Question about Frigidaire GLEQ2152ES Electric Dryer
Intermittent Heat The dryer occasionally becomes warm. An audible click is heard when the heat comes on and another audible click is heard when the heat turns off. After a minute or so of no heat, the dryer decides to heat then repeats as previously stated. I was wondering if I have a bad thermstat, heat element, or fuse situation. This seems to occur only on certain drying cycles. In some cases the dryer never becomes warm and I am left with cold, wet clothes. :-(
  • 3 more comments
  • Anonymous Nov 04, 2007
    same problem in a frigidaire model GLER331ASO. Thank for info. I will check these things
  • powerguy Dec 27, 2007
    Having same problem with a Kenmore Elite model 110-62882101. It will run fine for weeks then no heat. All parts check out OK. Very Frustrating. Cleaned out vent line 3 months ago, worked OK after that, then it wouldn't heat twice during weeks thereafter, "healed" itself after a few days (I did nothing), works ok now. Will look at vent situation again. This is a rather new installation, however. "powerguy"
  • Anonymous Jun 17, 2008
    frigidaire Gallory series dryer will run but no heat
  • gabby2blab Aug 29, 2008
    you can feel heat through vent...no heat in dryer...clothes do not dry..cleaned vent of lint
  • Anonymous Mar 27, 2014
    no heat and it stops in about 10 minutes
For what its worth, I found out what was wrong with the Kenmore Elite 110-62882101. The circuit board works a small relay that works the heating element. We replaced the thermister, then the circuit board - to no avail! Finally, we replaced the relay, and the problem ended. Seems that the relay didn't always make up even though it clicked. It's a Potter Brumfield (and old line company) but made in China (what isn't?). The guy is the local parts store says the motor relay is the same type (they look alike) and that these caused trouble in the past. The heat circuit didn't use relays in the past (when there were thermostats), but they do now (that temperature is controlled by thermisters and circuit boards). So, the lowly, seemingly simple and reliable heat relay can be the problem - if your dryer has one. --- Powerguy
Posted on Mar 04, 2008
I have a similar problem with my old DE406 Maytag. It use to require a couple hours of rest before it would apply heat but once it did start up (as long as the door was not opened to "check the clothes") it would continue running/heating/drying the appropriate duration.
The air flow exhaust is free and clear and the air flows quite well. (My dryer does not exhibit the audible click-on, click-off symptom as mentioned in the original posted question however.) So I am relatively "certain" that it does not have to do with air flow.
Should I presume that the problem is with the one of the two thermostats?
Finally, the two different thermostats for this model are apparently 3-3035 and 3-5865. Which thermostat is the Low Temp and which is the High Temp? Which one do you think is more likely the cause of the problem?
Posted on Feb 28, 2008
Check the exterior air duct; the one leading outside.
This can get clogged and also block the air flow
Posted on Nov 07, 2007
The problem is almost certainly caused by a lack of air flow, clean ducting and check any external vent is clear. Regards Advisor
Posted on Aug 30, 2007
    President:
  • 331 Answers
Tango, your dryer is most likely overheating inside the cabinet. This is caused by poor air flow and will cause the dryer to "short cycle" the heating element. 1.)Make sure the dryer is at least 8" away from the wall. This will ensure the duct work from the dryer to the wall is not "choked" off and preventing air flow. Visually verify the flex duct behind the dryer. Make sure that any bends in it are smooth "S" shapes and no 90 degree turns. 2.)If you've never had this done, you should... hire a pro to come out and clean the internal dryer duct work, the ductwork inside the walls leading outside. They will, over time, collect lint in there and eventually begin choking off the air flow. Kinda like a clogged artery and cholesterol. 3.) You may have a failed blower inside the dryer. I doubt this because a failed blower makes an awfully loud noise to let you know it's bad. You didn't mention noise so this is a long shot.
Posted on Aug 01, 2007
  • Tracy Farrell
    Tracy Farrell Aug 05, 2007
    Please post back with your resolution.
SOURCE:
Gas dryer turns on, turns, and dries clothes but does not become noticeably hot or even warm.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 21, 2010 | Dryers
I just replaced my heating element and it still isnt getting warm
Number 6 and 15 come in a kit. Both need to be replaced. Why? Because the bigger one is rated for 250f and the smaller one which is bad in your case dies @300F.
These blow when the vent becomes clogged and stops airflow
More repair photos, more heating failure solutions, a video which shows how to break it down, and a service manual is HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Oct 29, 2010 | Roper REX3614KW Electric Dryer
Dryer is not heating up to dry clothes
The spark ignitor maybe at fault. Listen for the clicking noise upon starting it up the first 30 seconds it runs. If not heard it is in need of a replacement
May 01, 2010 | Amana NED7200TW Electric Dryer
Dryer not drying due to no heat. We just had recent heavy snow and i have roof vent so i thought that may have been the problem. After checking further, the problem is due to no heat coming out. It tumbles...
since this is a gas dryer turn it on and listen for 30 seconds for a clicking noise. That will be for the burners ignitor. If no clicks are heard the ignitor is at fault
Feb 14, 2010 | Kenmore 63942 Dryer
1999 Dodge Caravan SE's intermittent heater
it sounds like a vaccume leak check under hood for vaccume line that goes through the firewall trace this line and look for leaks next pull controll unit out of dash most times this unit is worn an will leak causing lak of controll of the heat an airconditioning
Feb 13, 2010 | 1996 Dodge Caravan
Dryer does not start up when the start button is pressed. It makes a click like a relay is closing but no power to the drum motor, or electric heat. unit interior lights up, and controls light up. When...
Your belt is likely broken. Pop the top (held down by spring clips) to inspect. If you see it - try to lift it. If you can not lift it it is ok. If not ok, remove the front cover for complete access to the drive.
Dec 29, 2009 | Kenmore HE2 Plus Front Load Washer
Gas dryer dries slow
The coils on the gas valve are faulty. They will work occasionally when cold but will not after they become warm with use. Replace the coils and it will work again. Eric
Sep 11, 2009 | Kenmore Dryers
Heat no longer works
Is this a gas model? Does the glow coil get bright orange then go dark? You would want to measure the current on the glow coil if this is the case. It could be a weak glow bar/coil or bad coils on the burner. This all assumes the thermostat is sending full voltage to the burner. Please do not hesitate to ask more questions.
Eric
Jun 10, 2009 | Whirlpool LGR5636L Gas Dryer
Propane dryer. Can hear the heat kick on but dryer doesn't heat
Try looking at the gas regulator. It should have a solenoid that opens and closes. It sounds to me like this is not opening or is only opening partially. I had this same problem on an oven.
May 31, 2009 | Kenmore Dryers
Dryer warm but not hot, long dry times
some times there are multiple heating elements in there and if one is out it does not get as hot. another simpler place to start would be to make sure your line is clear of debries all the way from dryer to out doors. this is a good idea any way since lint build up can cause the occasional house fire.
Jan 23, 2009 | Dryers
Frigidaire GLEQ2152ES Electric Dryer Logo
3,136 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
