No speach on lg lh-w750 DVD player
I have no speech on DVD's only background noise, the centre speaker is also crackling regardless if anything is playing or not
  • 19,396 Answers
Check the speaker cable connections.
Check also sounds settings on DVD, but that should make no difference.
Test the set with different speakers, if it depends on the DVD , then it is a fault probably on the audio output .
Posted on Feb 01, 2009
Background noise problem with motorola radius cp200 and also crackling status during transmissions
Bill,
If the crackling and static are coming from the radio, it could mean 1) Something in your environment is putting out RF (radio frequency waves). 2) You have an old battery. 3) You are at the edge of the radio's range. 4) You have a bad speaker in the radio.
Possible solutions for you could be:
1) Have the radios reprogrammed to have Private Line (PL). This would block out RF noise on your frequency. Also, within the factory if there are devices putting out RF noise, there may be some solutions for them.
2) Replace old batteries. (Try a known good battery and see if it helps.)
3) Check to see if you have the same problem when radios are within a closer range. If it is a range problem, education yourself and other users to hold the radio upright (perpendicular) to the ground. You will get the best range. Tilting the radio can reduce range as much as 2/3s. Even the bodyfluid of a person wearing the radio can absorb range.
4) See if you have the same problem with another radio, or if the crackling static is just with the one radio. It may need repaired.
Another solution for you might be a noise canceling remote speaker mic. This would put the speaker of the radio up on your lapel. And these mics also have some noise/wind canceling ability.
There are a few programming things you could have your local dealer try. They may be able to tighten up the squelch and knock out some of the noise.
Best regards.
Mar 11, 2013 | Radio Communications
DVD PLAYER MULTI REGION CODES
you can change your dvd region code but i advise you not to change it instead use a software . here is the link for the software to download :- http://www.4shared.com/file/19492658/43612f11/DVD_Ghost.html?s=1
if it doesn't work then contact me ok.
Jun 28, 2008 | Televison & Video
There is a crackling noise coming from centre speaker, have tried another speaker and still the same, so not a speaker problem. Have also tried different DVD player and still the same noise, and even...
It depends on what wrong is with the receiver. If there is bad DSP (digital surround sound processing) board better to buy new receiver. If it is just bad channel it can be repaired below or about hundred dollars. It could be also just simple cold soldering joints. You need to bring it to a repair shop and get an estimate.
Jan 11, 2011 | Denon AVR-1507 Receiver
LG Hdd/dvd recorder receiver system ? model lh-rh3690se, speakers ? lhs ? 36se5s, lhs36se5a, i recenty bought this player but it just keeps displaying (please wait on the dvd player), nothing shows on the...
l have active subwoofer 4 lg LH-RH3690SE DVD REC.SO I M LOOKING 4 A PLAYER /A FULL SEAT.I LOST MAIN WHAN I SENT IT BACK 2 LG BECZ OF A TECHNICAL PROBLEM.AND IT NEVER CAME BACK.IF ANY ONE HAVE A SOLUTION CONTACT ME ON 0717016643 PLZ GUYZ HALPP ME
Aug 30, 2010 | Televison & Video
No speach volume when playing ps3 dvd through hdmi
it is not using the correct sound file. try another dvd.
Jun 10, 2009 | Sony Playstation 3 (PS3) Console
Rear speaker not working.
check for loose connections
or speaker cut.
Apr 17, 2009 | Televison & Video
LG LH-W750 dvd player sound only
SOUN problem Zenith XBV343 DVD Player / VCR Combo?
Jan 06, 2009 | LG DN788
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
I can't hear any speech when I play a DVD, but I have all other sound.
Yes what you heard is correct,look for center speaker connection.If it is correct then connect it thru coaxel or digital out and see.
Feb 09, 2007 | Eltax DV-100 DVD Player
Televison & Video Logo
56 people viewed this question
Top Televison & Video Experts
