Question about GE DBSR453EBWW Electric Dryer
Grinding, scraping noise when drying
Started out with a scraping sound and now has progressed to grinding sound
  • dxirebel3 Feb 05, 2009
    same here except now it has progressed to a squeaking sound that is very loud.
    Scholar:
  • 105 Answers
Glides or roller replacement, could also be something from a pocket wedge between drum or cabinet.
Posted on Feb 04, 2009
2003 GMC Yukon- when driving I have a weird grinding noise in lower speeds and then again when driving around 50-60 mph. it does seem to affect the steering wheel as well. Now when turning left the I get...
It sounds like a wheel bearing is going bad. They are easy to change. If you have a place to jack the vehicle up. Try spinning the front wheels. You should hear a scraping noise as the wheel turns.Also replace both sides at the same time,as the otherside is not far behind.
Oct 01, 2017 | 2002 GMC Yukon XL
MY CTD85 CONDENCER DRYER IS MAKING A NOISE WHEN DRYING LIKE A SCRAPING NOISE DO YOU THINK THE BEARINGS HAVE GONE?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Nov 14, 2010 | Dryers
My ge wvsr1060 makes a grinding sound only while agitating. What is wrong & how can I fix it?
The scraping or grinding noise is from the drive pulley rubbing on the base. This could from the front apron sagging.This can be accessed by removing the front cover.
Mar 02, 2010 | GE Washing Machines
LG Tromm WM2277HW during high speed spin makes noise
I had exactly the same symptom...grinding noise only during high speed spin cycle.
I took the top and back panels off to see how the drain hoses etc. connected. Not wanting to take it apart further, I eventually just took the washing machine outside (I knew I was going to be dealing with water!), pulled the debris catcher front side bottom, and let rip with a garden hose inside the drum with the catcher out (leaving an open drain that could flow unimpeded).
Water flowed quickly out of the open drain, and lo and behold, a small drill bit came out with the water flow. This bit, presumably had gotten through the drum grating, and was resting on the bottom of the housing, scraping and grinding when the drum was spinning.
Aug 16, 2009 | LG Washing Machines
Grinding noise about 30 seconds after starting
Sounds like starter isn't disengaging, get that checked pronto, you could be damaging the flywheel (very expensive). Could be any appliance also; a/c compressor, idler pully, alternator, etc. Don't wait.
Jun 10, 2009 | 2007 Dodge Charger SRT8 Sedan
Maytag dishwasher has a grinding sound during the
Hi
Many times a complaint of noises ( grinding or scraping ) can be traced to a cracked impeller in many of the common motor and pump assemblies used today. Sometimes a poor washing complaint is common after this wash impeller has cracked. Remove power first before investigating.
The motor shaft has started to rust and swells out and this swelling cracks the upper impeller. Most times a new seal and impeller kit can cure this complaint but sanding and cleaning of motor shaft is required before replacing the new seals and impellers.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 03, 2009 | Maytag 24 in. MDB9750AW Dishwasher
Grinding scraping noise and metal strips in the dryer.
yeah id prob just go buy a new drier, cause that one sounds as though its dried its last piece of clothing
May 05, 2009 | Dryers
Brakes grinding in snow
your building up surface rust or the pads are worn out.if it only does this in wet conditions sounds like rust from over night or sitting.please have them checked
Jan 29, 2009 | 2004 Hyundai Santa Fe
GE DBSR453EBWW Electric Dryer Logo
210 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
