Question about Toshiba Satellite A75-S229 Notebook
CD not working
I cannot see my cd in my computer. Any suggestions?
  • 56 Answers
Is the was working then it's just disappeared or this problem since u buy it ??? if it's happend not too long try system restore for windows.... then if it's didn't work ... try to boot from the CD ... insert any operating system CD (windows,linux ,,,etc..) if it's start that mean the problem in the software not in the hardware ... therefore u must install a new operating system.... if it's work please rate me!
Posted on Jul 31, 2007
SOURCE:
My CD-drive wont read my Age of Mythology disks is there any way i can fix it?
try a different cd first to see if your cd drive is even working.. if it is then check your cd for scratches .. sometimes in older cd drives the slightest scratches make the cd unreadable.. i would suggest if the cd drive is unable to read most cd's you should replace it .. try staples or electronics stores like it.. there cheap..easy fix read up on safe instalation of cd drives
Dec 10, 2010 | Microsoft Age of Mythology for Windows
Need to Download Belkin Setup Assistant
I would suggest the following:
in another computer attempt tocreate an image file of your driver cd as you mentioned you still haveit (I strongly suggest you don't lose it), then with a usb thumb drivemove that image into the computer where you want to run the wizard (the one that does not have the cd drive working). now for you to create an image iso file on the othercomputer (virtual image of your cd) you need nero or magiciso oranother program to create iso files from a cd, now to read that imageon your cd-trayless computer you can use a program called magic disc.
there are other programs you can use to make iso image files that are free
free alternatives to nero
magic disc
- this is free and it will create a virtual cd drive on your computerwithout cd drive, you just need to mount the iso file you created withthe other programs and it will work like a cd drive so you caninstallation cd without ever inserting the actual cd.
good luck!
Dec 27, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
DISC DRIVER BROKEN ,NEED TO PROGRAM WEBCAM TO PC
I was trying to help getting the drivers online but for that camera it seems to be tricky.
in another computer attempt to create an image file of your driver cd as you mentioned you still have it (I strongly suggest you don't lose it), then with a usb thumb drive move that image into the vista computer (the one that does not have the disc tray working). now for you to create a image iso file on the other computer (virtual image of your cd) you need nero or magiciso or another program to create iso files from a cd, now to read that image on your cd-trayless computer you can use a program called magic disc.
magic disc
- this is free and it will create a virtual cd drive on your computer without cd tray, you just need to mount the iso file you created with the other programs and it will work like a cd drive so you can installation cd without ever inserting the actual cd.
good luck!
Dec 26, 2009 | Computers & Internet
How to do a system recovery when my cd rom drive doesnt work?
got to have a new cd-rom drive mate, most practical approach.
other options are network boot (done in offices with many computers), USB boot (if your BIOS supports it & you need to have a USB device with the bootable image of the system disk), etc.
Jan 26, 2009 | Computers & Internet
Reformatting acer travelmate 2310
Put in the recovery cd, and restart the computer. Its going to say something like: "Press any key to boot from cd", then press any key. It should start up. Tell me what it says when you restart you computer with the cd inside the computer.
Jan 02, 2009 | Acer TravelMate 2300 Notebook
My cd is well ....i have no idea
Sounds like a tough problem to have because half of the CD drive is working fine (the reading part) but half isn't (the writing/burning part).
Here are a few suggestions:
1) try a different CD writing program, if the Wizard says the CD-Rs are full, try a version of Nero or a freeware burning program.
2) if, when you load the blank CD, Windows says that it's unable to burn it, it might not be a CD that your burner can recognize. If you are using different or new CDs, try another one or borrow someone else's blank CD. I've had it happen where a set of CDs that I bought were bad and couldn't be used. Also, some cheap CDs don't work on some CD burners.
3) It might be a bad CD drive. If it's an older computer, you might have to get a new CD drive. Before doing this, I'd try reinstalling the software and drivers for your CD burner and try both the suggestions from above. Good luck
Sep 09, 2008 | Compaq Computers & Internet
Ripping Disney CD
Some CD's are protected and will not let you rip them to your computer. You may be able to find programs that can get around it, but they are probably illegal.
May 23, 2008 | Dell Dimension 4600 PC Desktop
CD can't be read by Adobe Reader
might be ur cd is scratched so it cannot read the files from cd i mean that some sectors on cd is been damaged so it cannot read put a disk cleaner on the cd and clean the cd it might work if it did not i order to recover the information i can suggest u with the software called bad copy ull get the trial version of it here http://www.jufsoft.com/badcopy/?rid=BadCopy&vid=3.75&bid=0608 download it and recover the whole disk into ur computer the files present in the disk will get transferred on ur computer and the the files in bad sectors also will be read and transferred if both of this did not work put that cd in some other computer i reads copy those cd files to some other empty disk and run it on ur computer this solution is when it runs on other computer if it runs in other computer then there is a problem with ur cdrom if disk does not run in other computer it is the problem of disk and u can solve it by the above mentioned software
Nov 16, 2007 | Microsoft Office Xp Professional Full...
Toshiba Satellite A75-S229 Notebook Logo
24 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
