Question about Hitachi Televison & Video
Color is horrible.
Just replaced the bulb. Now color is bad. Tried to fix it according to manual instructions. Unable to do it.
  • 4,234 Answers
In order for us to provide you with accurate suggestions and solutions, the model number is required. Can you please update this with that info?
Thanks,
Dan
Posted on Feb 01, 2009
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Projection picture is horrible, not clear
This set needs the coolant fluid between the tubes and lenses replaced. This is a very common problem for philips/magnavox projection tv's and should only be performed by a professional so that there will be no leaks. Theis is a complicated repair. Thanks for using fixya.
Dec 25, 2009 | Philips 9P5034C 50" Rear Projection...
I think the color bulbs are going out. I called
3D pic?Ur convergence it dead.U know how to solders?Tries these websites for convergence kit.Use replaced what in the convergence kit. Tv repair World.com,or Tvrepairkits.com.
Dec 14, 2009 | Mitsubishi WT-46809 46" Rear Projection...
The color has faded . I replaced the bulb the problem persists!
Light Engine is Bad, If you had said TV was making loud whistling sound then it would be Bad color Wheel
Sep 27, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Color
Check the red colour out put section at LCD base PCB..the capacitor is weak or the transistor is gone bad,replace with new one..
Jul 09, 2009 | Samsung PCL541R 54" Rear Projection...
Buzzing sound with volume off/mute samsung 6163
It sounds like your color wheel. If you are handy at all you can change it pretty easily for the price of the part (probably around $90-$110) and a couple hours of your time. Here is a link to a video showing you the step by step process. http://www.youtube.com/watch?v=Cx4pbNjsxfU good luck..
May 28, 2009 | Samsung HLP6163W 61" Rear Projection...
Color problems
Your color wheel is bad. Thats the only thig that controls color on the DLP projections. You will need to replace it But I would check the connections on it first to make sure the connections are secure. Let me know if you require more assistance.
Feb 26, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Bad color
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Oct 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
