Question about Gateway BCM94306MP Network Adapter
ACCIDENTLY REMOVED LAN CONNECTION
I CAnnot connect to the internet.. i was trying to free up some space on my gateway pc, and tried removing rarely used programs. I manually removed components necessary to connect to the internet.. I somehow deleted the ethernet hardware or something.. and cannot set up new connection as there is no lan icon.. How can I fix this issue ? is there something I can download to my laptop and somehow transfer to my desktop pc?
  • 3 more comments
  • oarodriguez4 Feb 01, 2009
    GATEWAY MFATXPAR ESX 500S
    I DOWNLOADDED AND TRIED TO INSTALL THE DRIVERS BUT IT A MESSAGE APPEARS THAT THEY ARE ALREADY INSTALLED
    WIRED Sn# 0027144131
    PCI/VEN_8086&DEV_1039&SUBSYS_4000107B&REV_81\4&2AF9ED5&0&40F0
    THE DRIVERS FOR THE DEVICE ARE NOT INSTALLED
    DEVICE: ETHERNET CONTROLLER
    ERROR CODE: THE DRIVERS FOR THIS DEVICE ARE NOT INSTALLED
    President:
  • 1,214 Answers
Go to Device Manager and see if your ethernet adapter has a yellow exclamation point next to it. If it does, then right click, properties, device driver, update device driver, and then have it scan your hard drive for the drivers. If they are not there, tyr the CD that came with your computer.
If you don't have a disk, then yes, you may need to go to the Gateway site and download the LAN drivers for your machine.
But I doubt that you removed the drivers. You may have removed some software, but not the drivers.
What symptoms of non-operation are you now having since deleting what you deleted?
I can help you through this, but I need to know where square 1 is first.
And what Operating System are you running?
Posted on Feb 01, 2009
  • 916 Answers
Go here scroll down and download this: Click Here
It will reinstall your hardware for you
  • Gateway Master
  • 13,433 Answers
Hi
This can be easyly fixed by installing the lan software again. I need to know the brand and model of your computer.
Go ahead and accept this solution, send me the details and I'll make sure you get the correct software back into the computer.
  • 4 more comments
  • Ekse Feb 01, 2009
    Hi http://support.gateway.com/support/drive...
    Download the software
    move it to the computer
    install the software
    Is the problem solved?
  • Ekse Feb 01, 2009
    Is it wireless? or Wired?
    Can you find the serial number from the computer case?
  • Ekse Feb 01, 2009
    Do you remember the name of the program that was removed? Also are you using windows xp?
    Also if you could post me the device PNP ID for the device that is not installed.
    To do this press Start Then Run And type in msinfo32 On the computer where the problem is
    Now press the + next to components, as the list opens find the problem devices part click on it.
    Now you may need to maximise the window to full screen to see the full PNP device ID
    Please write down everything you see on the page
    For example:
    Device
    1394 net adapter
    PNP device ID
    1394\NIV1394\17339DD1D800
    The above is just a example and I need you to find and write down exactly what it gives you, send the details to me on this page.
  • Ekse Feb 01, 2009
    Thank you, I'm looking into it now.
  • Ekse Feb 01, 2009
    Ok This would be easyly solved if the computer had internet access I could remotely install it but I'll have to write it down for you.
    Follow my instructions exactly to get the driver installed.
    1. Download the driver file, 7512978.exe from the gateway support site, yes its the same file you already downloaded.
    2. Download winrar and install it, with this link
    http://www.rarlab.com/rar/wrar380.exe
    Download the file, run it to install it or double click it. Install the program by clicking next next next next and ok or close at the end so the program is installed.
    Now you have winrar installed
    Find the downloaded driver file "7512978.exe" Right Click and select EXTRACT to 7512978\
    A new folder named 7512978 will be on your desktop or in the folder where you extracted the file.
    You will need to move this folder with all its contents to the right computer.
    3. Now that you have the folder and all the files on the computer where the driver is missing from.
    Right click on my computer and select manage.
    On the management window on the left side select Device manager.
    Now on the right side find the device with ! or ? mark or yellow mark, or unknown device. Right click on it and select properties. Then click on the drivers Tab and click update driver.
    Then Select the advanced option
    Now Remote the Check from the Cd rom option and change it to include this location in the search, follow the red arrows.
    Browse
    Find the 7512978 folder
    Click ok
    follow the blue arrow and click next
    the driver should install.
    If any questions come up, click on continue anyway. If anything else comes up or if the driver is not found drop me a comment.
  • Ekse Feb 03, 2009
    Have you gotten the problem fixed? Do you need further assistance?
    What steps have you taken where have you got stuck or what happens?
    Thanks,
    Ekse
2 Suggested Answers
  • 13433 Answers
SOURCE: PROBLEM CONNECTING TO INTERNET
Can you post me all the details you find in your computer case, there is either a 10 digit serial code or 22 digit. post me everything you find.
Feb 01, 2009 | Gateway BCM94306MP Network Adapter
Lan card toshiba wireless no working
Check this Tip for an overview
  1. Connect your PC to your router using LAN Cable: be sure you can browse internet
  2. If you cannot browse check router config with your ISP
  3. Connect to your router using IP address you find for gateway in Network status
  4. Configure your router wireless section to match with your PC card
  5. Start removing security, broadcast radio signal, create a simple SSID as network name
  6. Check if router network is seen by your PC card (when you disconnect the LAN cable and activate the wireless card)
  7. If connection is established ( near the router) try different location
  8. Reconnect cable and reconfig adding security protocol (WPA-PSK recommended) use parameters compatible with your lan card
Jan 15, 2009 | Toshiba Satellite 5105-S501 Notebook
Connection using ethnernet cable
Connect Ethernet cable into your LAN port.
Your PC shaould be able to see the connection (righ click on Systray LAN ICON, check status ) eventually try REPAIR.
Check the Gateway address.
Be sure to use DHCP to obtain IP address.
If you can Ping the gateway but cannot browse Internet, ask hotel desk if they need to activate your connection (sometime a fee is charged).
Let me know if you need more detail.
Dec 30, 2008 | ASUS Computers & Internet
Have internet connection for e-mail but cannot connect computer to server. Have the ability to send and receive e-mails. I have removed all firewalls and have no-add-ons other firewall on, Defender being...
1.check your browser if you have work offline check try to uncheck it. its under file on your browser menu.
2.have you try to delete your temporary internet files under tools - internet options - browsing history
3. check all working pc if they have proxy settings under tool-internet options- connection tab- lan settings. copy it if they do have.
Nov 11, 2008 | HP Computers & Internet
Ps3 wired connection
Hi There.
If your PS3 is Networked upto Your PC to use the internet connection, You have to allow the PC to share its Internet connection with yout PC, Do this By going into Network settings, Checking the properties of your LAN card in your PC. and clicking on, "share my internet". This should alleviate that problem..
Or.
If your PS3's Wired connection isnt working. but your PC one is, Try moving your PS3 Lan cable into one of the other Free LAN Ports (if available) or Try Switching the PC cable over to the PS3's Port in the Router, and Visa-Versa !
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Wi Fi fine, ISP fine, no internet via LAN connection though.
Make sure your firewall is not blocking your ability to go to websites. I saw this the other day, somehow the users firewall was set to block all internet traffic out of the computer.
Jan 21, 2008 | NetGear DG834G Router
Connected on Wireless but unable to connect on Internet
If not done allready, setup the lan IP address and default gateway in win98 Click MyComputer-ControlPanel-Network-Double Click TCP/IP Adapter for your 3com device-insert LAN info for IP Adress-subnet mask, Gateway and your Internet service providors DNS Addresses info Tab's (3x different Tabs "IP Adress" "Gateway" "DNS Configuration") IP Adress will be at least one number higher than your gateway address and not allready being used by other PC's on your network and gateway address will same as your router interface address subnet mask will be the same for all PC's on your network. For 3com and Netgear routers LAN setup is usually Gateway = 192.168.1.1 Subnet Mask = 255.255.255.0 IP Adress = 192.168.1.10(choose alternate number than 10 if allready used by another PC on your network, try to use round numbers, must be a number higher than 1) Once all info is entered click OK (this may trigger a database info update message and task)now your LAN is setup and ready to talk to your network Restart PC and try browsing again. May possibly require reinstallation of the TCP/IP client (you double clicked this to setup your LAN in Win98) or reinstallation of the IIS(Internet Information Services)component found in, Add/Remove Programs-Add/Remove windows components and then try LAN setup again if this does not work first time round
May 06, 2007 | 3Com OfficeConnect Wireless 11g 802.11g/b...
Computers & Internet Logo
611 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
