Question about Whirlpool RBS305PD Electric Single Oven
My oven will not heat up at all.
Yesterday I used the self-cleaning feature and the oven worked fine. This morning when I went to use the oven it reamained cold. The light comes on, the preheating timer comes on, but no heat on the at all.
  • julie_s May 11, 2010
    Could you check your bake and broil elements? The self-clean feature uses a lot of power (the overn comes up to over 500 degrees for a sustained period of time) and this can cause the bake and broil elements to burn out.
    The elements in your oven are similar to the filament in a light bulb -- they either work, or they fail. I think it would be unusual for both elements to burn out at the same time, but not impossible.
    If you see any cracks or rough spots in your elements, it could mean that element has failed. Check both elements (use s flashlight if you can't get a good look at them with the oven light alone). If both appear damaged, tell the service agency this when you call. The repairman should be able to bring both elements with him (elements are easily obtained at any parts dealer if you provide the model and serial number of your appliance).
    Problem Solver:
  • 10 Answers
Make sure your cooking timer is on manual....
Posted on Feb 01, 2009
Used self cleaning process on my oven yesterday and today the oven will not turn on, we keep getting message to unlock the oven door even though it is. What can we do?
The oven gets extremely hot during the self-cleaning mode... the door switch might have got stuck in locked position, or broken in locked position (to be replaced), let's hope it's just stuck...which you'll need to work the mechanical lock-unlock latching back and forth to hopefully unstick....and if that doesn't work just re-run self-cleaning process but this time let the oven cool completely before unlocking the door. Hope this helps.
May 11, 2014 | GE Ovens
Fisher and Paykel AeroTech Double - OD301 Electric Oven Oven not working after self cleaning
Ours have also stopped working (both top and bottom). Bought in 2003 so only 8 yrs old. Getting technician in to fix. Will post solution. Also whenever oven is heated up the display panel fades and is not visible (has been doing this for a couple of years)
Nov 22, 2011 | Fisher and Paykel AeroTech Double - OD302M...
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
I have a triple task Kenmore stove with the self cleaning feature, my oven worked fine till I cleaned it one day and now it wont heat up. I have taken the elements out and had the tested and they are fine...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 11, 2010 | Ovens
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
After using self cleaning function my oven had no power. Replaced the thermal relay and it worked fine. Now, we have run the self cleaning function once more and the oven died again. Is there another...
There is always going to be a problem whe you run your self clean feature. Your oven heats to over 800 degrees and this high heat takes out electronic parts.
Oct 18, 2009 | Whirlpool RBS245PDS Electric Single Oven
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool 27" wall oven. no heat after self clean
Self cleaning features are not recommended by most appliance technicians. The ovens are not constructed satisfactorily to expel the 1000 degree heat, Therefore the thermal fuses blow as well as other parts failures.
Remove the oven. Remove the rear panel. Replace the thermal fuse in the back of the oven. Use Easy Off next time.
May 12, 2009 | Whirlpool RBS245PDS Electric Single Oven
Oven does not heat. Broiler and stove work. NO gas smell.
could be the oven thermostat, get a plumber/heating engineer out, but make sure you can trust him, cause he could try and say u need a new cooker when it MIGHT only be a new oven thermostat.
Feb 02, 2009 | GE Ovens
Whirlpool RBS305PD Electric Single Oven Logo
225 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
