Question about Brother GX-6750 Typewriter
How do you type an exclamation mark?
Is there is specific key combination to get type this?
  • 10,865 Answers
I would begin by pressing the shift key and then the numeral one key. good luck
Posted on Feb 01, 2009
Where is the exclamation mark
The ! is usually the upper case 1 if you don't have a key marked ! you can type ' backspace and type a period
DickyO.
May 15, 2014 | Office Equipment & Supplies
DSL yours did not put r4 but when I open it I see the name of r4 and with an exclamation mark
If you see any exclamation / question marks or red X's a new driver will need to be updated or installed right click select up date driver
You will have to open up your network connections Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled. Make sure your antivirus program is not blocking the internet connection. If you are trying to connect through a modem/router you it should have come with a disk then you might have to connect the usb lead to your modem to get a connection then Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers. The driver might be on the disc supplied by your ISP internet service provider or the motherboard disc If you cant install the driver Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its "Enabled"ima Click start type cmd press enter you will be in DOS mode type in ipconfig press enter you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138 i device arrows key scroll to nstalled. Hope this helps.
Jan 28, 2013 | Sigma 1.006596.V2.15 Luxembourg 1200/2200...
Bluetooth code 43
Click the Start button, click Control Panel, click System and Maintenance, and then click Device Manager.
If you are prompted for an administrator password or confirmation, type the password or provide confirmation
In the list, double-click the type of device, and then locate the specific device that isn't working properly.
If an exclamation mark appears next to the name of the device, Device Manager can't find the device driver. Go to "Use Windows Update to find a device driver."
If no exclamation mark appears next to the name of the device, go to "Uninstall and reinstall the device driver."
Close Device Manager.
hope this helps
Aug 01, 2012 | Microsoft Windows 7 Ultimate for PC
Cannot change the function on my keyboard back to a question mark
If you're on Windows then try pressing CTRL+SHIFT keys together (sometimes ALT+SHIFT, see which combination works for you) until your keyboard layout indicator in your system's notification area (bottom right part of your screen, just left of system clock) shows the keyboard layout code that you're used to, in your case "EN". You can cycle through all the installed keyboard layouts using this same key combination.
Mar 02, 2012 | Compaq Keyboard
Have a new wireless HP keyboard for all in one omni 100, keys do not correspond on screen with keyboard, have tried adding different language keyboards in regions to no avail, what am I doing wrong_+(* ...
It's possible that you have hit the Num Lock key while you had another key pressed. Try the following combinations, one at a time, to see if any of them work. Be sure to test each one before moving on to the next one.
CTRL and NUM LK
Shift and NUM LK
ALT and NUM LK
A lot of times characters will swap places if one of these combinations has been pressed, and pressing the combination again should switch it back. Let me know how it goes! If this doesn't work, we'll try something else.
Aug 26, 2011 | Compaq Keyboard
How do i calculate combinations
Your calculator has three keys, next to which are the following markings:n! , nCr, and nPr. The one with the exclamation point is for factorials. The second is for combinations, and the third with permutations.
Syntax of the command.
If the markings are on the keys, the functions are accessed directly. If the markings are on the body of the calculator, you access the functions by pressing SHIFT and the key.
12 [!] gives 12 factorial
12 [nCr] 4 gives the combinations of 12 objects taken 4 at a time (order not important)
12 [nPr] 4 gives the permutations of 12 objects taken 4 at a time (order is important.)
Jun 09, 2011 | Texas Instruments TI-30XA Calculator
Sidekick 3 typing question
Hold ALT and the key with the symbols .
Feb 09, 2010 | T-Mobile Sidekick® 3 Cellular Phone
Where is factorial button on ti-83 plus
Not every function on the TI83Plus calculator has a dedicated key, or is accessible through a key sequence. Among the keyless function is the factorial function.
To access the factorial function
  1. Through the catalog of commands: press [2nd][0] (CATALOG) and scroll Up till you reach the exclamation mark !
  2. Press [MATH]. Use right arrow to highlight PRB menu. The factorial function is the 4th in the list.
Syntax
Type the number and use one of the foregoing access methods to echo the exclamation mark on the home screen and press ENTER.
Ex: 12! =479001600
The largest number that you can use with the factorial is 69.
Hope it helps.
Dec 06, 2009 | Texas Instruments TI-83 Plus Calculator
I have no sound
Check if the volume is not muted. Then, check in the Device Manager, if there is any exclamation mark visible under "sound, video and game controllers" category.
If there is any exclamation mark then right click on the device and uninstall it and restart the Computer then reinstall the audio driver after downloading from the manufacturer support site.
Furthermore, you may also try performing System Restore to restore the Computer to the time when sound was working normally.
Press the Windows logo key+R to open the Run dialog box then type devmgmt.msc and click OK to open the Device manager window.
Type rstrui in the Run dialog box and click OK to proceed with the System Restore procedure.
Nov 07, 2009 | Computers & Internet
Brother GX-6750 Typewriter Logo
111 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
