Question about General Electric GE 13-438 Overhead Garage Door Switch
Opened my garage door remote and now it doesnt work
I opened up the garage door remote to retrieve the code so I could program an additional one. I put the cover back on the original remote and it didn't work. Everything was working fine before I removed the cover to get the code (which I was very careful in doing and didn't change or touch anything on the inside). Now the remote doesn't work at all. It shows a red light when I press on the button. I park underground in a multi stall lot in my apartment complex. About 10 people have the same remote to the same door and everyone's is working.
I have no idea what to do and it's really annoying to have to get out of my car to manually open the door each morning I leave and evening I return. I appreciate any help.
Model # 109130-360
Brand- Overhead door
  • Thomas F. Schneider May 11, 2010
    Inside the remote are little switches. Make sure the little switches are in the correct position. Sometimes they are the same as the code?
    Problem Solver:
  • 21 Answers
Old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball old school hollywood baseball
Posted on Feb 10, 2009
Can you program more than one remote for a liftmaster model 1160 garage door opener? When I try, one works but the other doesnt. Seems to knock the other remote out.
When this happens it is usually because you are trying to program two remotes that are not compatible. Even though they will both work they will not work together. Take the model number off the one that works best and get an exact replacement.
Aug 01, 2011 | Sears Craftsman LiftMaster Chamberlain...
Our remotes (2 for the car and a keyless entry) stopped working. We erased everything (and checked to make sure our remotes weren't working) and reprogrammed all remotes. They work, but our neighbor's...
Make sure your neighbor doesn't have a remote with a sticking switch. Often times a person will stick an extra remote in a drawer and then place something on it that holds the button down. Try programming your remotes this way just in case you didn't.
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Sometimes it can help if you are in the garage when you program your remotes this way and it will drown out any distant signal.
Nov 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My garage door sytem was working fine. I lost a remote, so after getting a new one, I programmed it into the door opener. After that, i found the remote I programmed worked, but my wife's remote did not....
Ted, it sounds like normal garage door function. Here is my take, you were pushing the button in a fashion that was to clear all remotes. This is done through either pushing wrong button, or pressing the programming button for too long.
Sometimes you need an assistant to be able to activate the wireless key, soon enough after pressing programming button. Get a ladder and a light, climb up and read the directions carefully on your opener. Try to add just the keyless system.
If that does not work,Get an assistant, and do the whole process again, including the keyless.
There are two distinct processes, adding and clearing, and it may be easy to invoke the wrong one.
Your system uses rolling code/invite system. Rolling code relates to a handshake betewen each remote and the base. The code is changed at each use, for each remote. (the keyless /wireless also).
Been there, done this. all for an additional second or two of button press.
Oct 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Have a genie garage with two doors and need to change one to open, one of the doors that use to open another door. Other door is opened by bluetooth by autmobile. How do you change code on unit on ceiling...
Go to this site and follow the directions under "Replacing a lost or stolen remote" Then you will need to program your bluetooth.
http://www.aaaremotes.com/gegadooptr1.html
Feb 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door is opening when the neighbor open theirs with remot
You say you "setup the remote and the main box but doesn't solve." I think you mean you programmed the unit but I'm not sure. Anyway try holding the smart/learn button in for 10 seconds and this will erase the memory. None of the remotes should work. Now when you are sure the neighbor will not be using their opener, program your remotes. This may be what you did but I'm not sure.
Aug 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Code Remote and other remotes do not all work at the same time.
Either your keypad has reverted to an earlier technology and will no longer work properly with your opener or you have the wrong keypad. Either way take the model number off the main unit and get the correct keypad.
May 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Cannot program additional remotes to new door opener
THe old transmitters have a differnt code...more than likely your new one is a riolling code and the old ones are not. They are not interchangeable.
Oct 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Manual
I would try here, they seem to have library of manuals.
http://userguides.50webs.com/
May 25, 2008 | Sears Craftsman LiftMaster Chamberlain...
General Electric GE 13-438 Overhead Garage Door Switch Logo
1,007 people viewed this question
Top General Electric Electrical Supplies Experts
Rob Bridges
Level 1 Expert
ken skalski
David Harrelson
David Harrelson
Are you a General Electric Electrical Supply Expert? Answer questions, earn points and help others
