Question about HP Pavilion dv1000 Notebook
Powering on laptop without Hard drive
I'm trying to check this laptop to see if the screen was fixed properly but without a hard drive I was wondering if there will show any signs of it getting power.
  • 38 Answers
Without a harddrive it'll still boot the bios and will probably give you an error about the missing harddrive. You'll see text on the screen so you'll at least know if the screen is working.
Posted on Feb 01, 2009
My Lenovo laptop will not boot up right. It just
Does the hard drive appear in the system list in the bios?Have you tried booting without the battery inserted or resetting the laptop?
1 remove the battery
2 test
3 remove power and hold down the power button 30 secs
4 reseat RAM and check the hard drive is connected properly if not in a caddy,reconnect power and test
5 Research system recovery options.It may be that the hard drive is faulty if the system will not recover.
Aug 31, 2014 | Computers & Internet
My laptop screen is black
Here are Few steps which can use to trouble shoot your laptop no display problem.
1. Connect a VGA
cable for external monitor and check if you can see any display on External Monitor.
2.Take out your RAM and Clean it with Pencil Eraser and Put it back. If Possible try with different RAM,
3. Remove your Hard Drive and Try switching on Laptop without the Hard Drive.
4. Make sure that you are using proper Adapter with proper Voltage.
The Above S
Aug 10, 2012 | Computers & Internet
My son broke the screen on his laptop two years ago and I finally replaced the screen. Now he cannot remember the hard drive password for the computer. I am wondering if there is a way to reset this...
Reset the bios by disconnecting the biosbattery (leave it out for 5 mins), this will clear the installed passwords from the bios. Is inside your laptop on the motherboard, probably in a hard to reach place, but that is the most simple way to do it.
Jul 02, 2011 | Western Digital WD2500BEVS Scorpio 250 GB...
E 68 error....will transfer cable help fix it?
The E68 is a weird error. Its normally from a hard drive failure. The underground xbox 360 scene says
THe E68 is a Hard Drive Error. The Hard drive is not properly configured: It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it.
If the xbox can play without the hard drive then this error can be caused by a problem with the fans that make them draw too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices.
If its the hard drive or your console causing the problems contact Microsoft they will probably fix your hard drive and maybe recover your game saves. On the newest games that info is stored on xbox live.
May 08, 2010 | Microsoft Xbox 360 Hard Drive (20GB)
Powers up then shuts down after a couple of seconds.
Apparently you damaged an internal component.
Your BIOS program performs a POST (Power On Self Test) on each of your computer's devices before it will allow the operating system to boot up. The POST protects your computer from damage to more devices if it runs into a fatal error with one.
I suspect that your hard drive may have been damaged. Hard drive is not the first thing checked, which would account for the few seconds that the POST runs. And, hard drives are easily damaged.
SInce your POST shut down your computer so early, it's hard to tell what else might have been damaged, but I would think it would be worth replacing the hard drive and trying to boot the computer up again.
Good luck with it!!
Oct 06, 2009 | Acer Aspire 5315 Notebook
No power
Sounds like a motherboard issue, BUT first try fixing it with a few basics like:
reseating / swapping the memory
removing the hard drive and then powering up the machine.
Try those two first and then report back.
Jun 13, 2009 | Gateway MX8711 Notebook
Wont turn on
Hello, It looks like a dead hard drive... To check your hard drive and see if you can repair it yourself, reboot your computer press simultaneously the "cmd" and "s" keys at startup if you see a black screen with white text, type: fsck -f and hit enter this does a "file system check", when finnished, type "reboot" and press enter. If nothing better happens, you'll certainly have to brinng it to an Apple Authorized Center Best regards
Jun 10, 2009 | Apple MacBook Air
Laptop hp pavillion ze4300
Probably bad memory or loose CPU module. First try removing and resetting CPU. You'll need to remove Keyboard, Palmrest, and heatsink and shield beneath Keyboard. You'll need a small Phillips screwdriver to remove screws and small standard size screwdriver to loosen screw holding CPU. After removal/reset, put everything back together and try powering back on. If still same problem, replace memory located on bottom of LT located behind door. Also, you may have a memory module located under Keyboard next to CPU that may be bad.
Jan 06, 2008 | HP Pavilion ze4300 Notebook
White screen
you do not get any sounds right?  If no, you need a  new hard drive.  There is no magic fix for a white screen.  Either your hard drive is corrupted..  if no sound it's your hard drive.  If there's is sound it could be your lcd connector.   As a matter of fact it could be your hard drive cable.  At your own risk feel free to open up the mysterious unit and make sure the big metal rectangular prism in there is properly connected.
Sep 30, 2007 | Magellan RoadMate 700 GPS Receiver
HP Pavilion dv1000 Notebook Logo
67 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
