Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
USB HUB FAILURE
THE SYSTEM REQUIRES THAT I UNPLUG ANY USB DEVICE CONNECTED TO IT BEFORE HYBERNATION OR SHUT DOWN, FAILING WHICH, I'LL ONLY GET A BLANK SCREEN AFTER LOG ON, WITH ALL INPUT DEVICES NOT RESPONDING. I TRIED TO ADJUST THE BIOS SETTINGS BUT, IT NEVER WORKED, I DONT SUPPOSE IT COULD BE OUT-DATED BIOS AS THE VERSION ON MY SYSTEM WAS RELEASED ON JANUARY 2005.
  • HOPOLANG KEMANE Sep 03, 2007
    Problem solved!
    Sorry sadrew, I went to the manufacturers site and managed to download the recent bios and the utility tool(for use in windows environment), it was a bit risky because I've never done an update before but If anyone is to do it, be sure to look up the motherboard version number as this should correspond to the bios.
    President:
  • 2,961 Answers
My advice would be to not use hibernation, there are too many posts with people putting their pc into hibernation and not able to get it to wake up again, partly because of hardware issues relating to usb power ups afterwards. I would rather use the log off or switch off as hibernation only comes into use for conserving battery power in notebooks. also do not attempt to update the bios if there are no problems as you may render your pc useless
Posted on Aug 01, 2007
How do you recharge batteries with the usb
yes you can or many places they sell wall/car adapters that charge USB devices you have to look around .
Jul 09, 2016 | Garmin Etrex 20 Gps
USB Hub not functioning
Disconnect the HUB, reboot your PC and connect your HUB again.
Mar 16, 2012 | HP Computers & Internet
I have a thoshiba satelite a100 laptop my problem is usb device is not working i format the laptop and then install windows xp sp3 but not solve this problem i conect any usb device then erormessege is...
To work around the above issues, one of the below solutions could prove helpful:usb-device-not-recognized.jpg
  • Unsecure or Loose Connection
    Unplug the presently connected USB device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a USB device.
  • Scan for Hardware Changes in Device Manager
    Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the USB device.
  • USB Hub Power Management
    Disable power management of the USB hub. To disable the power management on the USB hub, follow these steps; Click Start, and then click Run. Type devmgmt.msc in the popup box, and then click Ok. Expand the Universal Serial Bus Controllers' node, and then follow these steps for each USB Root Hub that is listed.
    1. Right-click the USB Root Hub and then click Properties.
    2. Click the Power Management tab.
    3. Click to clear the Allow the computer to turn off this device to save power check box, and then click Ok.
    Note: If you perform the following p
      Unplug the presently connected usb device (if any). It is quite possible that the connection is not secure and has become loose. Re-plug the USB device tightly and firmly into the USB port. This is one of the most common reasons for an error in detecting a usb device.
      Use the Device Manager to scan for new and recently installed hardware. From the Start menu, select the Run option. In the pop up box, type in Devmgmt.msc and then click Ok. From the Action menu, click Scan for hardware changes. This will make Windows scan & recognize any new devices that are installed. Now, close all opened device managers and control panels. Now, follow the above step and see if your computer detects the usb device.
    • usb Power Management
      Note: If you perform the following procedure on a laptop computer, you may reduce the battery life.
    Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Mar 28, 2011 | Computers & Internet
Usb port not recognized any device
  • Don't worry just follow the simple steps and get rid out of that problem
  • Sometimes, simply unplugging the USB device and turning off the computer for twenty minutes and then restarting may solve the issue. If none of the above options have solved the problem, check the manufacturer's website for new driver information. It is possible that your drivers need to be updated. There could also be a possibility of hardware failure, which needs to be checked by a hardware expert.
Please rate me if this solution works for you
Thanks......Have a great time
Jun 29, 2010 | Acer Veriton 7600GT PC Desktop
Power surge on hub port a usb device has exceeded the power limits of its hub port there is nothing connected to my computer
I don't know how old your system might be or how many USB controllers it has on the motherboard, but understand this...
Theoretically, one USB port can support up to 999 "daisy chained" devices.
With that said...the way a USB port is implemented on a motherboard, manufacturers enable two or four ports to be working off of one USB interface. Those ports you see on the front of your computer are most likely connected to just one USB interface on the actual motherboard and that's why you always see computers with USB ports located together in pairs.
With that in mind, you're USB ports are connected to what is referred to as a "hub"(that motherboard interface), which only outputs so much power. If one device or many devices attached to this "hub" exceed the power output of this "hub" then it will either back down to USB 1.1 speeds or it won't function at all. That is why some USB accessories require their own wall adapter, because the USB can't supply all the necessary power for it.
So one of two things has happened, either your USB port is fried or you introduced a new USB item to the "hub" that surpasses the power requirements of what your USB hub can output once you plug in your mp3 player.
You can troubleshoot by unplugging all un-necessary USB equipment and try only that port again. My assumption is that the USB hub is fine but the actual usb port you use might be damaged.
Good luck.
Mar 12, 2009 | Acer Aspire One PC Notebook
Usb ports
  • The driver for the device is faulty. When you plug in a USB device, the computer should load and then configure the device without ever requesting a device driver. If the computer prompts you for a device driver, check the information that came with the device or go to the manufacturer's website to see if a driver is available.
  • The USB port might be defective. If the USB device is connected to a defective port, the device will not work. Try plugging the device into a different port. If all the USB ports are being used, unplug a device that you know works, and then plug the problem device into the port that device was using.
    If the device is plugged into a secondary USB hub with other USB devices, unplug the device from the hub, and then plug the device directly into a port on your computer.
  • Other USB devices might be drawing too much power from the hub. The device you are trying to use might require all the available power or bandwidth that your computer can provide. If other USB devices are connected to the computer and are drawing power from it, the first device might not work. If any other devices are drawing power from the hub, try disconnecting them, and then see if your device works. If this solves the problem, you might want to obtain a USB hub with its own power supply so that you have adequate power for all devices.
  • Oct 23, 2008 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
    Usb write protect
    If you've updated your software and checked the drivers but the issue still persists, try the following things:
    • Unplug the USB device and then plug it back in. Make sure that the connection is snug and installed in the proper direction. Note that USB plugs fit one way only—if you try to plug them in upside-down, it will not insert.
    If this does not solve your issue-
    • Unplug all USB devices from the computer. Then start plugging in USB devices one at a time, testing each one to make sure they all work before adding the next. Sometimes two devices will conflict and will work together.
    • Is this a new device that never worked, or is it a device that you've had for a while that suddenly stopped working? If it used to work, think about what changed just before the device stopped working. Did you recently add another new device? Install a new program? Try reverting the computer to the way it was before the device stopped working. If it works again, there is an incompatibility with the device and whatever you added.
    • Unplug all but suspected USB devices. Open System Devices menu-
      • Windows: Right click “My Computer” > Properties > Hardware > Device Manager > USB Serial Bus Controllers
      Under the USB information, you should see the USB devices connected to your system. (Disregard any Host controllers) The name may not be identical to your device (it may say “USB Mass storage device”), but it should have the right number of devices listed.
    • If you have the device plugged into a USB hub or into your keyboard, plug it directly into one of the USB ports on the computer. If it works there, the issue is with the device to which it had been previously connected. The device may need more power than the port provides
    • Try a different computer!
    Sep 23, 2008 | Centon Electronics USB 2.0 PCMCIA...
    Failure to read USB connected storage drives
    What I have seen with some computer models, is that the USB port cannot deliver enough current to run some devices.
    If possible, use an external drive with its own power supply and see if it will work. Most likely it will.
    Also, try a powered USB hub. I found that most of the time, a powered USB hub solved many problems with having enough power for some external USB devices.
    Jerry G.
    Jul 26, 2008 | Apple iBook G3 Mac Notebook
    Loss of power
    hi
    if you replaced the psu itself and you still get no power, have you tried changing the power cable itself?
    Jan 23, 2008 | Gigabyte GA-8PE800 PRO Motherboard
    Helpp! exceeded the power limits on its hub port?
    a simple solution is buy a powered usb hub ( which has an adapter which plugs into the mains) that should solve your problem
    Dec 11, 2006 | Nikon Coolpix 5900 Digital Camera
    EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
    101 people viewed this question
    Top EliteGroup Computers & Internet Experts
    Alun Cox
    Matson Kurian
    Matson Kurian
    Joe Negus
    Joe Negus
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
