Model 7141 motion detection light for outdoors with EZ connection
SOURCE: need to wire motion sensor to light, have three
The black wire goes with the black house supply wire, and the red wire goes with the black wire from the lighting fixture. The white wires all connect together.
SOURCE: the manual says wire black
Depending on where box is and who wired it the red wire very well may be switched from inside. If you want to use the dusk on and off and sensor exclusively, in other words, you don't want it switched, cap off the red wire and don't use it. If you would like it switched, see if you can find a switch that will operate the red wire, probably somewhere around the nearest doorway out, or if you have a switch that you could never figure out what it was for.
