Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Top wand does not spin
On my Frigidaire Model # RDB510LCS0 built in the top wand does not spin and spray water when the dish washer is running so thing are not getting very clean. The wand seems to spin free by hand. Thanks for any help you can give.
Bob
  • fitzincc Mar 09, 2009
    I've got the same issue. I've confirmed the water is making it around to the top through the hose on the side but there is never enough pressure to spin it. While I had the bottom filter out for cleaning I turned on the washer with the door open and the pressure is good, real good, big mess. Any advice would be greatly appreciated. Thanks,
You may have a water volume problem.
The water fill sequence on most washers is timed. Insufficient water at the bottom of the washer will cause the pump to cavitate.
Ensure water is filling to just under the heating element.
You can fix this by isolating the water and electricity then remove the fill solenoid. Inside the solenoid is a top hat filter screen. This screen captures sedement.
Once the sedement was removed on my washer the wands turned
My machine also had a check valve on the bottom near the back of the machine that was blocked.The valve needs to work freely in order for the pump to build pressure. The check valve can be removed from the top by turning the assembly counter clock wise.
Posted on Feb 09, 2010
How do I reattach the top washer spinning wand on my dishwasher? It was knocked off by an object in the top tray. It is attached to the top of the washer case, above the rack. The washer is a Frigidaire...
Hey friend, that's a great question!
From the information you have provided the wand fell of the top of your Frigidaire dishwasher and you want to reattach it. Normally, the arm screws in. If your arm will not attach properly it could be damaged or the piece it screws into could be damaged. I would check over to make sure there are no cracks or damage done to the arm. Best of luck! -Matt
Feb 14, 2015 | Frigidaire Dishwashers
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Dish washer not cleaning dishes in top rack
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Frigidaire built in dishwasher model PLD2855RFC1. Have to wash dishes pretty much spotless prior to using dishwaser. Glasses come out with what appears to be soap residue regardless if powder or liquid....
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
May 31, 2010 | Frigidaire PLD2855RFC Dishwasher
Top revolving spray arm wil not spin and rinse
Often they will not spin because there is stuff inside that plug the holes...
Here is a tip that I wrote about your problem...
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Apr 15, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 24" fdb641rj dishwasher
the check-ball runs the top spray arm both arms don't run at the same time and that's the correct fill for this model whats your problem
Feb 07, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Dishwasher not washing
By chance have you cleaned the spray arm out lately? There could be something blogging the water from getting into the arm. In most dishwashers, the arm only spins because water pressure makes it spin.
Miss Midget
Nov 19, 2006 | Frigidaire 24 in. FDB126RB Built-in...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
395 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
