Question about Motorola Mobility RAZR V3
Possible Water Damage?
Hi, I really need some help. My razr has what looks like water in the front screen. The backlight will not show, and I can't use most of the buttons. However, I have no idea how water could have gotten inside of it. I checked the water tag in the back and it shows that water has been there... =/ any solutions besides getting a new phone? (any home repair possibilities)?
  • asdfqwerf qwerwdsfasdf Aug 01, 2007
    THANK YOU SOOO MUCH. I figured I would have to take the screen off but wasn't sure what tools to use and etc. Thank you.
    actually, I tried that and it didn't work... both screens have NO light... any suggestions??
  • 39 Answers
I've jumped into my pool unaware my razr was in my pocket and although I ended up getting a new phone in a few weeks(phone was crushed at work), I was able to salvage my razr from the pool by doing this: You will need a T6 and T5 screwdriver to take the razr apart. (Don't try to do this without the right tools or it will take forever). Take a large cookie tray or other large tray that will fit the pieces into. Take apart the covering and remove the innards. With a soft cloth or paper towel, wipe the innards dry. After all parts have been wiped dry, take a hairdryer and gently blow on the parts (it really helps if your blowdryer has a "cold blow" setting) and make sure that you keep the dryer as far away as possible without the loss of airflow. (All you are trying to do is evaporate any small particles of water that you may not see). After blowdrying, I wiped the circuit board with a Q-tip and rubbing alcohol on some items that had water stains and waited a day for it to dry in the tray. After a day of drying in the tray, I placed all the items back together and my razr worked as good as new. Here is also the official repair manual that techs use to repair the razr. It will shed some light on details: http://www.hackthev3.com/pdf/Technical_Support_Group_V3.pdf
Posted on Jul 31, 2007
SOURCE:
Screen foggy
sounds like water damage,but also backlight might be getting ready to burn out
Oct 18, 2009 | Motorola Mobility RAZR V3
Black screen on inside and outside has not been dropped may have water damage from water on my hands
i know the water sticker is still white because you didnt get the actual sticker wet... in order to get the sticker to turn red... the sticker has to be wet...!
May 29, 2009 | Motorola Mobility RAZR V3
Motorola razr screen wont light up
Even though the water has dried out the liquid still can damage the software, liquid damage is not covered under warranty
May 22, 2009 | Motorola Mobility RAZR V3
Backlight not turning on when phone is turned on (Razr)
There is a small cable, inside the phone, near the hinge, that can come loose or unplugged. You should have this checked out by someone who can service it. For them it's a simple procedure of reinserting the cable fully.
Aug 03, 2008 | Motorola Mobility RAZR V3
WESTINGHOUSE FLAT SCREEN TV
Water damage/stains possible on backlight panel behind LCD panel. I've seen this more on laptops. Does it look like brighter white spots? You might have to take it in to have it professionally cleaned.
Apr 23, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
HELP ME WITH MY LG KG800!!
send it for repairs but i doubt they will fix it cause its water damage so you might as well get a new phone
Jan 14, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3 Cellular Problems With Water Damage
yes it is bad
getting hot means that the internals are frying or shorting out
leave the battery off of it for about a week then try it again.
I really don't like your chances of it working properly again though.
Good Luck
Nov 17, 2007 | Motorola Mobility RAZR V3
Motor Razy 3xx cellphone
yup...
its common prob for razr. if you can open your fon, check its flex coonector inside mayb it get loose thats why you dont have any display, if everything is fine... probably you have a defective flex connector or defective LCD...
Oct 26, 2007 | Motorola Mobility RAZR V3
Three problems...
1. You may have water damage this would explain all of the problems. 2. I doubt very highly it's your carrier 3. If you have dropped your phone, your camera lens may be cracked causing the screen to pick up primary colors, or once again it's water damage. If the screen does different variations of color in different patterns or only partial images... the lens is cracked. Otherwise... YOU'VE GOT WATER DAMAGE... say goodbye to the Razor.
Jan 15, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
75 people viewed this question
Top Motorola Mobility Cell Phones Experts
D. E. Hev
vince
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
