Question about Averatec 3200 Notebook
USB PORTS I have a 5400 series Averatec Laptop, the USB ports are dead. They won't work when put a memory stick. There's 4 ports on this laptop none of them works. Can you please help me?
  • Anonymous Mar 25, 2014
    usb port does not recognise any devices i.e. mouse, stick.
    Scholar:
    New Friend:
  • 98 Answers
Your USB ports on your computer are plug and play. If you have issues with your USB port, it is port related, driver related or device related. The following solutions will help you identify the problem to resolve your USB port issues.
To Identify a Working USB Port
Begin troubleshooting your USB ports by checking Device Manager to see if your USB ports or hubs are working properly.
  1. Click the Start button. ClickControl Panel.
  2. ClickSystem and Maintenance.
  3. ClickDevice Manager.
  4. Double-clickUniversal Serial Bus controllersand check to see if all your USB ports, hubs and controllers are functioning correctly. Any devices not functioning will have a yellow exclamation mark in front of them.
  5. If Device Manager shows any USB ports, hubs or controllers are not functioning, check for updated drivers.
To Update the USB Port Driver
An out-of-date BIOS driver can create issues with your system recognizing the USB port.
  • Watch a Video on Steps to Update Bios on Your Computer.
    1. When the update process is complete, your computer will restart again to load the operating system with the new driver version installed.
Posted on Jan 05, 2015
  • 36 Answers
Does your usb mem stick have any light indicators? if yes , whenever you put you usb stick, does it light? if it lights are USB ports is still ok,  You just have to reformat or partition you USB stick.
(you can also try other devices like usb mouse or any usb devices that lights up when you connect it)
if there are no lights if you plug, or no indication that a power goes to your stick, its possible that your usb your are busted. if this is the case, if your laptop has a PCMIA slot, you can find a pcmia USB card, if you dont have. your only option is replace the  motherboard.
Posted on Feb 02, 2009
I cannot power on acer 4520,instantly it auto off itself
reset the memory,with the laptop battery out and the adapter unplugged locate the memory access plate on the bottom,take the screw out and then carefully pry up the plate to access the memory,to take the memory out you will have to push out the plastic locking tabs located on each side of the memory stick at the same time until the memory stick springs up and then slide out away from the connector till the bottom of the stick is clear.If you have 2 sticks take them out and then install the sticks one at a time.If that doesnt work then try to narrow it down by unplugging the cd rom,hard drive,etc.If none of these work then you most ;ikely have a short somewhere ,inspect all ports and make sure none of the pins are touching especially the usb ports and the pcmcia slots,look for damage anywhere that might indicate it was dropped or fell.If the motherboard is at fault you will have to have it serviced by a qualified technician.good luck
Mar 04, 2011 | Computers & Internet
I used this memory stick on my old PC at home and it was wrking okay. When i put it into the usb port it showed up ad removable E. Now I have upgraded my pc to a laptop it doesent recognise the stick....
I assume when you say "memory stick" that you mean a USB memory stick rather than a Sony memory stick.
You should try it in another USB port (if ther is one on your laptop). If that doesn't work, then try it in another PC - if it doesn't work in another PC either, then it is likely that the memory device is at fault, otherwise. If it works fine on another PC, then it is likely that it is the USB port on your new laptop that is at fault in some manner.
If you have another USB device you can use (anything will do - a mouse, webcam, etc), try it in the port you tried the memory stick in. If nothing happens, then in all likeleyhood, the USB port is at fault. If the other device works, then it is probably the USB memory device that is faulty.
If the device works in another PC, try reformatting it as FAT file system on that PC, and see if you can then see it in your new laptop.
Oct 21, 2010 | Office Equipment & Supplies
My Averatec laptop's screen is going out and if
Seems to me the inverter is gone if you replace the inverter it will work like a charm
Dec 31, 2009 | Averatec 3200 Notebook
Can barely see windows. why? when it powers up, screen remains too dark to see. averatec 5400 series laptop
Could be the brightness settings on the laptop. Did you try increasing the brightness using the Fn keys? If that does not work you may need to have the laptop worked on.
Jul 22, 2009 | Computers & Internet
Blank screen
Look very closely at the screen when its on, see if you can see a faint image in which case the ccfl tube in the screen will be dead. Also try the laptop on an external monitor.
Otherwise if you know what your doing, remove the battery, hard drive, optical drive, all but one stick of ram, modem/wireless card and try again. There is a small chance it will be the cpu or motherboard.
Jun 16, 2009 | Averatec 3200 Notebook
Does the hard drive interchange with other Averatecs?
Swapping hard drives only works if the hard drive is swapped into an identical computer with the same device configurations, CPU and RAM etc.
The best way to copy or recover data from a working hard drive is to insert the hard drive into an USB hard drive adapter and plug it into a working computer's USB port. You should see this drive as an external hard drive and you can then copy or backup the data onto the computers hard drive or USB memory stick etc.
May 13, 2009 | Averatec 3150H Ultra Thin Notebook PC With...
I have a 5400 Series Averatec Notebook. it will not stay on.
first of all try a virus checker through it hope this helps regards Jim
May 05, 2009 | Averatec Computers & Internet
My averatec series 3200 notebook cant detect my usb device
The flash disk could be faulty, especially when it draws too much power, and this will cause the USB ports to shut down and the other USB devices won't work until the faulty device is removed.
Mar 11, 2009 | Averatec 3200 Notebook
How do I use the 4 in 1 card reader on my Averatec 2575
as soon as you inser a card you shoud be able to see the specific media: Memory Stick , MultiMediaCard , SD Memory Card , Memory Stick Pro
Jan 06, 2009 | Averatec 12.1 W Wxga Tft Amd TL-64 PC...
Usb ports not picking up memory stick
Is it just Memory Stick, or everything that you plug into USB?
Try following:
  1. plug in other USB device into ports
  2. if it does not detect any USB device on any port on your computer
  3. if both front and back USB do not work it may be taht USB is turned off in BIOS, or USB driver is corupted
  4. If you have front USBs and they just do not work there is wire connecting them to the motherboard since it may be loose, if connection is OK than they are dead.
  5. If just back USB do not work than they are dead>
Jan 30, 2008 | Computers & Internet
Averatec 3200 Notebook Logo
183 people viewed this question
Top Averatec Computers & Internet Experts
Avishek Samaddar
Avishek Samaddar
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
