Question about Water Heaters
Humming noise with my beckett burner
I have a beckett oil burner. when i turn the thermostat up the burner comes on and makes a humming noise for a while; then it stops. any ideas as to what this is.
  • 359 Answers
The beat i can do on this is an educated guess , it would be the pump or the pump motor bearings , but having said that i have also seen these make noise for years and not go out ,I have worked on oil burner about 35 years experience has taught me not to guess parts , so the advise i would give is to find the part and model numbers for the motor on the pump assembly and the pump try to find availability in your area , heating and cooling, hardware store ECT. and wait to see if becomes more defined or fails so you don't spend a fortune on parts you don't need ,**** make sure there are no oil ports on the pump motor bearings 9LITTLE OIL CAPS ECT OR PLASTIC PLUGS YOU CAN REMOVE TO OIL ) IF THERE IS PUT A COUPLE DROPS OF 3 IN 1 OIL AND SEE IF IT HELPS .
Posted on Feb 01, 2009
My new viessman boiler is showing F1 after it made a humming that went on for half an hour
F1 means burner is at fault ,lack of pressure, best to call viessman or the installer back as if its a new boiler it has a five year warranty
Jun 07, 2015 | Water Water Heaters
How do I connect the two thermostat wires from a Honeywell R8184G4009 to a programable thermostat. My old thermostat is not marked.
On the Protectorelay Oil Burner Control R8184G4009, you connect the two thermostat wires @ "T" and the other "T". On the ACE Smart Temp Universal programable therostat, connect one wire to "Rh" and the other wire to " "W". Be careful if you are using this thermostat for A/C. In that case, make sure there is no jumper between "Rh" to "Rc".
Feb 02, 2013 | Honeywell Protectorelay Oil Burner Control...
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
Sep 06, 2012 | Rheem Water Heaters
New Rheem Fury Guardian System 50 gal water heater model 42V50-40F. Loud low humming or drone sound when in operation. What can this be?
Is the noise when the water is running or when the burner is running???
If it is just the water then the noise often is the flow checks inside the tubes going to and from the heater...
If it is the burner, then the noise could be the gas going through the gas valve...a bit of moisture or dirt can sometimes cause noises...usulally will correct its self after a bit of worry...
poping crackling sounds and such are common with mineral builsup in the bottom of the heater....
Flush the heater and get the dirt out....
sizzling noises sometimes happen from condensation dripping onto the burner....gain not a problem...
sometimes the gas properties will cause the gas to make noises when going through the gas orifice into the burner... usually this is air or a LP air mixture known as "citigas" that will burn like natural gas but really isn't and it will make noises such as your are describing...again no problem...
Ultimately the noise you hear is not a problem but can be irritaing if the heater is where you can hear it easily...
Feel free to comment back if you have any more questions...
Feb 25, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
Water heater runs for 40 seconds or so and stops, smell oil oder
Hello STOP!!!!! don't push the reset button any more.You have a ignition/spark problem.You will load the chamber with oil and will cause major problems when it lites off.Replace the ignition TRANSFORMER on the burner.Avalible for (beckett burner) at home depot/lowes.
Sep 20, 2010 | RTO Bock Water Heaters 51E 50 gal 152,000...
I have a power vent2 water heater by Rheem products. Problem seems to be with blower fan turning on when thermostat calls for heat. Fan makes un-able to start noise and thermostat stops. If I turn the...
your blower motor is trying to seize up on you, it is time to change it, if the fan doesn't come on first your water heater should not light, the fan comes on first to get eccess gasses out of the burner compartment,, do not light with ot the fan first it could combust
Jan 27, 2009 | Bosch & Power Vent Water Heater
Beckett home oil burner
problem is pump-must replace- there is a valve inside unit that holds pressure to about 150psi -it is leaking by when unit shuts down- causing problem. If left unrepaired you could blow chimeny connection with bad ignition. good luck
Nov 01, 2008 | Water Heaters
Water Heaters Logo
937 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
