Question about Samsung SyncMaster 551 15" CRT Monitor
IBM MONITOR ON SCREEN DISPLAY
Hi, I'm having XP Home SP2 on IBM THINK CENTRE,MONITOR E 54, but did never experience such a peculiar problem. It happens like, in my monitor, for the last few months I'm seeing that, the on screen display (i.e. the display we see after pressing those buttons) appears in the monitor on its own and keeps on coming and disappearing continuously. The contrast menu appears and it goes up to 100% on its own. If I press decrease button of the monitor sometimes it decreases but again immediately increases up to maximum. It remains there and hardly goes off from the monitor.In the Device Manager I've checked the status of Monitor n in the Properties therein it shows the 'device is working properly'. This gives a lot of troubles in my working. Would you please suggest me something to fix it? I have tried all the method from reinstalling graphic driver to checking the cables.
  • anish2213 Sep 30, 2008
    same prob m too facing pls give some solution?
    Problem Solver:
  • 16 Answers
This is a problem in the monitor itself. The computer has absolutely no control over the On Screen Display. Most likely the button that controls contrast is stuck. You might try blasting the button with canned air. Sounds like it might be time to buy a new or used monitor.
Posted on Aug 01, 2007
SOURCE:
How to install monitor driver when you cant see the monitor in xp sp2
It could be the display driver issue as the monitor should be detected by default.Try connecting to the display port direct;y to the CPU display port if you are connecting to the graphics card and then check.
If you need online technical support, you may very well contact TheBestPcDoctor. I get my all issues fixed by them and it is a reliable support according to my experience. If you want you can also get in touch with them @
www.thebestpcdoctor.com or via 877-407-9229
Oct 04, 2011 | Dell E173FP 17" LCD Monitor
Screen goes blank after booting with WinXP SP2 CD.
Hi, your will need to delete your windows XP re format that part of your hard drive, then re install XP
Jul 04, 2010 | Microsoft Windows XP Professional SP2
Lcd screen stuck in external screen mode
How to use the function (Fn) keys on the keyboard - ThinkPad T40, T40p, T41, T41p, T42, T42p, T43, T43p
Switching the display output location.
Switch between the computer display and an external monitor. If an external monitor is attached, the computer output is displayed in the following three patterns by turns:
  • External monitor (CRT display)
  • Computer display and external monitor (LCD + CRT display)
  • Computer display (LCD)
Notes:
  • For any operating system other than Windows 2000 or Windows XP, no additional procedure is needed. Just press Fn+F7.
  • This function is not supported if different desktop images are displayed on the computer display and the external monitor (the Extend desktop function).
  • This function does not work while a DVD movie or a video clip is playing.
To enable this function in Windows 2000 and Windows XP, the following procedure is needed:
  1. When you log on to Windows 2000 and Windows XP for the first time, press Fn + F7 and select a display-switching function in the Initial setup window. Since in Windows 2000 and Windows XP multiple users can log on to a single operating system by using different user IDs, each user needs to select the function in the initial setup window when logging on for the first time.
  2. If the Fn + F7 key combination have been assigned to a presentation scheme function, start Presentation Director, and change the settings.
Feb 28, 2010 | IBM ThinkPad T41 Notebook
Game display only occupies the center portion of monitor not full screen. Thinkpad A22m w/ windows xp home SP3. Can't get the game screen to display on the full monitor screen.
It is most likely that the game is unable to operate at the resolution that your screen is set at and is compensating by sizing the game window to the required size. You might change you display resolution to a lower setting.
Hope this helps! Rate my solution!
Jan 07, 2010 | IBM ThinkPad A22m 2628 Notebook
Cant find download for drivers xp think vision L150 moniter
you dont really need a driver for this monitor but here is a link to where you can get the color setting and so on for it. click here
Nov 30, 2009 | IBM ThinkVision L150 (Black) 15" LCD...
IBM R40 Screen Problems
I think you have an inverter board thats just about dead. It's located in the screens plastic housing at the bottom of the screen just above the keyboard. It's about 4 inches long and a half inch wide.There's just one little cable connecting it. But you have to take your screen apart to get to it. It's easy to replace and relatively inexpensive but it does require a little disassembly skill.
Also ,I will need the exact part number from the bottom of your laptop. There are several different R 40 models, and 2 different screen sizes.
Apr 14, 2009 | IBM 11P836402 for ThinkPad R40 Monitor
No sound driver?
I think you must have the "Universal Audio Architexture" first, u can download it from microsoft site...here
http://hotfixv4.microsoft.com/Windows%20XP/sp2/UAA_HD_Audio_OOB_update/5013/free/216955_intl_i386_zip.exe
it rather annoying I think, for an old style notebook...mine too
hope this help :)
Jan 18, 2009 | IBM ThinkPad R60 Notebook
Second monitor
I beleive that you may need a splitter, I think it may be called a convergance splitter to work with the program. Check with the manufacturer support for the program. They should be able to tell you if a splitter is needed.
Sep 02, 2008 | IBM ThinkPad T42 Notebook
T40 Monitor Display
I assume you are running window XP or vista?
Go to
Start>Control Panel and look for Power Saver, or Screensaver options. There will be settings there for determining how long, if at all, your display will take to turn off.
Nov 15, 2007 | IBM ThinkPad T40 2373 Notebook
Background display
OK....in XP Home and PRO SP2 a bug cause this to give vga shift.....reinstall OS with XP SP1 and the problem would be solved....there is currently no solution for this. JJ
Sep 14, 2007 | IBM ThinkPad T23 2647 Notebook
Samsung SyncMaster 551 15" CRT Monitor Logo
108 people viewed this question
Top Samsung Computers & Internet Experts
asber
Stormi  Paulk
Stormi Paulk
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
