Question about Hitachi PJTX100 Multimedia Projector
Hitachi CPX275 unstable connection with Vista
I am able to connect and establish temporarily using Windows Vista Ultimate and a Hitachi CPX 275 but the signal will get corrupted after a couple minutes. The problem seems worse with the sidebar open on Vista
  • 115 Answers
Pls set up the display properties to screen reslution to 800x600 and then try higher resultion. that will work.
Viren
Posted on Nov 27, 2007
SOURCE:
I INSTALLED TOSHIBA SOFTWARE UPGRADES APPLICATION. THE REFRESH LIST SITES AN ERROR CONNECTION COULD NOT BE ESTABLISHED. I NOTICED CSINSTALL.INI FILE IS MISSING? CAN SOMEONE HELP?
restore the system and the date that the machine was working before.
2) use the ANTIVIRUS+MALWARE, you can have some virus or malware, pass it.
3) if the problem persist, your computer has software diagnostic, use it and you will have the fix it.
God bless you
Sep 25, 2012 | Sony Toshiba Qosmio F45-AV411 Notebook
Is there any software by which i can work on my computer when i am away from my home ?
Hello,you can work with your pc even away from it without a software.. In Windows, Remote Desktop allows you to access your computer from a remote location. To enable Remote Desktop, you must have administrative rights on the computer you want to use as the host (i.e., the computer to which you will connect from a remote location), which must be running one of the following versions of Windows: Windows 7 Professional, Enterprise, or Ultimate Windows Vista Business, Enterprise, or Ultimate Windows XP Professional The Remote Desktop Connection client software (for the computer from which you want to connect) is installed by default on all computers running Windows 7, Vista, or XP. Enable the Remote Desktop feature on your host computer From the Start menu, select Control Panel (or Settings, and then Control Panel). Double-click System. In Windows 7 and Vista, click Remote settings. In the "Remote Desktop" section, select one of the two options to allow connections from other computers. In Windows XP, select the Remote tab. Select Allow users to connect remotely to this computer. To choose which users will have remote access, in 7 and Vista, click Select Users... or in XP, click Select Remote Users... . Typically, all administrators of the computer will have access by default. Each user must have a password before you can allow remote access. When you are finished, click OK. Your computer will now be able to accept incoming Remote Desktop connections. Open a connection If you have configured your computer to accept remote connections, to establish a Remote Desktop connection: Depending upon your network configuration and system requirements, you may first have to establish a VPN connection to your host computer's network. From the Start menu, select Programs or All Programs. Select Accessories, and then Remote Desktop Connection. In the space next to "Computer:", type the name or IP address for your host computer. Click Connect. Note: If you would like to adjust any of your connection settings such as screen size, login information, availability of local hard drives and printers, or keyboard and sound behavior, click Options before clicking Connect. In the Log On to Windows dialog box, type your username, password, and domain (if required). Click OK. Once you are connected, you can use your remote computer as if you were sitting in front of it. When you are finished, in the Remote Desktop Connection window, select Start, then Shut Down. In the Shut Down Windows dialog box, from the drop-down menu, select Log Off username, where username is your username on the remote computer. Click OK. goodluck!don't forget to rate,thanks'''''****
Feb 21, 2011 | ViewSonic VG2230WM LCD Monitor
I have no vista key
Its illegal to use such used keys and you have to disable Automatic Updates. Please buy one. Use this temporarily. Oh first you have to tell me the version. This is for ultimate.
FBK3P-9HCG-YJGBB-CRVGV-X32M9 (Act )
YFKBB-PQJJV-G996G-VWGXY-2V3X8 OR pvyfq-2jtbv-pkxq2-fqhdy-mtbvh
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Windows Vista Ultimate: Internet connectivity
Make sure your IPv4 settings property is set to AutoObtain the IP address under the Network properties for the wireless card
Apr 05, 2009 | Microsoft Windows Vista Ultimate Edition
WindowsMail "the connection to the server has Failed"
go to microsoft technet and type the error code into the search bar
Dec 25, 2008 | Microsoft Windows Vista Ultimate Edition
Cannot connect to internet using HUAWEI mobile connect in HP vist
chek whther those driver supports vista?othwise try to find out vista drivers from site.....and even try manual connection through network connection...
Dec 05, 2008 | Microsoft Windows Vista Ultimate Edition
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Hitachi PJTX100 Multimedia Projector Logo
115 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
