Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Error message and not cooling Kenmore Bottom Freezer
My Kenmore Refrigerator has started making a loud noice and all of a sudden we got the error message "FF". Soon after, it stopped cooling altogether. The warranty ran out 2 weeks ago and I am frustated and stuick with a $1500 broken machine. Any ideas on how to fix?
  • fperrino Jul 18, 2008
    Our fridge is 14 months old. Was working fine then heard a louder hum than usual. came down this morning to Er FF on the screen. since then the fridge is warming. Sears can't come till next week and of course we are out of warranty. since reading all these complaints is there any recourse against Sears that we can take as a group. TOO MANY WITH SAME PROBLEM. My fridge was $2000 and I do not have the money for a costly repair.
  • 183 Answers
First if you have not already complety defrost freezer, if this does not resolve check the defrost heaters are ok if not replace, if they are then the fault is the defrost sensor. Regars Advisor
Posted on Aug 23, 2007
SOURCE:
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore model7957160 error code erff
ER FF is a Error Message that your Freezer Fan is not working properly, W10128551 Evaporator Fan Motor The problem could be your=> 2169142 Fan Blade has become damaged either by ice or loose fan motor mounts. Someone will need to unplug and remove the rear panel of freezer to observe just what has taken place, Thanks Sea Breeze
Feb 17, 2012 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
The freezer quit running, it was making a loud humming noice before going out. Model 45041, 55041.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 11, 2010 | Kenmore Refrigerators
Our kenmore elite bottom freezer is making a loud humming noise. It shuts off when door is open..and continues when door is shut. Temperatures are fine, no error message, it rarely stops..like it is trying...
Turned off the fridge, emptied the Freezer, used a blow dryer for 20-30 minutes, to melt ice that had built up in vents at rear of freezer.
Cleaned the freezer and reloaded...no hum..at least for now.
Sep 13, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message ER FF - refrigerator is not cooling as a result
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 19, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer working fine but refrigerator not cooling
Do you have the ER DH error message showing? If so, it is a failed senser, an $11.99 part that many of us are having trouble with.
May 18, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Error message er if
Hi. Error FF is your Fresh Food Fan. Otherwords, the evaporator fan motor has failed. You should replace the motor and motherboard. You may get by just replacing the motor. Sears doesn't manufacture the refrigerator. They just pay extra to have Kenmore put on it. Its the manufacturer that needs to back their equipment. If you bought it from Lowes, you can't hold Lowes responsible for the ongoing issue. They sell the same refrigerator. Anytime this model refrigerator displays an Error code, unplug it for 5 miniutes and replug it. Sometimes it was a computer misfuction. Good luck! Mack
Dec 28, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Error Message ER FF
The refrigerator has noticed the freezer fan is not responding. Need to replace the fan motor. Also called evaporator fan motor.
Oct 09, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
76 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
