The treadmill has 2 adjustment bolts at the back of the machine. The allen wrench needed to adjust the roller came with the machine. If the belt is drifting to the right, tighten the right bolt (clockwise), and the same for the left if it is drifting left..
Fold up the treadmill. The front (close to the floor now) has 2 metal guides. Those should be rubbing on the walking belt to keep the front centered.
Proceed according. God bless you
Testimonial: "Thank you so much. After following your instructions I was able to get the walking belt centered and it is staying in place. I didn't have to ask my husband to fix it for me, feel so proud."
SOURCE: Operating Manual
TRy Here
http://www.iconservice.com/cgi-bin/ncommerce3/ExecMacro/manuals.d2w/report?name=PFTL39310&m=1&lan=
Gerritt
Serving the Twin Cities
SOURCE: Proform 520
Not sure what's happened here. treadmill won't turn on when red key is inserted. checked electrical plug to make sure it worked. I couldn't see that there's anything wrong with the red key. Have any ideas?
SOURCE: Proform Crosswalk Dual Motion Cross Trainer
I think you are talking about the front roller. It has a rubber sleeve that helps to grip the walking belt. Sometimes you can tighten this enough to keep it from slipping but you run the risk of overtightening and damaging both rollers. We recomend replacing that roller.
SOURCE: Proform Crosswalk Advanced 525X
One possibility is the pulley in the front roller.The shaft that goes into the roller slips making the belt seem as if its slipping. To check it it requires tmarking both surfaces with paint and then see if the mark seperates.
SOURCE: my treadmill Proform caliber walk... belts keeps
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes
