Question about Desa International R40 Utility Heater
R70ct ready heater keeps shuting off
Heater runs for 2 min. then shuts off and the reset has to be pressed. smells very rich, like it's not burning properly
  • 11,896 Answers
Either you have debris in the fuel line or you need to clean the igniter
Posted on Feb 01, 2009
Strong smell of gas after turning off
you may have a fuel leak or your motor is running rich check the fuel tank and have your idle speed motor checked
Jan 18, 2014 | 2002 Mercury Villager
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Running very rich. how to adjust fuel and air screw
First of all are you running kerosene or diesel ? If you are using diesel, it does not burn as clean as kerosene which causes that burning rich smell. If you are going to use diesel, just use #1 diesel only but still may have a little rich smell. Don't use die red off road diesel. If you are using kerosene and want to check your air pressure on your pump, you will need a 10 lb. test gauge with a 1/8" NPT male pipe thread on the end of the gauge.There are 2 plugs on the back plate. Do not remove the upper plug with the hole in it. This is the adjustment screw for pressure. Clockwise increases pressure, counter clockwise decreases pressure. With the heater unplugged,remove the lower plug. Screw the test gauge in and start the heater. Check the pressure. Most are set between 5 1/2 and 6 lb. of pressure. Check your owners manual to see what your setting should be. If your pressure does not change, you have a worn pump and it would have to be repaired. Once you have the correct setting, unplug the heater, remove the gauge and install the plug back. If you feel that you are not qualified to perform this procedure, send it in to a local repair center.
Jan 11, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
My hot tub pump is getting loud. And if placed on high I can smell a burning smell, so obviously not being used. I've left it on to keep it heating and the plumber is scheduled for this week. However...
It sounds like the bearings have gone bad in the jet pump. A shaft seal leak will sometimes let water get into the bearings and the motor will get louder and louder. Running it on high can intensify the noise and heat created by bad bearings. Eventually, the bearings will seize and the motor will try to turn and since it can't, it will get really hot. The motor has built in high limits to keep from burning up completely but it will smell like it's burning. I would replace the pump motor and seal, should take care of the problem. The OH may have been caused by the pump not moving enough water to run the heater and tripped the heaters high temp sensor. I hope this helps.
Oct 13, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Keep copier ready; disable powersave option
This is going to be a user program:
1) press and hold both light and dark keys
a) the 2 buttons to lighten and darken copies
b) hold both for 5 sec until indicators light up
2) use the left copy quantity key show 2
3) press your copy key
4) use the right quantity key to change to 2 (max 90 sec)
5) press the copy key
repeat step 2 but change to 3 with left quantity key
press the copy key
change right number to (4 = 60 min, 1 is default at 5 min) then press your copy key.
Once done press both light and dark key again to exit
Note*** changing shut off timer and preheat will effect copy lamp ready state. Every 60 sec or so the scanner will move and reset. Some people do not like the noise is makes all the time. If you don't you can always change it back to the defaults. 2=0 and 3=1.
Oct 12, 2009 | Sharp AL 1631 Copier
Will turn off after 1 min run on low heat burn
Hi Billie,
You didn't mention the model number, but they are all pretty basic. The flame sensor and thermo pile which are thin flame sensors, get charred and need to be cleaned. They should be cleaned with a soft cloth or even a dollar bill will work (a worn one)
When the heater shuts down it usually means it is not sensing the flame and this will cause it to shut off automatically. I have included a link to get the owners manual below.
Good luck and be sure to turn off the gas and power to the unit before working on it.
Click Here to Get Owners Manual
Thanks,
Paul
Jan 18, 2009 | Desa International GWP20T GLOWARM Wall...
Just keeps shuting off
try K1 kerosene after you clean it out, diesel burns dirty and has a higher ignition temp.
Jan 15, 2009 | Reddy R155D Utility Heater
Reset button keeps popping and the time between becomes shorter.
check the photo eye. It's the little rubber boot on the bottom right on the back side of the burner. If it's dirty, it may not be shutting off the igniter. If the igniter runs continuously, the safety breaker will trip.
Dec 18, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Desa International R40 Utility Heater Logo
115 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
