Question about Apple iMac G5 Desktop
Imac g5 is so noisy
Either the hard drive or fan seems to keep running. always so loud.
  • sanjgoyle Feb 02, 2009
    allanster- thanks for this. i've tried that without success. on some macforums they talk about clearing out dust from the vents. it is such a pain to work on documents with the machine purring away...
  • 60 Answers
Fan sometimes get stuck on, I won't bore you with the technical details as to why or the terminal command to fix. Just do this...
Shut down. Unplug the power cord from the back of the tower. Wait 15 minutes and plug it back in. Power up, it should have reset it.
The fans are "smart", some of them are designed to run only as needed, sometimes they get a little tangled up in their own underwear.
Posted on Feb 02, 2009
  • Allan Claunch
    Allan Claunch Feb 02, 2009
    You mentioned reading in some mac forum so I am assuming you have probably already seen this, but just in case, here is a good roundup of possible solutions (scroll down past dates)
  • Allan Claunch
    PS... I would recommend installing free iStat which will let you see the actual temperatures so you will know if you're really running hot or if it is software glitch related.
My Imac A1058 won't start up only the fans work
Never heard of before, though power there.
Guess, try holding the on/of switch in a little longer, some systems act as reboot/reinstall
Apr 14, 2013 | Apple iMac G5 Desktop
Why do only the fans work on my imac a1058
Hi Joseph,
Well it's a 9 year old iMac.. it sounds to me like the power supply has failed. Nothing under $300 to fix unfortunately
Imac wont recognize my new internal hard drive
Yes, rem it is iMac, it has to be formatted for iMac, sorry there is a way, if you have alternative access, search box and type in formatting new had for iMac. Good luck.
Feb 08, 2013 | Apple iMac G5 Desktop
I would like to know if an older hard drive from imac model A1076 could be installed in a slightly newer imac, model A1145 and have it be compatible and working with no problems?
Hard drives are universal, and based on physical connection / type. So your older HD should work even if you have newer SATA connection. The connection is backwards compatible.
Dec 08, 2012 | Apple Imac G5 20" Als G5 2.0ghz 2gb-ram...
Ok, the school where I work was having an electronics recycling drive and one of the other labs recycled an iMac G5 A1058. I have a friend who needs a new computer, so I took it, got a new hard drive for...
Bad capacitors often cause the no-turn-on problem. This page has a good picture of what bad caps look like in the G5. If you see this trouble in your G5, you might be able to get this going. Kits of capacitors are available (here's the place I got some from) and If you're comfortable with electronic soldering and replacing parts on a printed circuit board, changing out the duds may be all that's needed. I've seen three of these now. On one, there was just a single bad cap that was keeping the computer from starting up. It's certainly worth looking into.
Jun 13, 2011 | Apple iMac G5 Desktop
Imac G5 keeps freezing on turn on
Get out your Mac OS disc and restart your computer and get that disc into the drive. You may need to restart with the disc in, but that's ok.
Just restart again with the "C" Key pressed and the computer will launch with the OS disc, and then you can access the file menu when it finishes launching.
Choose "Disk Utitlity" from the file menu and you can repair the system files on your hard disk.
then restart without the disc in the drive.
Sep 14, 2009 | Apple iMac 24" Desktop
Imac g5 speaker has very loud buzz
Check the cable of your speakers or
Download another Music Player
Mar 18, 2009 | Apple iMac G5 Desktop
Imac g5 fan is too loud.  have looked at apple forums and have not found a solution.
Pull off back and clean fan with compressed air can, try and move sensor from hard drive frame to somewhere on the hard drive itself. If not order a replacement fan they do go bad.
Mar 01, 2009 | Samsung SGH-P310 Cellular Phone
17" iMac quit working
Your Imac may be one of those affected by Apples purchase of inferior capacitators from Taiwan. If you are less than 3 years from the purchase date, apple will repair the problem for you for free. Just take the unit to your nearest local Apple Genius or tech. If you are outside of the repair extension guidelines, I have provided a link here which can show you or someone more skilled how to repair the problem. Ordering a new motherboard and power supply will set you back a lot of money, however the following guide and pdf give you step by step instructions on how to ressurrect your dead imac without speding more than $100.00. I was able to repair my imac using this guide and it was worth it to save a $2k computer that was only 3 1/2 years old. Check it out:
the following information (in italics and bold)  is taken directly from:  (this site is complete with instructions, manual and the full compliment of materials available at an extremely affordable and fair price. I took a chance and repaired my own, it is not as hard as it sounds1)
The iMac G5 Repair Extension Program for Video and Power Issues applies to first generation iMac G5 computers that have video or power-related issues as a result of a specific component failure. If your iMac G5 is exhibiting any of the symptoms listed below and your computer's serial number is within the noted ranges, your computer may be eligible for repair, free of charge. If Apple or an Apple Authorized Service Provider (AASP) determines that your iMac G5 computer is eligible as part of the program, the repair will be covered by Apple for up to three years from the original date of purchase even if your iMac G5 is out of warranty.
This is a worldwide Apple program.
Affected systems will exhibit one of the following video- or power-related symptoms:
Scrambled or distorted video
No video
No power
Note: If your iMac G5 is not experiencing any of these symptoms, you do not have to contact Apple or any Apple Authorized Service Provider.
Which iMac G5 computers are affected by the iMac G5 Repair Extension Program for Video and Power Issues?
The program is available for certain first generation iMac G5 models that were sold between approximately September 2004 and June 2005 featuring 17- and 20-inch displays with 1.6GHz and 1.8GHz G5 processors.
The affected iMac G5 computers have serial numbers where the first 5 digits fall into the ranges noted below.
Serial Number ranges:
W8435xxxxxx - W8522xxxxxx
QP435xxxxxx - QP522xxxxxx
CK435xxxxxx - CK522xxxxxx
YD435xxxxxx - YD522xxxxxx
Some second generation iMac G5 computers have serial numbers that fall within the upper band of the ranges listed below. Only first generation iMac G5 computers are affected by this program.
Where do I find the serial number of my iMac G5?
The 11-digit serial number is located on a label under the foot of the iMac G5. There is a bar code underneath the serial number.
To view the label, hold the sides of the iMac and gently lay the computer face down on a soft, clean towel or cloth.
Is the iMac G5 Repair Extension program available for other Apple computers?
This program applies only to the systems noted in this FAQ. Other versions of the iMac G5 line are not part of this program. Click here for more information on how to identify iMac G5 models
Free guide for how to repair the motherboard capacitors, rescue the hard drive and more.
Feb 22, 2009 | Apple (661-2795) for iMac Motherboard
Apple iMac G5 Desktop Logo
284 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
