Question about Dryers
Dryer will not stay on and has power to it
The hose to the dryer and vent are ok just wont stay on
    Scholar:
  • 42 Answers
The problem you've described appears to be the DOOR SWITCH (Very likely and very common).
The purpose of the door switch is to prevent injury when the drum is rotating. Thus, if the door is open or the door switch "thinks its' open" (broken), the dryer will not turn on for safety reasons.
Depending on your "handy" skills, the door-switch is pretty simple to replace and costs about $10-$15 or so. I would access the inside of the dryer; observe the metal trip level (not on all models), depress and test the switch for continutity; or replace as necessary.
Posted on Feb 01, 2009
The dryer wont stay on the heating mode
how long does it run before quit heating . unhook dryer vent hose and try with vent discounected
Nov 29, 2013 | Haier GDZ5-1 Electric Dryer
MY HUSBAND POWER WASHED THE OUTSIDE OF THE HOUSE, WATER MAY HAVE RUN INTO THE DRYER VENT. COULD THAT BE THE REASON WHY MY DRYER NO LONGER HEATS UP ENOUGH?
Quite possibly if he filled the vent hose up with water. You may have to scoot the dryer out, disconnect the hose, and try lifting it up enough to drain any water in the hose. Otherwise, while you have it apart, look in to the hose and make sure it isn't plugged up with lint. Tell your husband, that's ok, I would probably have made the same mistake . :) Mark
Jul 12, 2011 | GE Profile Harmony DPGT750EC Electric...
Wont stay hot
This means the gas coils have failed or the dryer vent hose is blocked.
Check the vent hose in the rear of the dryer it's the most common issue.
Mar 27, 2011 | Kenmore Dryers
Damp button stays on and it won't work. Water in the vent hose.
leave vent hose off, run dryer. if solves problem fix vent hose and vent. if not then take dryer apart and clean all the lint out
Jul 19, 2010 | Maytag EPICz Electric Dryer
We just moved and hooked up our dryer and it wont dry our clothes
1ST CHECK POWER OUTLET IF YOU HAVE ELECTRIC DRYER, IT SHOULD HAVE 220V COMING OUT FROM OUT LET. IF POWER IS OK AND HEATING BUT LONG TIME TO DRY THEN CHECK YOU DRYER VENT.
IF YOYR DRYER VENT AND POWER IS OK, THEN IT COULD BE ONE OF THE HI LIMIT OR YOU HAVE BAD HEATING ELEMENT
Feb 28, 2010 | Kenmore 62602 Electric Dryer
May tag it heat up but no air is comming of the hose that leads out side
Your vent is propably restricted with lint. Have entire dryer vent system cleaned. Make sure first that the dryer is blowing ok by taking hose off back of dryer. If air comes out dryer without hose attached but no air out vent when hose is attached then the vent hose or duct work in house is clogged.
Feb 02, 2010 | Whirlpool GEW9250 Electric Dryer
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
Clothes get warm but stay wet and do not fully
You need to check the venting. Take the vent hose off the back of the dryer and try drying a load with it off and see if it will fully dry. If so, clean the vent hose.
Nov 16, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryer wont dry clothes
Vents can fool you sometimes they seem to be ok but still cause problems. Try running with vent unhooked from machine one time and see if it works ok.
Check for leaks air leaks around the door or anywhere else.
Jun 10, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
65 people viewed this question
Top Dryers Experts
