounds as though your element has gone bad and is shorted to the case. The resistance should be infinite. If you read any resistance from the element to the case, replace the heating element. The no heat setting should be exactly that....no heat.
May 22, 2009 | Dryers
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Kenmore dryer.
chech your exhaust hose from rear of dryer ,,if can disconnect and run and see how long it heats up for ,if you reconnect hose to back of dryer and shuts off quickly pretty obvious ,, bad air flow , clean out exhaust
Dec 31, 2008 | Dryers
No heat Whirlpool dryer
when you turn on the dryer does the ignitor glow if it does replace the coils if not check the thermal fuse
Dec 19, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
113 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
