Question about E-Machines eMachines Desktop PC
Emachine T2862 I replace the power supply and get a green light on motherboard, but sill will not turn on.
  • Anonymous Feb 20, 2009
    Same problem. I tested the old power supply and no response. The old supply does not light the green light whereas the new one does. Yet machine will not turn on. repair person stated that often with an e machine, both the power supply and the motherboard go. I'm not sure it is worth replacing the motherboard on this old of a machine. fremontdave@comcast.net
  • 107 Answers
Have you try to test your power supply if it actually works? try 2 remove it from your pc plug the power chord on it and short the GREEN and BLACK wires using a pin or any conductor u can use. see if it turn on lights and fan turns on when you do that.
Posted on Feb 01, 2009
D865perl motherboard, the green light is but on the power supply the light are blinking does that mean i need a new power su
Where did you replace the capacitors? It is likely that part is defect. When the capacitors were on the Motherboard there is a big chance you demolished the motherboard. These boards have multi layers and while soldering you must be sure the solder is through and through. If you tried to repair the power supply there are cheap replacements. try another power supply before you go on.
May 20, 2014 | I-Star Computers & Internet
My dell laptop dont turn on
Is there a green light on your power supply that plugs in the wall? If not, the power supply is dead or there's a problem on the motherboard.
To troubleshoot, unplug the laptop from the power supply, unplug the power supply from the wall. Now, plug the power supply into the wall, you should see a green or blue light. If there's a plastic spot for the light but no light is coming on, replace the power supply - better to try a known working on before spending the money on a new replacement first.
If there is a light, plug it into the laptop. If the light goes out when you plug it in, there could be a motherboard problem and the board needs to be replaced or the power jack is damaged and you need a professional to replace it.
If the light is on the whole time, but laptop does not turn on, this could also mean that the board is still bad.
Regardless if it doesn't power up with a good power supply it is usually a motherboard problem and the board needs to be replaced.
Check with dell to see if its under warranty and they will send the parts needed and a tech to replace if it is. You can also ask about purchasing a warranty so your money is better spent to keep your laptop alive and put it towards something useful for the lngevity of the system instead of just paying for the part and a tech.
Feb 11, 2011 | Dell Studio 1737 Laptop
Computer will not turn on. green light blinking
Try replacing the power supply, a blinking green light usually means the power supply is missing an output voltage. If you do that and you still get a blinking green light then the motherboard will need to be replaced.
May 01, 2010 | HP Media Center m1080n (PC099A#ABA) PC...
My computer won't start. Power supply (ttgi 450ss) has a blinking green light and the power supply fan starts when plugged in. Motherboard (asus m2npv-vm) has a green light illuminated between the pci...
See if you plugged in the 4 pin power connector on the motherboard besides the main power connection on the power supply (usually black colored and its a plastic 4 pin connector)
Try another power supply if all else fails. If new power supply does not work with this unit then its a motherboard which is blown and motherboard needs replacing.
Hope this helps
Mar 16, 2010 | TTGI SUPER FLOWER 450W quad fan switching...
Sony VAIO VGC-RB42G - No Power; Blinking green light on power
Try a different known working power supply on that computer, the green light on the power supply should be constant and not blinking. The green light on the motherboard shouldn't be blinking either but if its not getting the right voltage from the motherboard then it will blink as well.
Get a different power supply and see what happens. At that point the power supply green light should be constant, if its not then your motherboard is faulty at that point, if yout the green light is blinking on your motherboard, if both are constant then reseat the memory and CPU and only have the power supply hooked up to the motherboard and not to anything else.
If you still can't get video then at that point you know the motherboard is definitely bad.
Aug 30, 2009 | Sony VAIO VGC-RB42G PC Desktop
When i turn the power on the green power supply light goes out and doesnt turn onand the computer wont turn on
Follow these:
  1. Unplug the computer.
  2. Disconnect the power supply from the motherboard and all other accessories.
  3. Replug the power supply.
  4. Connect the green wire (PSON) of the power supply by way of a jumper wire to any black wire (ground).
  5. The power supply should turn on with its fan. If not, it is defective and should be replaced.
  6. Check the ATX12V connector of your motherboard. It is were you removed the 4-wire, 2 yellow and 2 black, connector of the power supply. Check the continuity of the yellow wires to the black ones. It should be open, otherwise it is shorted and your processor is defective and should be replaced.
Aug 19, 2009 | E-Machines Emachine T5026 power supply **...
Wont start power supply binks
What do u mean u unplug the motherboard...?
May 27, 2009 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Doesn't start. Green LED off. Red light permanently lighted.
First, try replacing the power supply. If this does not work then the motherboard will need to be replaced.
Aug 02, 2008 | Matsonic MS8137C Motherboard
E-Machines eMachines Desktop PC Logo
193 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
