Question about Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer does not heat
I have replaced the heating unit but still no heat, what else do I check? maybe temperature control or themostat, what do you suggest?
Thanks
  • 32 Answers
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Posted on Feb 05, 2009
Dryer problem
have ou check the heating element, the thermal fuse..?
Jul 04, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
This Maytag Atlantis heats too hot; I cleaned off all the lint deposit from the drier itself and from the ducts, but it is still too hot, with heat coming out even in fluff. please help.
There are high/heat limit switches in the rear near the heating element. The switch needs to be replaced because its not shutting the heat off when it reaches correct temperature. Rear of dryer needs to be disassembled for this repair...............
Dec 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer turns on but does not heat up
the first thing to check is the ignitor .how ever there is a thermal fuse located on the exhaust duct inside the dryer that may be bad this woulld cause the unit to run and not get hot.this needs to be checked with an ohm meter for continuity there is more than one thermal fuse so check them all just to be sure.i hope this has helped.please let me now how things turned out.good luck
Jan 22, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
MAytag GAs Dryer is no heating
First check lint in filter and clean. Sometimes the lint sticks to the themostat in the back of the dryer and the thermstat thinks the dryer is overheating (a safety control). If still not heating it has to be in the heating control unit at inside botton of dryer. If you have a Sears part house close by, they will test the unit for free. That's the best shot I have from here. When inspecting dryer or removing heater unit, be sure dryer is unplugged.
If this info helps alittle , please rate this advise - Thanks & Good luck
Oct 17, 2009 | Maytag Dryers
No heat from dryer maytag atlantis mde7600ayw had heating element them fuse and thermostat checked ok check ciruit breaker turn on and off decided to replace fuse dyer still didn't heat check outlet...
most dryers have a thermal switch or breaker in the cavity somewhere, they can become worn over time and will stop heating, the item probably looks like a copper arm that touches a contact similar to a old morse code key by looks
Sep 18, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
My Maytag Atlantis MDG6400AWW will not heat up. The drum spins but the clothes don't dry!
my dryer timer is not turning off and it does not get hot,I check glow coil.its working but it does not fire up.I smell gas some time
Apr 16, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag electric dryer will not heat up. it's a de107
Have someone check to be sure you have 240 volts to the plug. The dryer will run on 120 volts but must have 240 volts to the heating unit. If you 240 volts you probably need a heating element or control.
Apr 06, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis dryer no heat
The heating element and thermostat are located behind the front panel of the dryer. you will need to remove the door, then the retaining screws. the heater / element is located on the left side as you are facing the front of the dryer and has to sheet meta screws (upper back top / and front bottom) which will need to be removed. the unit has several colored wires for the thermostat and switch. remove these (remember which goes where) and the enitre unit will come out easily.
Aug 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
874 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
