Question about Kenmore 12102
Tighten the bobbin
I have a kenmore 10 machine how do i tighten the bobbin?
  • 124 Answers
Welcome to FixYa!
Are you having stitch problems? If this is the reason you are wanting to "tighten" the bobbin, then you should reconsider doing so. If you bottom stitch is the problem, then messing around with the bobbin is the last thing you want to do.....
Sewing machines are funny machines and counter intuitive. When people see problems with the underside stitch they automatically assume there is something wrong with the bobbin. In fact, the bottom stitch is created when the bottom thread interacts with the top thread.
The bobbin really doesn't have an adjustment and rarely goes out of whack. It's best to leave this alone unless you know what you are doing.....
So what....IS the problem? There are really only two things that seriously affect the bottom, in general, that is the tension setting (the little dial with numbers on it) and mis-threading the machine (make sure you are following the thread path exactly (sometimes it's not easy to figure out, so have someone else try it. Sometimes a fresh perspective will help you see what you might be missing).
Good luck and Thanks for using FixYa!
Please assign a FixYa Rating if you are happy with my solution.....
Posted on Feb 01, 2009
How to get it off bobbin wind
This is covered in the user manual. If you haven't got one search online for "user manual + your make & model". You should get several decent hits like. http://homeappliance.manualsonline.com/manuals/device/sewing_machine
Aug 08, 2015 | Sewing Machines
Bobbin thread is breaking and thread is knotting up on the underside
check the bobbin case tension--turn the screw to the left to tighten ---turn the screw to the right to loosen
also check the needle to see if it's damaged
also make sure the bobbin is threaded correctly & placed correctly in bobbin case
check for lint or loose threads in bobbin area
check for warped bobbin
Sep 27, 2010 | Kenmore 756A-30BH Mechanical Sewing...
Thread on bobbin looping
Sounds like you need to adjust the bobbin casing tension (tighten the little screw on the bobbin case). I would also oil the face of the bobbin casing so that the thread wont snag or tug on it at all.
Jul 15, 2010 | Kenmore Sewing Machines
Bobbin tread is loose when sewing on cotton material Have adjusted tension, it is on 9. It is fine when I sew denim, which I sew a lot but I am trying to sew cotton now. I have cleanned machine, changed...
Have you checked not only the top tension but also the bottom (bobbin) tension? Top tension is usually a lever wheel etc on the machine (depending on model). To tighten the bobbin tension you need to tighten the small screw on your bobbin casing.
I don't suppose it could be as simple as this?
Jul 07, 2010 | Kenmore Sewing Machines
Is there a way to tighten the tension on the bobbin?
In checking things out, I determined that the bobbin was incorrectly threaded into the bobbin holder. After rethreading correctly, and tightening the bobbin tension just a little bit, the machine worked perfectly. Thank you for checking back, I appreciate it very much. D
Feb 03, 2010 | Kenmore Sewing Machines
How do I adjust the bottom thread the stitches are too loose?
if stitches on top is loose then remove bobbin case and tighten small screw on it. if stitches on bottom of fabric is loose then tighten top thread tension.
Nov 03, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin thread bunching
Check between the tension disc, sometimes you can get a piece of thread caught in that and it prevents it from tightening down and making a good stitch. Also, make sure that your presser foot is in the up position when you thread your machine.
Feb 10, 2009 | Kenmore 15516 Mechanical Sewing Machine
Bobbin winding not working on Kenmore 385.15243/15343
Have you tried tightening the bobbin screw?
Sep 04, 2008 | Kenmore Sewing Machines
Kenmore 10 Sewing Machine
i have a kenmore10 model 1249180 ehwn i sew it squeeks i oil it i dont know where the squeek is coming from
Dec 05, 2007 | Kenmore 744-08BH Mechanical Sewing Machine
Kenmore 12102 Logo
156 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
