Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire ltf6000es1 error codes
Saw your solution to another problem and you stated to hold start/pause and cancel for 3 seconds. I did and it gives an e 23. What do I do?
  • mleiterman Feb 02, 2009
    Thanks for the reply. Is this something that is easy to replace and do you know what the part number might be if it is something I can replace?
    Thanks again.
  • wastenafarm Feb 04, 2009
    door won't lock. panel flashes error loc. where do i start?
  • 640 Answers
Im playing catch up...but if your getting e23,,you have a defective control board,,,replace,,the pump relay on the board is shot...
Posted on Feb 02, 2009
Frigidaire front load washer. E46 error. replaced control board. Still have same error code. Is there a way to clear the error code and reset the washer with the new board?
Hello CJ Lou - Typically that is correct, error code E46 indicates to replace main control board. First, either unplug or flip the household circuit breaker off to the washer to reprogram it. Wait approximately ten minutes and restart unit. Then try pressing and holding the START and PAUSE/CANCEL buttons simultaneously. All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the START and PAUSE/CANCEL buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes. If it proves to be ineffective, contact a professional to accurately pinpoint any potentially more serious issues.
Jan 30, 2013 | Frigidaire ATF6000ES Front Load Washer
How do you ge codes on a electrolux front laod dryer?
* Wake the washer by pressing any button. * Wait 5 seconds. * Press and hold the Start and Pause/Cancel buttons simultaneously. * All LED's will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LED's. The control will repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
Aug 19, 2012 | Frigidaire AEQ7000EG Affinity Series...
PT reads on display and it will not drain
Frigidaire does not have a "PT" technical error for any of their units. Please try to recall the error exactly by doing the following:
* Wake the washer by pressingany button.* Wait 5 seconds.* Press and hold the Start andPause/Cancel buttons simultaneously.* All LED's will go blank and after a few seconds the controlwill signal the stored code using audible beeps and blinking LED's. The controlwill repeatedly signal the code, as long as the Start and Pause/Cancel buttons are pressed. A two second pausebetween repeats affords you the ability to make accurate counts to identify thecorrect error codes.
Aug 01, 2012 | Frigidaire Affinity ATF7000E Front Load...
Ltf2140
WAKE THE WASHER BY PRESSING ANY BUTTON.
WAIT 5 SECONDS.
PRESS AND HOLD THE START AND PAUSE/CANCEL BUTTONS SIMULTANEOUSLY.
ALL LED'S WILL GO BLANK AND AFTER A FEW SECONDS THE CONTROL WILL SIGNAL THE STORED CODE USING AUDIBLE BEEPS AND BLINKING LED'S. THE CONTROL WILL REPEATEDLY SIGNAL THE CODE, AS LONG AS THE START AND PAUSE/CANCEL BUTTONS ARE PRESSED. A TWO-SECOND PAUSE BETWEEN REPEATS AFFORDS YOU THE ABILITY TO MAKE ACCURATE COUNTS TO IDENTIFY THE CORRECT ERROR CODES.
PLEASE NOTE THE FOLLOWING: ON A SMALL NUMBER OF WASHERS WITH SERIAL
NUMBER PREFIX XC4, IF THE PREVIOUS PROCEDURE DOES NOT PREFORM AS
SPECIFIED, FOLLOW THE OPTION BELOW:
* FOLLOW ALL PREVIOUS STEPS BUT INSTEAD OF PRESSING START AND PAUSE/CANCEL BUTTONS, PRESS AND HOLD OPTIONS AND PAUSE/CANCEL BUTTONS."
*THE CONTROL WILL PAUSE FOR 2 SECONDS, THEN REPEAT THE CODE AS LONG AS THE TWO BUTTONS ARE PRESSED AND HELD."
NOTE: A LETTER APPEARING IN THE CODE STANDS FOR A NUMBER HIGHER THAN NINE: A=10 B=11 C=12 D=13 E=14 F=15 "
"EXAMPLE CODE F1: THE FIRST DIGIT WOULD BE 15 AND THE SECOND WOULD BE 1. IF THIS CODE WOULD APPEAR ON A WASHER IN THE GOOD MODEL LINE, THE FIVE INDICATOR LIGHTS WOULD BLINK FIFTEEN TIMES AND THE START INDICATOR LIGHT WOULD
Jul 29, 2012 | Frigidaire GLTF2940ES Front Load Washer
Wont start
First you have to find the error code.
So! To recall an error code,
Wake the machine by pressing any button
Wait 5 seconds
Press and hold the Start and Pause Cancel buttons simultaneously
Ail LEDs will go blank and after a few seconds the control will signal the stored code using audible beeps and blinking LEDs. The control will repeatedly signal the code, as long as the Start and Pause Cancel buttons are pressed.
A two-second pause between repeats affords you the ability to make accurate counts to identify the correct error codes.
As long as the buttons are held, the failure code will appear in the display as an E followed by two numbers, a number and a letter or two letters, please post back with the error code for further assistance.
Dec 03, 2011 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire GLFT294OES3 turns on, but after a few seconds, it goes to "No Spin" and errors out. The water won't come through and it just shuts off, please help!!!
Wait 5 seconds
You may also have a code such as E47 or E24 etc..
Comme back with the code and I will explain what is the meaning of the code
Oct 02, 2011 | Frigidaire GLTF2940ES Front Load Washer
My washer won't start, it keeps flashing ERR and then the wash-time, and then LOC. My roommate says to fix it before, he held down three buttons, but can't remember which ones. Any idea?
Try the following two buttons: press Options and Select together for 10 seconds (or until the LOC disappears). The pair of buttons held for 10 seconds also sets this control lock.
To find out the error code, turn the Program knob to the start position, Spin Only. Press Start/Pause to start the cycle. Press Cancel to stop the cycle and turn off the LEDs. Press Cancel again and within 5 seconds press and hold the Options and Start/Pause buttons until the LEDs start chasing. Then release the buttons. Turn the Program knob seven clicks clockwise from the Start position. The control will signal the last error code. To clear the error, press and hold Options and Start/Pause for 3 seconds. Then either unplug the washer for 5-8 seconds before plugging it back in. Alternatively, press and hold Options and Start/Pause together for a few seconds until the Wash LEDs appear.
http://www.applianceblog.com/mainforums/frigidaire-electrolux/12950-frigidaire-atf6000es1-wont-drain.html has a link to the service manual for the listed washer (the link is half-way down the page).
I hope this helps.
Oct 12, 2010 | Frigidaire ATF6000ES Front Load Washer
Trouble code e20
Water not draining fast enough. Try holding the Start/Pause and Cancel key together for 3 seconds. The Door Lock, Wash, Rinse and Final Spin LED’s should light. Any error codes should be displayed when pressing the Start/Pause and Cancel keys.
Remove the bottom front panel. This can be done from the rear of the machine by unscrewing the 2 securing screws. The pump sits on the right side. Disconnect the hoses and clean them. Make sure to clean the pump impeller out as well.
Oct 12, 2009 | Frigidaire Affinity ATF7000E Front Load...
Error code e10
Communication failure =E10
1. Rotate the CYCLE SELECT KNOB to the 3 O’clock
position.
2. Press and hold the Select and Pause Cancel
buttons simultaneously for (6) seconds.
3. Immediately after, press and hold the START and
Pause Cancel
buttons simultaneously for (4)
seconds.
4. Rotate the CYCLE SELECT KNOB to the 2 O’clock
position.
The STATUS indicator lights will flash the number of
times for the first digit of the code and the START indicator
light will flash the number of times for the second digit.
The code is obtained by counting the number of times
the lights flash. Example E24: the STATUS indicator
lights would flash twice indicating the 2 and the START
indicator light will flash four times indicating the 4. The
STATUS indicator lights and the START indicator light
will start flashing at the same time. The control will then
pause for 2 seconds, then repeat the code.
Troubleshoot the problem by using the chart on next
page.
To move to the next code, press the OPTIONS button.
To clear code, press the Select botton.
To exit this mode, simultaneously press and hold the
Select and Pause Cancel buttons for (6) seconds to
reset.
if this does not work need to replace control
Sep 07, 2008 | Frigidaire Washing Machines
ATF6700FS - Affinity? 3.5 Cu. Ft. I.E.C. Capacity Washer Won't Start
ERR=An error has been detected
PAU=Cycle has been intrupted
58=High current on motor phase
To clear latest stored error code:
• Turn the Program Knob to the start position, Spin Only.
• Press Start/Pause to start the cycle and save it.
• Press Cancel to stop the cycle and turn off the LEDs.
• Press Cancel again to turn on the LEDs.
• Within 5 seconds, press and hold the Option and Start/Pause buttons until LEDs start sequentially chasing, then release buttons.
• Turn the program knob clockwise 7 clicks from the Start Position. The control will signal the last error code.
• Press and hold the Options and Start/Pause buttons for 3 seconds. The code will be cleared.
• Exit Diagnostic Mode to return the washer to normal operation.
a) Unplug the power cord, wait 5-8 seconds, then reconnect the power cord OR
b) Turn the program knob clockwise 2 or 3 clicks after the Start Position. Press Options and Start/Pause buttons
together for a few seconds until wash cycle LEDs appear.
Feb 25, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
580 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
