Question about Car Audio & Video
Wiring hardness I need to know what wire goes to what
    President:
  • 1,990 Answers
Check out Schoche.com For your Wiring Harness. They are Available at Wal-Mart also. Please Rate My Response! Thanks!
Posted on Feb 01, 2009
Maytag Refrigerator hooking up a 3 in 1 hard start to it
I would advise against installing a hard start device unless it is the only option. Most compressors have a run capacitor and if not wired right the compressor could be damaged. You should be able to obtain the correct start device from an appliance parts store.
Sep 26, 2014 | Refrigerators
2000 pontiac grand am gt radio wiring harness cut need to know how to hard wire in
most of these car the plug is simply a plug for convieince you dont need it to hard wire it you simply match up the colors most of them will be the same and then if there are any left over you should be able to do process of elimination hope this helps
Feb 22, 2014 | 2000 Pontiac Grand Am GT
Emerson Motor model T55CXCAS-1179 230 volt
There should be a wiring diagram sticker on the motor. If not, let me know at questions@oskopoolnspa.com
Jun 03, 2013 | Emerson Pool & Spa
Need to know which wire goes to which "post" on Monster iBeats earbuds.
The insulated wire going to the pos post The bear wire to neg post. Hope this helps
Mar 13, 2013 | Audio Players & Recorders
I have a holmes desk fan i need to know how to wire the moter uip
Check the ohm reading across pairs of wires.
Buy cheap multimeter at home world, install battery, set to read ohms : upside down horseshoe is ohms.
You have a non reversing 110volt motor.
One pair of wires goes goes to start winding, for starting the motor spinning, and these wires will have higher ohm reading.
Other pair of wires goes to run winding, that keeps fan at motor speed.
http://waterheatertimer.org/images/Motor-wiring-500.jpg
http://waterheatertimer.org/Color-codewire2.html
Oct 02, 2012 | Holmes Products Dryers
I JUST PURCHASED THIS AMP AND THERE IS NO WIRING DIGRAM WIYH IT.I NEED TO KNOW HOW TO WIRE THE POWER THERE ARE THREE WIRES RED,BLACK AND BLUE
Red goes to your battery, black gets grounded to the vehicle frame, and the blue wire is the remote turn on wire from the radio. There should be 3 power terminals together. The red wire goes to power or (+), the black wire goes to GRD or (-), and the blue wire goes to remote (usually between both the power and ground terminals). hope this helps
Aug 26, 2011 | Car Audio & Video
Need to wire motion sensor to light, have three wire(red, black & white), need to know how to hookup wires? my model no. is :-heath zenith sl-5318-bz-a
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
Feb 22, 2010 | Heath Zenith SL5316WHB Replacement...
NEED KNOW WHAT OLD COLURS OF WIRE THAT GOES WITH
black or red is usually "hot" (+) . green is ground. power antennae is blue.
speaker wires : stripes on the wire is usually "=". solid color wire is "+"
p.s. the wire with the fuse block is considered the positive side +
Dec 04, 2009 | Car Audio & Video
Schematic missing - need to know which cond unit
Black wire goes to contactor. On your capacitor the brown wire goes on one side the blue and the other wire from your contactor goes on the other sideof the capacitor. Russ
Aug 07, 2009 | Heating & Cooling
Car Audio & Video Logo
51 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
