Question about Sony HVR-M10U HDV Compact Player/Recorder Camcorder
Samsung VP D371 faulty firewire connection?
When i connect camcorder to laptop via firewire nothing happens. whenchecking the device manager there is an exclamation mark but a code 10error message saying the device cannot start. the device is displayedas 61883 Class Bus Device. any suggestions? I get a code 10 error and and exclamation mark next to 61883 class device in hardware manager when I try to connect my Sony HVR-M10U Compact Player/recorder to my HP Laptop ZD 7000A with Win Xp and all the latest service packs installed - what's up? It never did this before.
  • 473 Answers
SOURCE: sony dcr-dvd201 unable to connect via usb to xp pro computer
I've learned my lesson here. Firewire and maybe WinDV is what I setup all the time now.
Posted on Sep 14, 2005
SOURCE: My Sony DVD RW stopped working.. with error messages.
Hey its really worked Thanks Nitesh Oza
Posted on Aug 20, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Connecting Camcorder to PC
Windows Movie Maker won't detect the camera but Video Edit Magic should.
Posted on Aug 30, 2008
johnny5846
  • 379 Answers
SOURCE: Problems with Sony DCR-TRV350 Camcorder and Vista
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DCRTRV350&LOC=3
you say you tried to update driver , tried as in you didn't succeed in getting the update driver ?
i noticed at the sony site they have vista drivers for the dcr-trv350 , here is the link . thanks.
Posted on Dec 29, 2008
SOURCE: can not connect mini dv camcorder to sony vaio laptop
there are many post on various sites that state the same as you ihave the same prob with a sony which i paid £999,00 for and it wont connect i have been researching this problem for months on and of and cannot get any further, what may help you is some information that i have discovered , there are diffrent vers of firwire difrent baud rates this could be one reason for non detection ms sp1 has a diffrent ver to sp2 it is not easy to reinstall sp1 1394 as you need to diable cabbinet files to stop the reloading of the deleted sp2 speed 1394,ther are a few hotfixes avilable from ms on xp not suer about vista also if you plug a faster 1394 device into your machine it could diasble the slower ones , and now for the the killer any manufactur that incorporates 1394 in ther package has to purchase an extremly expensive license and microsoft are heavy into the development of usb stuf and are not concentrating on 1394 hence very little or no support, the only thing you could try is download virtual pc free from ms download site and install the op sys that pertains to the age of the cam good luck
Posted on Jan 13, 2009
I have a samsung VP-D70 camcorder and I want to transfer data to my laptop. The DV out on the camcorder is descibed as 4 pin the other end of the cable supplied is not usb (it has 723 on the connector).I...
This is a Firewire cable, also known as DV or IEEE 1394. Sony call it i.Link. It is not compatible with USB and you cannot get a lead to connect it to a USB port. There are converter/adapters that are supposed to allow Firewire to connect to USB but many forum posts say they do NOT work for video transfer. Unfortunately, most Mini-DV cameras will not transfer video by USB cable, even when they have a USB connection (it is usually only used for still pictures).
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. If you had a desktop PC, you could fit an add-on Firewire interface card to the expansion bus. This will come with a driver for the card.
I have a Samsung Mini-DV, and do transfers with it to the one computer I have that has a Firewire port. It is the only thing I use that computer for, and the reason I haven't thrown it out.
Jan 16, 2011 | Samsung VP-D70 Mini DV Digital Camcorder
I have a Samsung DV-D381 MINI Camcorder. What
OK there are NO cables as such for that PC, as of normal, to get Video into this machine you will have to use either, a USB TV/Video card, and use the AV inputs. OR put a Video TV/Video Capture card into a PCI slot, and again use the AV inputs to connect via. The you will have to use the AV leads Yellow, Red & White, OR the SVHS port if available. You will also need software to record the video stream, If you camera has FireWire then you could install a FireWire Card into a PCI slot and hook you via that, you will still have to use software though. Sometimes the camera, has proprietary software to edit and work with the Video from the camera, usually via FireWire. To get said software go to the manufacturers web site, and download a copy.
Mar 15, 2010 | Samsung VP-D361 Mini DV Digital Camcorder
Cant transfer videos from samsung vp-d361 pal
Check if it has the firewire port. If so, you can get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
You can use the Movie maker to burn it to the Disk
Mar 08, 2009 | Samsung VP-D361 Mini DV Digital Camcorder
Connection
i had this problem la port 1934 is active ? it`s been my first problem
second my problem to many USB conected so virtual memory problem :):). . I used program PowerDVD after that no more problem and im hapy i hope you will try. CIAO
Feb 29, 2008 | Samsung VP-D101 Mini DV Digital Camcorder
USB device not recognized on my VP-D371i Samsung digital camera
i am also have Samsung VP-D371i if u need help my icq number is 400 952 967, but my Samsung VP-D371i do not support usb iam use other line
Feb 23, 2008 | Samsung SC-D363 Mini DV Digital Camcorder
My Camcorder Is Not Detected By The IEEE Card.
1. CHECK CAMCORDER CONNECTIONS AND SETTINGS. 1. The DV Camcorder is turned on and connected by the power adapter (not battery) 2. The Camcorder is in Play Mode. 3. The IEEE 1394 cable is properly connected from you camcorder to the IEEE 1394 card. If you have checked these steps and the camcorder is still not detected, then the camcorder driver is most likely not loaded. 2. CHECK DEVICE MANAGER TO VERIFY THAT CAMCORDER DRIVER IS LOADED. 1. Go to Device Manager by clicking on Programs > Settings > Control Panel > System. (In Windows 2000 you have the additional steps of clicking on Hardware > Device Manager). 2. Under the device heading called Imaging Devices, you should see a device called "Samsung DV Camera or DV Camcorder". If you have an exclamation point "!" on this device, highlight the device by clicking on it and then click the Remove and Refresh buttons for Windows 98SE and ME. For Windows 2000, click on the uninstall icon, then click on the scan for new hardware icon. Even if the camcorder device does not have an exclamation point "!" on it, you can remove it and reload it. With Windows ME and Windows 2000, and Windows XP, the 1394 camcorder driver is built into the operating system by Microsoft and is already loaded on your system. With Windows 98SE the files are located on the 98SE CD in the Win98 folder. If the device is not listed, please check all of items in step #1 above. If it continues to be a problem, there may be a problem with the: 1. Camcorders firewire port 2. 1394 cable 3. The 1394 host controller card Samsung does not support Firewire Components. You must consult the manufacturer of your Firewire product(s).
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Video Cameras Logo
187 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
