Question about Samsung DVD-V3500 DVD Player/VCR
Samsung DVD-CM420 after some time audio cuts off
I opened it up and Q10 on the board marked DVD-CM350/XAA gets very hot, I replaced it still no luck.  it veries on how long the audio stays on I would guess about 30 minuts then the "set up" is displayed. thanks for any help. tom
  • 4,234 Answers
I don't have the service manual on this so a few more details will help. What is Q10 marked? It sounds to me like the output transistor is heating up because of DC or because of harmonic oscillations. Without an oscilloscope, this may be difficult to locate. Update this with the markings and I'll research this for you.
Thanks,
Dan
Posted on Feb 01, 2009
I get the nf halfway through the cycle. ALWAYS with 26 minutes remaining after opening and shutting the door several times and can get it to resume the cycle.
SAMSUNG WF331ANW/XAA TROUBLE SHOOTING GUIDE ...
www.manualslib.com > ... > Washer > WF331ANW/XAA
View and Download Samsung WF331ANW/XAA Trouble Shooting Guide technical information online. 3.7 cu. ft. High Efficiency VRT Steam Front Load Washer (Neat White). ... DC68-02834A-03_EN. 2011-09-28. 4:00:29. Previous page ... SamsungWF337AAG · Samsung WF338AAB · Samsung WF331ANR/XAA · Samsung ...
Support - Washers WF431ABP/XAA ' Samsung Washers ...
www.samsung.com > ... > Washers
Samsung Electronics
Dec 08, 2015 | Samsung WF338AAB 4.0 cu. ft. Front Load...
Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 31, 2017 | Televison & Video
Samsung hls4676sx/xaa sound cut off and speaker cracks
Sounds like an analog board problem--IIRC this has the audio amp on it.
Mar 05, 2014 | Samsung HLS4676S Television
I am looking for a manual for a Samsung DVD Model number P241/XAA-B DCan you direct me to where I can get one?
you can download direct on
http://downloadcenter.samsung.com/content/UM/200312/20031230162616265_P241-XAA.pdf
Is important for people who share their knowledge, know your comments.
If the answer is helpful, rate my answers
Sep 19, 2011 | Samsung Cameras
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
DVD disk tray will not open at all
had the same problem the mechanism for the door opener is faulty.........waited for 2 months to be finally told by samsung part is no longer available......wonderful back up service isnt it. Luck have it I had an extended warranty and getting it replaced with a LG combo
Jun 03, 2009 | Samsung DVD-VR320 DVD Recorder/VCR
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
I did not get a manuel with my samsung sc-dc164/xaa
u will every things concerning your camcorder throught this links - manuel, drivers, software & firmware too
http://www.samsung.com/uk/support/download/supportGlobalDownMain.do?group=&type=&subtype=&model_cd=&dType=G&vType=
type scdc164 as model code search.
Dec 26, 2007 | Samsung SC-DC164 DVD Camcorder
Samsung DVD-V3500 DVD Player/VCR Logo
213 people viewed this question
Henry  Thomas
Henry Thomas
