Question about Texas Instruments TI-84 Plus Calculator
Calculatior DIED i was working on a calculator packet for math class when the teacher told us to press 2nd down so i pressed 2nd and held the down arrow and suddenly my display dissapeared! I checked teh batteries and added new ones but the display will only come up for a second and then dissapear.
    Problem Solver:
  • 12 Answers
2nd up until contrast is at a comfortable brightness
Posted on Feb 16, 2009
How do I take the hyperbolic tangent of a value
You'll find the hyperbolic functions in the MATH/Hyperbolic menu, available by pressing 2ND [MATH]. Alternatively, you can simply type in tanh(, enter the value, ), and ENTER.
For example, to compute tanh(1), press 2ND MATH, down-arrow eleven times, ENTER, 3, ENTER, 1, )(, ENTER.
Or t, ALPHA, a, ALPHA, n, ALPHA, h, (, 1, ), ENTER.
If the calculator gives the answer as "tanh(1)", convert it to a numerical value by pressing diamond, ENTER.
Mar 04, 2011 | Texas Instruments TI-89 Calculator
I've replaced the 4 batteries in the back of my calculator, but it still doesn't turn on. I have quite a few TI-83 calculators with this problem. (I'm a math teacher.)
TI calculators have an annoying habit of dimming the screen when the batteries are changed so that it appears as if the calculator isn't turning on. Turn the calculator on (or at least press the ON key). Press and release the 2ND key. Press and hold the Up-arrow key for a few seconds and see whether the screen becomes legible.
If this doesn't do it, please reply to this post and we'll go on from there.
Dec 09, 2010 | Texas Instruments TI-83 Plus Calculator
TI-86 - how do i change a decimal to a fraction?
Use the >Frac command from the MATH MISC menu.
Press 2nd [MATH] to bring up the MATH menu, Press F5 for MISC. Press MORE for the second page. Press F1 to select >Frac.
Nov 18, 2010 | Texas Instruments TI-86 Calculator
My TI-84 Plus won't graph two functions at once. Only one equal sign highlights. My math teacher doesn't even know what to do and I really need two functions to show on one graph.
Turn the satistical plots OFF
Press [2nd][Y=] (STATPLOT). Select or enter 4: to execute the command [PlotsOff] [ENTER]
Clear the lists (statistical lists)
Press [2nd][0] (Catalog]. Press [PGRM] C. The cursor jumps to the first command in catalog that starts with C (The greek letters in names do not matter). Scroll down a bit to reach the command [ClrAllLists]. Select it and press [ENTER].
Try your graphs again.
If you still have problems, just reset the RAM:
Press [2nd][+] (MEM). Press 7 to select [Reset] then [1:All Ram][2:Reset]. Press [Clear] to erase the Ram Cleard message.
Now you should be able to draw the graphs.
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Texas Instruments TI-84 Plus Calculator
My calculator turnd on, but when I press 1,2,3... nothing happens. I can press apps, math, prgm...and they work. What's wrong?
Need to set your brightness setting . Press 2nd and the up or down arrow key this should darken the curser and the display to where you can see it .
Oct 08, 2009 | Texas Instruments TI-83 Plus Calculator
All of my apps, gone !
Please do not dislike your math teacher, for your own sake: You will not learn much from someone whom you dislike. Now Relax.
All the applications that were preloaded in your calculator are available to download freely from http://education.ti.com Use the tab Download--> Apps and software. Then select software for the TI83/TI84 Family. While you are at the site download the TI Connect, if yoy do not have it already. The link follows.
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window.Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is ready to communicate with the computer.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable (USB or TIsilver cable), Select Port (USB1) and Click OK..
If you are lucky and it works, you can reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer. To install an application already downloaded to you computer, drag it to the main window of TI Connect and drop it. Keep installing, the appilcations you want.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the Apps on a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][C:Apps]. A list of Apps appears. Scroll down the list. If you want to transmit un app you press [ENTER] when the arrow reaches its line. Once an app is selected , a small square appears on the left. After the selection, Hit transmit. I suggest you transfer Apps, one after the other. Avoid selecting them all and send them all at one go.
Hope it helps
Oct 01, 2009 | Texas Instruments TI-84 Plus Silver...
My daughter's math teacher cleared her ti-84 plus silver edition calculator for the algebra regents but never put the software back in. how do I get her graphing calculator back to the way it was...
My screen was frozen and I needed to do a manual reset. If you take out 1 battery from the back....hold the "del" key down and reinsert the battery while holding it down....it will reload the programming into the calc
Aug 16, 2008 | Texas Instruments TI-84 Plus Silver...
Ti 84
I have a TI-84 Silver Plus and the same thing happened to me. I was desperate to fix it because I had math finals the next day. So I pressed the blue '2nd' button, and held down the down arrow and it worked! If that doesn't work, go see if it can be repaired somewhere!
Jan 11, 2008 | Texas Instruments Office Equipment &...
Help!!a Black screen appears when I turn on my calculator
http://oakroadsystems.com/math/ti83oops.htm#Lines
ok guys, after about 10 years of not using my ti-83, i put the new batteries in and got the black screen you are all talking about.. came to this site.. saw no solutions.. kept looking.
I've fixed my calculator, but my brain won't tell me exactly how.. but i followed those instructions..
you CAN see what is on your screen if you tilt it under the light ... just fiddle around until you can see faint writing on your screen under the black.
Press window
i have these entries in my calculator
xmin=-10
xmax=10
xscl=1
ymin=-10
ymax=10
yscl=5
xres=2
then go and press second and the down arrow to lighten your screen. it should work.
Nov 01, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-84 Plus Calculator Logo
134 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
