Question about Sharp DV-HR350H DVD Player/HDD Recorder
Video playback is in black and white
The same tape shows in colour on a different machine
  • 790 Answers
Hi
Please check the system settings to configure the PAL SECAM NTSC Settings
Thanks!
Posted on Feb 01, 2009
I have a collection of VCR tapes. They all will play sound but no picture - same in 3 different VCR players - please help!
Your current TV may not be "multi-system", which is needed to play tapes that have been recorded on a VCR that operates on a different "colour system". VCRs can be "multi-system" too, in which case, you select its output to match the playback TV's colour system. When you previously got the tapes to play, your VCR and TV were either "colour system matched" with each other (and the tapes), or "multi-system"
http://helpguide.sony.net/dsc/1510/v1/en/contents/TP0000576912.html
A simpler issue may just be a faulty video cable between the VCRs and the TV, assuming you used the same cable in all cases.
Nov 14, 2017 | Televison & Video
Jvc gr-ax35 only plays black and white on 3 different sources i.e. tv, dvd recorder player and usb capture. could this be tape detrition or dirty video head
i would take it and get it serviced
i think the tape isnt running at quite the right speed perhaps a dirty bearing
usually if you get black and white from a colour video
then its either recorded in black and white or playing back black and white
so if you record then test it using a a vcr and a converter vhs tape box then you can see if its recording in black and white
then youll know its something too do with either the colour carrier etc component of the video its outputing
dont think its a dirty head
but you can clean it easy enough
i use a plain manila envilope and use the inside of its paper
the outside is smooth the inside is rough
its just right to clean the head drum
and some small lint free cloth to carefully clean the mecha
i use IPA isopropile alchohol {get from the chemist}
Jan 10, 2015 | JVC Video Cameras
Playback is black and white
if this is b/w on the tv then you have a settings problem.
you need to check you connected the camcorder to the tb correctly, it should be yellow for video and red and white for audio, and you could try looking at the tv menus
if its the camcorder then check the cc monitor. and all the settings. Get anew dv tape and record something , check its colour then play it through the tv.
Sep 17, 2009 | Sony BRAVIA® DAV-HDX576WF Theater System...
VHS plays in colour and DVD plays in black and white.
there is a circuit in the color section to put the tv to black and white if the color subcarrier is missing from the broadcast signal.
it is called a color killer and needs to be adjusted.
it is for a technician to do.
it operates off the 3.58mhz color subcarrier.
Aug 18, 2009 | Jwin Electronics JD-VD138 DVD Player
Replays both dvd and video tapes back in black and white only.
Check the av channel you are playing back on if it is av2s then this will play in b/w,you need to be on av2
Aug 09, 2009 | Televison & Video
TV colour programmes replayed in my video turn out in black/white
Fixed the VCR problem. Thightened all the connections and it now seems to be working OK
Dec 14, 2008 | Televison & Video
Black and white playback with sony handycam dcr-hc20
There is no problem on your camera, DCR-HC19E is PAL system(European system) DCR-HC20 is NTSC(American system). Are you in US or Europe? I think your TV is NTSC, cause the tape recorded on DCR-HC19E you played has no color. To confirm, connect your HC20 to TV in camera mode, not recording yet, just look at the TV as your monitor, If its in color, no problem, just erase the old video recorded on the HC19E, but if its important to you, you can convert it to NTSC using a PC. thanks
Sep 12, 2007 | Sony Handycam DCR-HC20 Mini DV Digital...
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
VCR won't tape and get no playback
First check how good / bad are your recordings. Take a current / recent recording done after this problem cropped up, and play it back on another VCR - maybe a friend's. If the recording plays back badly- showing the symptoms you described, then the problem is still dirty or worn out Video Heads. If the Recording plays back perfectly on the friend's machine, but plays back badly on your machine, I still suggest that you try cleaning the Heads one more time, and if the problem is not resolved, it is time to trash the VCR. One last question, you say that you have reset the channels. Are the reception channels' images clear? I may be able to give some more suggestions, based on this response.
Apr 17, 2007 | Goldstar GVR-E435 VHS VCR
Black and white playback on television screne
Select the correct color system in your tv. probably the system which was selected in your tv did not match that of your video cam. good luck!
Feb 15, 2007 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Sharp DV-HR350H DVD Player/HDD Recorder Logo
64 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
