Question about RCA HD61LPW42 61" Rear Projection HDTV
RCA CHASSIS CTC195K BLOWA SCR
Rca cHASSIS ctc195k BLOWS SCR AND FUSE AT TURN ON I HAVE CHANGE FLYBACK AND hot transistor same problem
  • taxiad Dec 17, 2008
    I have CTC 195 projector that blows power supply fuse when i plug it into ac power source, prior to turning it on,
    Problem Solver:
  • 6 Answers
Make sure that the scr has adequate insulation. I have run into this problem before several times, and it always comes back to the scr and heatsink. check for shorts before you plug it in. unless you have an isolation transformer, do not hook up ac powered equipment to chassis ground, as this will blow your transistor again. use dc poweered volt-ohm meter.
Posted on Aug 09, 2007
SOURCE:
I have sound but no picture on my rca 32f531t
you can have these guide:
Flyback Transformer
the horizontal output transistor is for ITC008
search these site you can find more info for your chassis
that was 2 years ago
Sep 28, 2012 | RCA 32F531T 32" TV
My tv. proscan mod. ps50700 won`t turn on
The PS50700 uses the 195 series chassis. The most common cause of the set not starting up is a shorted flyback (high voltage) transformer. Sometimes a shorted flyback will also cause the horizontal output transistor to short too. These parts need to be tested and/or replaced by a tech familiar with the RCA 195 chassis.
Aug 17, 2007 | Proscan PS65000 65" Rear Projection...
When i plug it in it cherps but wont turn on
That model was produced with different Chassis types. I would need the Chassis number usually a PTK or a CTC number to assist you with the most common cause of the set chriping which is usually due to the flyback and HOT transistor needing replacement.
Dec 26, 2009 | RCA P46810LV 46" Rear Projection...
RCA P60920BL wont power up makes clicking sound
This is a chassis PTK195 and acommon fault with these sets, that causes the symptom you describe, is the flyback transformer goes bad.
If you're at all familiar with electronic repair you could start checking there (and horizontal output transistor shorts). If not have an RCA approved warrany repairer give you an estimate/service call.
Note: the good thing about these sets is the chassis is very common and easily removed for service (without bringing in the whole set.) .
Usual cost to repair flyback/ dead set symptoms $200-$350.
Nov 24, 2009 | RCA P60920BL 60" Rear Projection...
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
RCA CTC203 chassis-Flyback and hot replacement
Use the one that comes with the new transformer. The old one can be removed by squeezing the sides of sucktion cup.
Dec 15, 2008 | RCA F32668 32" TV
Rca projection tv serv#p56938yx mod#p56938 serial#c135c50tx chassis#ptk195s16p cant id
Here are some numbers to call for Flyback Replacement
Electronica 1-800-772-5578
Asti 1-800-221-1828
you will need RCA chassis# PTK195s16p - flyback number1541938b.
ThankYou for using FixYa. Have a Nice Day.
Feb 07, 2008 | Televison & Video
My RCA TV
I Just started to service one of these RCA ATC-010 chassis,I found a shorted Horizontal Output transistor 2SD-3402.
This could be just a failure of the transistor itself or the transistor failed because the flyback transformer has either shorted windings or internal diodes. These parts are not expensive,I suggest replacing both at the same time to save yourself future aggravation.
Jan 28, 2008 | RCA 32V524T TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
56" RCA projection TV
If you can find the horizontal output transistor which is located near the flyback transformer,one lead of this drive transformer is connected to the base lead. (horizontal output transistor). There may be a little coil in series with this lead going to the transistor.
Jan 17, 2007 | RCA P52921 52" Rear Projection Television
RCA HD61LPW42 61" Rear Projection HDTV Logo
110 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
